Projects LA HOT RODS Get's A 37 Pontiac
Discussion in 'The Hokey Ass Message Board' started by saltflats, Dec 24, 2022.
  1. Stock Racer
    Stock Racer
    White Walls = late 50's, early 60's. Black Walls = late 60's, early 70's. Whatever look you're going for, they are both cool
    saltflats and mad mikey like this.
  2. saltflats
    saltflats
    from Missouri
    I like the way you guys think. Was going to have them mounted today but the garage door spring broke so now I in the garage door business. :mad:
    osage orange and mad mikey like this.
  3. Stock Racer
    Stock Racer
    It's always something
    saltflats likes this.
  4. bchctybob
    bchctybob
    and wasn’t the white wall slick period over by the time Cragar SS wheels arrived on the scene?
    40FORDPU and saltflats like this.
  5. rdscotty
    rdscotty
    from red deer
    Blackwalls for sure
  6. akoutlaw
    akoutlaw
    I like the black walls better also.
  7. saltflats
    saltflats
    from Missouri
    Black walls it is.
  8. saltflats
    saltflats
    from Missouri
    So trying the figure a cut line for tire clearance so it doesn't look like a total hack job.
    See the red line, what's your input?
    Thanks James.
  9. bchctybob
    bchctybob
    Just look on here for pictures of Don Nowells Chevy or check out this one.... Nice tire fit.
  10. wrenchbender
    wrenchbender
    Yes don Nowell’s 37 Chevy was and is and should be the standard every one needs to use for a gasser it is perfect in every way
  11. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    The wheel open redesign looks good. Now be a Man and reroll the lip like factory and redefine the radius end of the lower rear body line!! ;) lol Larry
    Stan Back and saltflats like this.
  12. wrenchbender
    wrenchbender
    Yeah James just cut it up already I’d have already cut it up and had the thing rolling by now lol
  13. akoutlaw
    akoutlaw
    I think that you are on the right track. Your lines look good to me.
  14. saltflats
    saltflats
    from Missouri
    I thought I would cut a pie out and save the rolled lip and work it back out and add what small parts would be needed. Going to work on something to get a more accurate line, thinking of something attached to the old wheel to use as a big compass.
  15. midnightrider78
    midnightrider78
    When Dad and I re-cut the wheel arches on my '56(originally was done without much concern for accuracy), we made a sort of compass out of some scrap metal we had around to mark a nice smooth, consistent radius.
    bchctybob and saltflats like this.
  16. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Actually, James that is exactly what I would do too. Cut back about an inch from the factory lip and fit it to the new radius line, but weld and metal finish the seam. And if a little BALLAST WEIGHT is needed that's okay. ;) lol Larry
  17. saltflats
    saltflats
    from Missouri
    You think an inch, I was thinking less than that. Still working on a marking fixture.
  18. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Whatever works for you, I like a little mor meet to use swivel head vice grips to position the seam and to get a dolly behind to adjust the seam. It also allows me to adjust the fit with the shrinker/stretcher or run it through the panishing hammer. or even the English wheel. you can do it, I have faith. :) your one of the few projects going on here. keep up the good work, Larry
  19. saltflats
    saltflats
    from Missouri
    So I made a holder for a marker to compass out a circle.
    I'm a little stumped. Think I need an aspirin.
    osage orange likes this.
  20. saltflats
    saltflats
    from Missouri
    20230818_145744.jpg 20230818_145752.jpg 20230818_145809.jpg 20230818_145814.jpg
    It's looking like I need to lower the ride height so I can have a round wheel opening.
  21. saltflats
    saltflats
    from Missouri
    I hear what your saying. I was thinking it didn't make any difference how or where my marker was on the axle as long as it didn't move it would still make a circle. I can say I have been trying to make it tight to start, sure would help me ease into it.
    Dick Stevens likes this.
  22. saltflats
    saltflats
    from Missouri
    I am rotating the axle and the fixture moves with it.
  23. saltflats
    saltflats
    from Missouri
    If this helps, I tack welded a lug not to the tube. I then tighten the lug nut, next I slid my eye bolt with a hose clamp welded to and tightened it up to hold the marker holder, then just turned the brake drum. Never touched the fixture again.
  24. saltflats
    saltflats
    from Missouri
    Kinda awkward but it's the same. I can see it when I set the wheel and tire up next to it.
  25. You had it with the squiggled out line.
  26. saltflats
    saltflats
    from Missouri
    You may be right.
    Crusty Chevy likes this.
  27. 37 caddy
    37 caddy
    from PEI Canada
    I would drop the rear a bit and put the tire next to the fender and then start drawing a line,otherwise it isnt synettrical? The rear of the car will bounce some when it is loaded,it would look best if it was a "honed" out version of the factory wheel well,if you cut some off each end it would look kind of wonky,at least to me anyway. harvy
  28. saltflats
    saltflats
    from Missouri
    One aid I have been using is this hoop I rolled out during my comp/ coupe project using the same tires.
    Guess the hard part for me is trying to see a round opening.
  29. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    I think your over thinking it James. Just make sure your fixture is at top dead center and set your marker at the point you want to make your cut from the wheel lip. I was talking an inch but sounds like you were thinking just above the point where the lip rolls up. Then rotate the axle, as long as the fixture doesn't move the line will be parallel to the axle center. I would the cut along the line leaving the upper section intact. Then massage the lip over to the cut line, clamp it in place and mount the tire, then you can adjust the lip accordingly and scribe the area to be remove and trim it to fit and butt weld it together. Rolling the tire up next to the car I think is giving you an optical illusion. Its only metal, you got this. ;) Larry
  30. saltflats
    saltflats
    from Missouri
    Larry, hold my beer.
    VI Lonewolf likes this.
