History Late 30s Mopar coupes?
Discussion in 'Traditional Hot Rods' started by trevorsworth, Aug 6, 2025.
  1. trevorsworth
    trevorsworth
    Since I'll be turning my RPU back into a roadster soonish I won't have a hot rod truck anymore... unless... I looked at a 38 Dodge truck body today. No frame, but... a really nice cab, bunch of extra doors and fenders, two hoods, bed sides, and a few grille shells to choose from...
    I could get a 46-48 Ford frame pretty cheap and at first I thought it would work well - at a glance the critical dimensions are very similar to the Dodge truck frame - but I think it gets too fat too far forward to do what I was thinking. Maybe I'm better off looking for the right Dodge truck frame or building a custom frame.
    dwollam likes this.
  2. RodStRace
    RodStRace
    trevorsworth likes this.
  3. trevorsworth
    trevorsworth
    You forgot the drag coupe... :D
    I wanna really build one. Sid's car is more like a restoration. The T is my first, I learned a lot putting it together, and it's coming along well but I love it as is, it's daily driven, so I don't wanna just blow it apart and change it completely. Here's one where I'll have to really test the engineering and fabrication skills I've picked up.
    RodStRace likes this.
  4. gene-koning
    gene-koning
    The widest point on the Dodge truck frame is 36" on the outside, and that is under the pickup bed. The only place on the Ford frame that is under 36" wide (that point looks to be the firewall location to me) going forward, at the widest center location the Ford frame is 44" wide (probably at about the back of the cab, and that 44" isn't even the outside of the frame measurement). That Dodge cab is not going to fit on that Ford frame worth a hoot.
    Either find a Dodge frame, or build a custom frame.
  5. cfmvw
    cfmvw
    https://www.jalopyjournal.com/?p=62478
    This '36 Dodge has really good lines with the front wheels pushed forward and the nice chopped top.
    I also like the way this one looks with the rear axle moved back to center the tires better in the wheel wells - the black looks really nice! Taller tires help with the proportions, too.
    57Fury440 and trevorsworth like this.
  6. cfmvw
    cfmvw
    Found this fenderless '38 Chevy on the HAMB, a good example of pushing the axle forward to create the right proportions.
  7. cfmvw
    cfmvw
  8. choptop4
    choptop4
    38Dodge. Almost done.
    dwollam and cfmvw like this.
  9. cfmvw
    cfmvw
    I did a double-take on that rear view. Talk about a mirror finish!
  10. 57Fury440
    57Fury440
    The 38 Plymouth will look great with your ideas put into play. It will be a nice car without being another same old, same old. You have no idea how many idiots have come up to me over the years, asking why I didn't use a 57 Chevy.
  11. cfmvw
    cfmvw
    Found this one on the HAMB, looks like a '38 Dodge.
    caseywheels likes this.
