Technical Larger gas tanks
Discussion in 'Traditional Hot Rods' started by SnowmanII, Sep 10, 2014.
  1. SnowmanII
    SnowmanII
    from Minnesota
    I was looking at replacing my 40 gas tank which is junk anyway, with a 16 gal tank. Has anyone had one of these oversized tanks in there 40? They say it hangs an inch or so lower than stock tank. I don't see any issues other than maybe exhaust? Thanx
  2. Joe E
    Joe E
    I had a 35 coupe (same frame) and swapped out the gas tank for a larger unit. (Forget what brand). I had to cut my exhaust pipes off in front of the tank. ( dual pipes with straight pipes out the back). The tank was almost 2" lower.
  3. rottenleonard
    rottenleonard
    Can never have too much gas unless your on fire:confused:
  4. SnowmanII
    SnowmanII
    from Minnesota
    Good to know thanx!
