Technical LaSalle Ford Closed Drive Conversion
Discussion in 'The Hokey Ass Message Board' started by LS1, Jul 14, 2023.
  1. LS1
    LS1
    from us
    1. Maryland HAMBers
    I'm currently working on converting a side shift laSalle 3 speed to a ford closed drive as described in an old thread here:
    https://www.jalopyjournal.com/forum...onversion-courtesy-of-bruce-lancaster.408427/
    Now, my question is when you add the ford bearing retainer to the lasalle trans you lose the main shaft seal on the tailshaft, wouldn't that cause a trans leak issue? Maybe a sealed main shaft bearing is needed at the back of trans? Maybe I'm over thinking this.
    Thanks
    51 mercules likes this.
