Technical LA 318 and getting proper quench, possible?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Nov 30, 2024.
  1. Sharpone
    Sharpone
    Your welcome, glad I could be of service
    Dan
    Budget36 likes this.
  2. Budget36
    Budget36
    So after a lengthy thread on the Abody forum, I’ve decided to just get the block squared, decked to .020/.025 below 9.6 factory spec, and run it as-is.
    Next up will be a cam change. The one in it might be okay, all I recall was “like an RV grind” so I’ll check the lift and see where it’s at.
    Thanks all!
    RodStRace, 57 Fargo and Sharpone like this.
  3. RodStRace
    RodStRace
    Cams open up ugly with the lifter problems. I'd just get it built cheap and change only if needed.
    If you want to toss in a part that can upgrade later, get a timing set with degree slots.
    Sharpone and Budget36 like this.
  4. Budget36
    Budget36
    The plan now is (if I change the cam) to use the lifters, they are new, unused from 25 years back.
    I think before just buying a cam, I’ll send the one in it off to get it measured, WTH.
    Sharpone and RodStRace like this.
  5. RodStRace
    RodStRace
    Budget36 and Sharpone like this.
  6. Sharpone
    Sharpone
    @Budget36 How did you make out on your engine?
    Dan
  7. Budget36
    Budget36
    I’d have to dig out the notes I took, but the cam was “okay” for my needs. It won’t make the power as linked to before, but I’ll be fine.
    Engine is back together with fresh lube, and will think about firing it off this fall/winter.
    Sharpone likes this.
  8. Sharpone
    Sharpone
    Good deal
    Dan
