SOLD Laboranti 32 - 5 Window Coupe 100k 215-300-6885 - ask for Jerry FRAME By Andy Kohler Original 32 Ford frame, boxed. 37 Ford X member, early Ford pedals. Custom flattened front and rear crossmembers. Rear frame horns bobbed. Front V style spreader bar BODY and PAINT Top chopped 4.75" front, 4.50" rear Hand hammered decklid louvers Flattened firewall to accommodate engine Chocolate Root Beer metallic base/clear by Dave Matthews Flat line stripping by DeWayne Connet Custom fabricated Pines Winterfront style grill insert- chrome plated with replicated Pines badge ENGINE and TRANSMISSION Cadillac 331 .40 over, Isky cam Offenhauser 2x2 intake Original Stromberg 97's, chrome plated Grace and Co. Air cleaners- chrome plated Pat Mason rebuilt magneto- chrome plated case Original valve covers - chrome plated Vintage Speed finned valley cover Original Badger spark plug covers- chrome plated Throttle Jockey wire separators New radiator 39 Toploader converted to open drive- rebuilt Andy Kohler FRONT SUSPENSION and BRAKES Dropped original 32 heavy, drilled, and chrome plated 34 split wishbones - chrome plated Model A reverse eye front spring - chrome plated Chrome plated spring shackles 49 F-1 upper shock mounts- chrome plated Brian B*** custom front brakes, drilled and chrome plated Boling Bros front hubs 40 Ford spindles chrome plated So Cal front shocks - chrome Boling Bros finned brake drums Chrome plated steering drag links REAR SUSPENSION AND BRAKES 40 Ford banjo rear - rebuilt with Hot Rod Works ring and pinion kit, 3:54 gears, and open drive conversion kit. Modified 40 Ford rear wishbones into ladder bars. 42 Ford rear spring, reverse eye Posie- chrome plated Chrome rear spring shackles Boling brothers rear brakes- chrome plated Boling brothers finned brake drums STEERING Vintage magnesium cased Halibrand steering box hung on custom cowl steering framework Custom column extension and polished stainless interior column support. 41 Lincoln steering wheel, recast by Steering Wheel Chris and paint matched Chrome plated pitman arm Chrome plated Custom spindle steering hoop EXTERIOR 37 Airflow door handles machined to fit 32 handle bases - restored and chrome plated 36 Chrysler tail lights - bezels replated 1940's bronze gas gap- polished 37 Lincoln Zephyr Trunk handle- restored, polished, painted by HotRodJen Chrome Guide headlights. Hollywood license plate light- replated Custom polished stainless rear push bar Custom polished stainless headlight bar EXHAUST Custom Belond style headers by Matt at Gear Drive - chrome plated Custom polished stainless steel exhaust system with side kickouts and Triumph style rear pipe flares 36 Ford driveshaft style side tubes for side pipes, made by Matt at Gear Drive - chrome plated Custom machined br*** side pipe caps Modified British bike hub wingnuts for cap hold downs. INTERIOR Custom brown roll and pleat interior, German squareweave carpet. Chrome plated garnish moldings Custom aluminum WW2 style seats- polished Custom aluminum console - polished 1940's SW rear mount gauges 1939 Nash Speedometer 1932 Auburn Tach Custom Crafty B underdash switch console with br*** switches 1949 Mercury door handles Recast V8 shift knob, Steering Wheel Chris, paint matched. Custom turned br*** pedals WHEELS AND TIRES 1940 Ford steel wheels Ribbed stainless Ford Deluxe inner and outer trim rings and matching hubcaps Firestone 5.50/ 16 and 7.00/16 tires FUEL TANK The fuel tank in this car comes with a special and do***ented history, and is my favorite part of the car. The tank was made by Dean Moon, of Moon Equipment and was installed on his engine dyno that he ran during the early years of the Moon business. The tank has several extra bungs welded onto it, as well as two large spout openings for full size fuel caps for various hookups while on the dyno. It has one of the early style caps still on it and and original pair of feet/tank stands. The cap and stands have been with this tank for its life. I purchased the tank from the family who bought Moon's dyno, and used it at their Speed O Motive engine tuning business in California. Outside was pinstriped and leafed by HotRodJen. NOTABLE AWARDS -Jalopyrama , Best of Show Bomb Award - NSRA , Cl***ic Instrument Pro's Pic - Greenwich Concours, Award of Speed and Style - Cleveland Autorama, Dirty Dozen Award - Vagabonds Annual, best in show -Whiskey Throttle Fair, captain's corner super 7, best interior award, best attention to detail award, best hot rod award MAGAZINE / ONLINE COVERAGE Hop Up Special #8 - Feature Car Full, detailed build journal featured on the Jalopy Journal / HAMB https://www.jalopyjournal.com/forum/threads/jerry-s-32-5-window-project.1032277/ Greenwich Concours appearance feature article on the Jalopy Journal https://www.jalopyjournal.com/?p=49279 TRANSFER Good clear Pennsylvania ***le in my name
