large journal crankshaft
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Jul 7, 2013.
  1. 29moonshine
    29moonshine
    i have a 69 large journal 327 crank. what is the most that it can be turned with out having problems thanks
  2. seb fontana
    seb fontana
    from ct
    All the way to small bearing size block or until you can't find undersize bearings for the block you are using..
  3. gasserjohn
    gasserjohn
    real crankshaft re pair shops can turn/offset turn/weld it/re harden it /chrome it /plus many other ways i donot know about..........
  4. Deuces
    Deuces
    Is it a cast iron or forged steel crank????....
    Just curious.....:)
  5. racemad55
    racemad55
    Whatever you can buy for undersized bearings will determine how far you can get it turned.
  6. 29moonshine
    29moonshine
    forged
  7. Deuces
    Deuces
    If it is forged, all the journals could be welded and re-ground for standard size bearings....
