Laced up wires, What do you think?
Discussion in 'The Hokey Ass Message Board' started by Yankeyspeed, May 16, 2007.
  1. Yankeyspeed
    Yankeyspeed
    I starting lacing up all the wiring in the engine bay of the Plymouth. I am about half done. I am thinking of doing under the dash after this. What do you think?
  2. slo60
    slo60
    looks good to me-- thats about where i am on the truck...
    keith
  3. kwiksilver
    kwiksilver
    You must have spent time in a telephone central office. All our wire is laced up like that with waxed string. looks cool. I prefer friction tape.
  4. Yankeyspeed
    Yankeyspeed
    Pipe Organ guys still do it old school:D
    I can still get the waxed nylon from a supplier no problem.
  5. Clutch 2
    Clutch 2
    from Maryland
    That looks great!That's how i plan on doing my coupe,but can't seem to find that waxed string. I plan to do mine like the WWII aircraft era. Where did you find it?
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    You can buy the original style woven lacquered fabric conduit in varying sizes, split it, cover your stuff then tie it up.
  7. squirrel
    if you can't find a supplier, try searching for "lacing twine", which is what they call it.
  8. AstroZombie
    AstroZombie
    thats how boeing does it too. looks better than split convoluted tubing, easy to work with, and did i mention it looks better than split convoluted tubing!!! good job man, i dig it.
  9. 64 DODGE 440
    64 DODGE 440
    from so cal
  10. ChuckleHead_Al
    ChuckleHead_Al
    We got tons of that shit here..
    But Uncle Sam and Fraud, Waste and Abuse.
  11. twolane
    twolane
    looks damn good!
  12. fiat128
    fiat128
    from El Paso TX
    I work in an electric motor factory and we lace up the end turns of the motor stators with tie cord like that. I'll have to snarf some.
    This stuff is heat rated too.
  13. Yankeyspeed
    Yankeyspeed
    Thanks gang, after the engine I will hit under the dash.
  14. Be sure to check out the Aircraft Spruce source in a previous post. I think you'll find a lot of stuff you can use for rods. I used them a lot for my altered's hardware needs, and they sell all kinds of Chromoly tubing by the foot. Great Folks!
  15. ckdesigns
    ckdesigns
    from Ogden,Utah
    That was my first thought.
  16. Aircraft style is usually tie wraps, but I like the look of lacing if it's heat proof. Rags
  17. Looks nice.
    Reminds me of the wiring behind the control panel in older power stations.
    I'm curious about your remote oil filter.
    Is there an inner fender panel or shield that protects it from rocks and the like?
    I'm a bit of a worrywart and can see a rock puncturing the thin wall of the filter can.
  18. Yankeyspeed
    Yankeyspeed
    Yeah you are right. I need to make something up. My step brother has informed me as well.
