LaSalle transmissions - can anyone point me to an exploded view?
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Dec 19, 2006.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    I don't mean ****tered down the street - I'm looking for a technical drawing or diagram. I need to identify some parts.
    What I have isn't a top shift case - so that rules out a '37 I guess. But I think I might be missing a shifter fork? Is it even called a fork on a sideshift case? This thing came all the way from the Acehole himself with a box full of spares - but I can't figure out this one bit. I don't really understand sideshift boxes yet. And by the way, THANKS BOB - this thing is going to rule. I think I'm going to try to modify a Ford shifter to do the changing work. Sounds wierd... but I think I can do it.
    Expect me to go looking for a church parking lot once this thing is in a car.
  2. Andy
    Andy
    If you can find a diagram for a '50 olds box,It is the same. They are really tough to work on. There is a little br*** slug about an inch in dia. that fits in the 2/high shift fork. They are delicate. Don't ask. Do you have the front bearing retainer? A ford can be used. There is a snap ring that goes inside the 1st gear on the output shaft. Hope you have it. Best wishes.
  3. bobbleed
    bobbleed
    from Awesome
    hahaha its actually the electric company's parking lot.....
    Johnny just bought a couple ******s in pieces and they have box's of extra parts...... so if you are missing anything let me know and I'm sure we can come up with it....
    I would really like to see a diagram as well.... i have an open drive side shifter and I want to use a top loader case on it..
  4. plan9
    plan9
    is the lasalle box (both sideshift and toploader) stronger than a '39 ford toploader, or is it the gearing which is desirable?
    i vaguely recall that the sideshift gears are the same (physically) as the desirable '37 lasalle toploaders. i dunno much about transmissions in general.
  5. ProEnfo
    ProEnfo
    from Motown
    38-42
    CC
  6. 392_hemi
    392_hemi
    LaSalle box is way stronger than a Ford toploader. It's not even close. '38 and '39 gears will fit in a '37 case, but the case has to be machined slightly to make it work.
  7. Paul
    Paul
    Editor
    thanks for the pix ProEnfo
    I picked up a couple three side shifts completely dis***embeled
    and a nice rebuilt top shift unit recently...
    might be good to study a picture before trying to put one of the side shift jobs together.
    and, uh..
    technicaly the lasalle is a bottom loader.
  8. ProEnfo
    ProEnfo
    from Motown
    Top shift..
    CC..
  9. Paul
    Paul
    Editor
    here's the same picture scanned from my MoToR's auto repair manual
    this one with descriptors for some of the bits inside..
  10. ProEnfo
    ProEnfo
    from Motown
    Paul, I hope it helps, sorry for the quality...it's an old book.CC
  11. Paul
    Paul
    Editor
    here's a brief how-to out of an old little pages mag on converting the Cad to Ford tail behind an Olds..
  12. It has been MANY years since I tore into one of those gear boxes.The two things I remember most is:Have a GOOD set of snap ring pliers and use plenty of grease to keep the roller bearings from falling out of the shafts.Small hands help too as everything comes out from the bottom.
    When you do get it together,don't try and speed shift it from second to third or the shifter ****on will snap.Then it won't go into 3rd gear;well it will but it won't stay.Keep a few of those around.I used to keep a couple in the glove box.They were originally made of oil-lite bronze.They sold steel replacements but they weren't compatible with the slider and usually fried.I made a few from red br*** when I couldn't find originals and they seemed to work pretty well.Also seem to remember you could change those ****ons without completely dis***embling the trans but it was tricky to do on the road.Last time I worked on one of those was about 1963.
  13. Paul
    Paul
    Editor
    how much did they change year to year?
    how do you identify what year a transmission is?
    of the three I have I believe the top shift to be the '37
    the rest of the pile looks like enough to build a late one, '41 maybe?
    it has a m***ive output shaft, splined for a modern style U joint
    and another that looks like something in between,
    side shift like the late one
    and similar output shaft to the '37
    the third side shift case has been altered,
    a bit crudely, to take a Ford tailshaft
    like in the article above.
  14. Dirty2
    Dirty2
    Great thread . I might be needing this info..
  15. RocketDaemon
    RocketDaemon
    from Sweden
    i'm going to STEAL everything in here and add it to my olds post :D
  16. Rusty
    Rusty
    What was the last year a lasalle ****** was produced?
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It's a little hazy, but either '53 or '54, depending on who you listen to.
  18. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'm not sure when they decided that a 40 foot long tailshaft was the way to go. I know that '38 sideshifts still had the medium length tail like the '37 did. That may be what you've got, because I bought a sideshift that the owner alleged came out of a '39, and it's got the long tail.
  19. Dirty2
    Dirty2
    I'm getting a complet change over from a LOW milage 53 . Going to have to make a shifter of some sort.
  20. RocketDaemon
    RocketDaemon
    from Sweden
    actually i don't think they produced the lasalle ****** after 1948
    i'm basicly guessing or rather ***UMING, because, they was made for the flathead v8 originally... in 1949 the caddy and olds v8 ONLY had automatic... in 1950 they put out olds with lasalle ******, do not belive that many put together..
    basicly i belive all post 1949 are surplys ******s left from the 40ies,
    like the only caddys with manual was the he****s or ambulances (i rather belive it was merly almost only ambulances that had em, why need to shift fast with an he****?)
    wonder what the "excuse" for the olds 1950 tailshaft is though, and why that accordingly to heathen the bellhousing differs from caddy and olds aswell
    and the last year used should be 1953 or 1954, atleast 1954 should be the absolute last year used due to in 1955 that cadillac changed bellhousing pattern
    could of course be possible that they produced it later on then 1948 but read somehwere on an olds faq that they "raided partsbin from cadillac and lasalle" ... they should have reintroduced the ****** and strenghened the 2-3 shift so it became even more bulletproof...
  21. Kevin Lee
    Kevin Lee
    Super Moderator
    ProEnfo and Paul - Thanks for those pictures and articles. Huge help.
    I was looking at what I have again last night. First of all the size difference between one of these and a Ford is crazy. Everything is m***ive in comparison.
    So a close look and I think I'm missing the front shifter parts and whatever detent goes between it and the rear shifter arm. The story on this trans. is the case is busted - the whole front shifter bit is gone - just a hole there. But Bob hooked me with a spare case as well as a box full of gears, bearings, etc. So digging around I found what I think is a "shift ****on". But nothing else that makes sense in that space.
    Also missing the front bearing retainer - but I'm not sure exactly what happens here with the Ford conversion. It's possible that the adapter plate serves as the retainer and the Ford part (retainer) bolts to that?
  22. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Here's a tip for you, and everyone else with a sideshift Cad/LaSalle. Find an old Hurst floor shift conversion for a '55-'64 Chevy three speed. It's not that difficult to convert for use on these transmissions, and the early Chevy gearboxes used the clamp-on shift arms that you need for the Cad/LaSalle. I'm putting together some pictures of what's entailed as far as modifications go.
  23. bobbleed
    bobbleed
    from Awesome
    Thanks, for all the info.... yeah top shifter.... thats what I ment... haha
    I got a caddy motor from a 51 four door that was factory stick....the car was low milage and origional..... so they came in regular caddys as well.....
    Although that is the only factory stick 50's caddy I've ever seen...
    The caddy bell IS different as it dosen't have the mounting ears and is ribbed....
    The ****** itself is cool.... it is long, but open drive.
    I have two of those, one side shift closed drive, and then two top shift ******s....
    My plan is to convert one of the top shifters to open drive using the later caddy guts and tail shaft.
    And then I want to convert the other top shifter to use with a ford torque tube tail shaft....
    Is there a way I could get a photo copied version of that magazine Paul?
    I also have a couple crazy looking shifters for the side shift ******s...
    They look to use a ford top loader type shifter and mount on top of the ******.... they have these slide deals that hook onto the shifter arms of the ******.....
    I'll take pics...
  24. Paul
    Paul
    Editor
    sure, pm me your email address
    and I'll send tonight,
    or snail mail addy and I'll send a copy..
  25. Paul
    Paul
    Editor
    what's the better syncro?
    I have two styles, they look the same except
    one is bronze and the rest are aluminum.
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Do some research before you attempt to use the sideshift ge****t in the '37 case, as a couple of the old articles I've read mentioned some sort of modification being necessary to do so.
  27. The shift ****on - in a stocker - is an about 5/8" - 3/4" br*** ****on with a 3/16" - 1/4" grove in it.
    The ****on drops into a receptacle machined into the 2nd-high shift arm inside the case.
    CT Automotive - a famous North Hollywood speed/machine shop used to manufacture a steel ****on - and it could have been cast iron.
    The steel ****on cured the speed shifting blues of the br*** ****on, but didn't last as long on the street due to steel against steel - even with lotsa oil - wears faster than br*** against steel in the same well lubed situation.
    One thing you want to be careful of is using a floor shift conversion that does not have 2nd or high gear stops built in.
    I had a Hurst Mystery Shifter, an econo version of their regular three speed shifter.
    The Mystery Shifter did not have stops, but the regular shifter - a little more expensive - did.
    The MS shifter also had a removable round floor shift handle and the regular shifter had the flat bolt-on handle.
    Reason I point this out is the Cad-Lasalle boxes side shifter sticks out of a long cast piece.
    A few speed shifts and you can break the cast iron piece off the case.
    I did that at San Fernando dragstrip and damn near fell on the floor.
    Saved by a safety belt - lap style was all that was required then.
    After I got replacement main case from a circle track racing friend who'd stockpiled a bunch of them, I stuck my gears and stuff in the new case, built some stops for the shifter and no more probs.
    Get yourself a Hurst three speed shifter, make some new brackets for the shifter, bend up some 3/8" rods as necessary and the rest should be easy.
    Heim joints should work well here.
    If you have some hardened steel Hurst shift arms - trans end - that are close to what you need, but the rectangular holes are a touch small you can file them to shape by:
    Heat the arm to a moderate orange - as viewed in subdued light.
    Let it cool naturally.
    File as required.
    Heat the arm to moderate orange again and toss it into a bucket.
    That will harden the arm back to where it was.
    In fact it may harden the arm beyond where it was and the metallurgists on the board can tell us what's happening here and perhaps make a better recommendation, but I've done several of the Hurst shift arms this way and no problems down the road.
    As for the extra long tailshaft, I think it was done in an effort to get a shorter driveshaft or get the front U-joint beyond a crossmember.
    Far as bellhousings go, Olds had two different styles.
    49-51 I believe and 52 & up.
    The 49-51's take the Cad-Lasalle trans as a bolt on with no probs.
    The 52 & up has a different bolt pattern and you can bolt the 38 Buick trans to these.
    Course, then you have to set the Buick trans up for open driveline.
    And then there's the Ford clutch actuating arm that exits the bellhousing at a 30 degrees or so angle downward - when viewed from the rear.
    The Olds clutch actuating arm exits the bell housing level.
    Which makes for some interesting clutch linkage if you want to do it right, but that's another story.
  28. Kevin Lee
    Kevin Lee
    Super Moderator
    Yeah, I'm definitely missing that 2nd-high shift arm. Thanks for the added information with shifter arms and whatnot.
    Short on time here but I will say I saw that wierd shifter thing that Bob was talking about. Tuck had one similar and we were discussing adapting the Ford shifter.
    There was a picture in Rodder's Journal where someone did this (adapted a Ford toploader shifter to a sideshift with what I remember as some pretty cool linkage) - but I gave that issue away and can't remember specifics. It was the "ch***is" story.
    Pressed for time... I'll be back later.
  29. 392_hemi
    392_hemi
    Shift forks and bearing retainers are extremely difficult to find. The bearing retainer slips on the front and is held in place by the bellhousing. Since these aren't bolted on, most are lost in time. But you can modify a '39 Ford style bearing retainer to work. Shift forks are forgings and are almost impossible to find unless you salvage them from another trans. To fit the later gears in a '37 case, I believe you have to enlarge the countershaft holes, but I'm not positive on that. But I do know the gears will fit and work fine, and that some machining has to be done to make it work.
  30. Paul
    Paul
    Editor
    found another picture
    this one is of an Olds transmssion
    similar to Cad...
