Technical Ladder bars with Z frame?
Discussion in 'Traditional Hot Rods' started by Omarsvette, Oct 12, 2020.
  1. Omarsvette
    Omarsvette
    from Arizona
    I’m setting up my deuce frame with a Z. Is it ok to have the ladder bars point down so much since the frame will be Z?
  2. Omarsvette
    Omarsvette
    from Arizona
    This is a mock set up of the rear end. You get the idea how the ladder bars will point down. Also I haven’t grafted the Z yet. image.jpg
  3. Omarsvette
    Omarsvette
    from Arizona
  4. Stock Racer
    Stock Racer
    Do an online search for "instant center calculators" That should give you some good info. I had it in one of my old posts but I can't find it.
    4ever18, X38, loudbang and 2 others like this.
  5. X38
    X38
    Basically, for a car to drive okay on the street, things are best parallel with the ground.
    Dirt cars, drag cars, rock crawlers, amphibious vehicles and tractors my be different.
  6. Omarsvette
    Omarsvette
    from Arizona
    I agree with parallel to the ground, it’s how I’ve set things up before. I’m considering triangulated set up......
  7. Ratspit
    Ratspit
    I ran into the same issue when I kicked the rear of my truck. The only solution I could come up was to move the bar mounts, under the cab, up as high as I could without interfering with the floor too much. I fabricate my own mount as the ones from Socal and Pete &Jakes just didn't cut it.
    loudbang and Omarsvette like this.
  8. seb fontana
    seb fontana
    from ct
    If the frame is blocked to ride height isn't the cross member awfully close to the ground? Its the axle to ladder bar pivot that matters, you'd have to raise the bar pivot point to get to level to ground, i.e. match c'line of axle.
    Tman, loudbang and Omarsvette like this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Don't understand why anyone would want to build a car without sufficient ground clearance ,just makes no sense to me ....
    sko_ford, hemihotrod66 and Budget36 like this.
  10. Omarsvette
    Omarsvette
    from Arizona
    I understand your confusion, like I don’t understand why people give an opinion when one isn’t asked
    Jibs, vtx1800, WalkerMD and 7 others like this.
  11. Omarsvette
    Omarsvette
    from Arizona
    I felt the same with this style k member. I thought about raising the bar pivot for ground clearance and to level the ladder bars. I think I’ll go that route. The “loop” of the crossmember is the lowest point. Cutting that off would give me clearance and allow me to level the ladder bars.
  12. Omarsvette
    Omarsvette
    from Arizona
    Exactly what I’ll do, thanks
  13. Marty Strode
    Marty Strode
    I would check the drive line angle you will have, also.
    Stock Racer and Atwater Mike like this.
  14. Omarsvette
    Omarsvette
    from Arizona
    I mocked that up already. That balance because I’ll be raising motor and ****** for clearance
  15. alchemy
    alchemy
    Do you have room under your seat to raise the ladder bar pivot point too? All you'll need is a bump in the floor. Would make good use of wasted space.
  16. Omarsvette
    Omarsvette
    from Arizona
    Yes plenty of room, it’s a roadster body.
  17. Omarsvette
    Omarsvette
    from Arizona
    mgtstumpy, Departed and loudbang like this.
  18. mgtstumpy
    mgtstumpy
    I'm no suspension expert however the ladder bars need to point up or be horizontal to be geometrically correct and give you anti-squat with the correct amount of pinion angle at ride height. Pointing them down will cause the car to 'squat under load' which in turn can cause the rear tyres to easily unload. The pinion will point down. The front pivot point needs to correspond horizontally with centreline of housing at ride height.
    With anti-squat built in and bars pointing up at the front up, the wheels have a tendency to turn the axle in the opposite direction. This motion causes the bars to push the car up.
    With them pointing down the opposite occurs and the rear drops.
    Race cars can have 1-2 degree down angle
    X38, Omarsvette and loudbang like this.
  19. gimpyshotrods
    gimpyshotrods
    I am a suspension expert, and you are indeed correct.
  20. Departed
    Departed
    from Canada
    the thing I learned when I built my hotrod is the lower you go the more problems you'll have. seems like you're ground clearance will be 4" ? Will you be running mag wheels with low profile tires?
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    Well I guess you told me ..LOL:p
    Tman likes this.
  22. Omarsvette
    Omarsvette
    from Arizona
    40s style wheels with American cl***ic Bias ply look a like radials. Yes about 4inches image.jpg
  23. Omarsvette
    Omarsvette
    from Arizona
    Sorry I wasn’t trying to be rude or condescending, I wanna keep my post about suspension set up. The more these guys teach me, the more info I can p*** to younger guys to keep this tradition going. ;)
    Just Gary and fauj like this.
  24. Blues4U
    Blues4U
    from So Cal
    Is this an underslung ch***is?
  25. Marty Strode
    Marty Strode
    At 4" ride height, you will be a minimum of 2" below the scrub line.
    olscrounger, X38, Stock Racer and 2 others like this.
  26. junkman8888
    junkman8888
    Looks like you're trying to build a '32 Ford that will "lay frame", which is crazy.
    4" of ground clearance on a street driven vehicle is crazy.
    So you might as well go crazy the rest of the way and build an under-slung frame from scratch instead of butchering the frame you have.
    And I almost forgot, I actually enjoy watching people "color outside the lines", so to speak, but if you expect to show a non-traditional build style on this website and not get flamed, well, that's crazy too.
    sko_ford and Tman like this.
  27. krylon32
    krylon32
    from Nebraska
    I've done several 32 ch***is with kicked or Z'd rear frames and they've all run ladder bars but I uses a straight front bar and not a dropped one. I've never had any problems.
    sko_ford, Tim, AHotRod and 1 other person like this.
  28. Omarsvette
    Omarsvette
    from Arizona
    That’s what I’m working on, a straight bar. How tall of a Z did you make?
  29. Omarsvette
    Omarsvette
    from Arizona
    Ch***is will be above the axle.
  30. Omarsvette
    Omarsvette
    from Arizona
    Please refer to post #10....
