Technical Lake Pipes...mounting
Discussion in 'Traditional Customs' started by Roothawg, Sep 23, 2018.
  1. Roothawg
    Roothawg
    Have lake pipes always been hung with the cheesy wrap around brackets? The last set I had, i drilled a hole in the back and mounted a rivnut inside them. Is there something out there better?
  2. gtokid70
    gtokid70
    I have been thinking about this also, l don't want to use those brackets. I was thinking of using a nut insert and make up some stainless L brackets.
    Sent from my SM-A520W using The H.A.M.B. mobile app
  3. gimpyshotrods
    gimpyshotrods
    The cheesy brackets are traditional.
    pecker head likes this.
  4. Roothawg
    Roothawg
    Are they? I have been trying to look at my little books and I can't see any.
  5. 302GMC
    302GMC
    from Idaho
    The better muffler shops welded studs behind the pipe for hangers, or welded a bracket behind them, depending on length. The mounts were usually insulated with the rubbers & washers used on tailpipe hangers, or shock grommets.
    We're talking about cars that had them hooked up …
  6. gtokid70
    gtokid70
    I would think any grinding or welding would be asking for rust.
  7. BamaMav
    BamaMav
    from Berry, AL
    I remember a tip in R&C or Street Rodder was to cut the circular bracket in half and weld it to the back side of the lake pipe, that way nothing would show on the front side.
    rodncustomdreams and Roothawg like this.
  8. miker98038
    miker98038
    I did like 302GMC did. But as I’m in Seattle, I had stainless lakes pipes, and they were hooked up.
  9. Roothawg
    Roothawg
    Mine will be hooked up.
  10. chopolds
    chopolds
    from howell, nj
    Here in Jersey, I learned from my old boss, they welded studs, or bolts to the backside, and used shock mount rubbers, like 302 said.
  11. straykatkustoms
    straykatkustoms
    I would advise not to hook them up. You have to be aware of leg burns getting out. I've seen some nasty burns. I've seen guys run the exhaust towards the back of the lake pipe. That way they don't get as hot..
    AChopped1950ford likes this.
  12. jnaki
    jnaki
    Hey R,
    Back in May 2018, I was driving around looking for this surfboard mfg. shop in the “surf ghetto” of South Orange County in So Cal. I came across this cool looking lowered, custom, 1951 Buick Sedan sitting by the side of the road. I took some photos and put it in a HAMB thread. (see below.)
    The first thing I noticed were the Lakes Pipes. Those were the big hit of the 50s and early 60s in So Cal. This application looked a little different. The front portion of the exterior Lakes Pipes went into a custom tube. I did not see the rest of the installation, as the traffic was flowing and I could only take quick photos, dodging the cars between shots.
    There were two camps back then during the 50s and early 60s.
    1. Mount the pipes along the bottom of the door sill. Make sure the front curved inlet pipe went back into the motor area, not hooked up, but to make it look like it was hooked up. “Fakies”
    2. Get an inlet pipe running from the actual header down pipe or exit pipe in a “Y” formation for best exhaust flow back and out. Weld it to the Lakes Pipes under the door sill using the bolt on end caps when necessary. (At the local dragstrips, etc.)
    Since I did not hear it run or look deeper into the wheel opening, I do not know which camp this set up falls. We have seen both styles in semi or custom cars.
    Jnaki
    The purple Buick looked as if it is still in a building stage. But, the roots are pretty solid for a current custom car/daily driver.
    https://www.jalopyjournal.com/forum/threads/what-you-see-today.1059262/page-24#post-12574287 51 Buick custom So Cal
  13. loveoftiki
    loveoftiki
    from Livonia,Mi
    Very popular Bill Hines Kustom touch..many of his cars had that mod..exhaust tubing welded to the rocker and in Bills case leaded in..today slathered in Body Filler
    jnaki and Roothawg like this.
  14. I've done the lake pipe a few times. Full length connected in the front is a Hot Spot for sure and as mentioned above connecting way back at the end helps but if your running live the heat still travels full length after a few miles. Also you must Cap the front end, often that led to the front mount behind the fender. It still looked Cheezy when parked. I learned to use about 8" of Flex pipe to connect to exhaust and mount the Pipe solid to the car. That way you didn't need a m***ive tab to hold it in place. On my 51 I actually relieved the lower edge of the Fender so the complete pipe would not hang below it and would be mounted half tube at the bottom of rocker and be strait and not extend into the Fender opening. Then my Wife said **** No! I'm not going to ride in that Damn thing if your doing Lake Pipes. So I did the Plugs instead. The Rippled Lake Pipes got mounted on the Wall in the Shop.
    The Wizzard
  15. Sancho
    Sancho
    Rippled...
    I caught that. ;)
    Roothawg likes this.
  16. I actually can get you a Photo of Them hanging if you'd like
  17. Sancho
    Sancho
    YES, please.
  18. williebill
    williebill
    Me, too. Want to sell them?
  19. Dan Hay
    Dan Hay
    On my 40 sedan, I didn't like the clamps either so my exhaust guy weld tabs to the back of the pipes out of sight.
  20. Here ya go. Note the two Studs welded on the back side a good distance from the Rear Entrance.
    20180925_110413.jpg And to williebill, no. I may get another Wife some day that won't know the hazards of Lake pipes and would let me enjoy the Ripples again.
    The Wizzard
  21. williebill
    williebill
    I understand. Wives are easier to find than decent ripple lake pipes.
    Dyce51, EVL401, Sancho and 1 other person like this.
  22. Roothawg
    Roothawg
    You guys are harsh....
    williebill and OG lil E like this.
  23. Sancho
    Sancho
    It's true.
