Technical LaSalle trans to Buick
Discussion in 'The Hokey Ass Message Board' started by Justin in PA, May 4, 2020.
  1. Justin in PA
    Justin in PA
    So I have looked through the multiple LaSalle transmission threads and have not yet found the answer to my question. I started to do a conversion of a '37 Buick trans to open drive with a '53 Olds side shift donor. Along with these transmissions, I found what I believe to be a '36 LaSalle top loader transmission that is similar to the Buick. The biggest differences are that it doesn't have the bolt on throw out bearing snout and is open drive. I slid the '53 Olds bell housing on and the bolt pattern doesn't match up. What I did find, though, is a '53 - '56 Buick bell housing that matches up perfectly.
    Does anyone know how the input shaft of the LaSalle compares to what would be required for a '53 - '56 Buick 322 nail head? Has anyone ever used one of these LaSalles behind a nail head? It looks like a good solution to get a tough floor shift behind a Buick.
  2. I am using a LaSalle transmission with a 54 Nailhead coupled by a Speed Gems adapter plate.
