Technical late 8ba clutch stoopid question
Discussion in 'The Hokey Ass Message Board' started by nobby, Apr 15, 2023.
  1. nobby
    nobby
    hello,
    what I have at the moment is
    a 52/3 8ba with the flywheel with 6 equal drillings
    i have a 10 1/4'' clutch froiction disc ( its 23 splined)
    the matching pressure plate for the above.
    i have the half bell, a stamped steel version
    the stamped steel half bell hits the pressure plate - just at the holes fo rthe hogshead, the spring things tpouch and i cant get the half bell to sit.
    now, this is where its gets spooky......
    I once had a different 8ba with the similar flywheel - 6 equal spaced holes
    and I am sure I fit a v6 camaro pressure plate to it
    and I am certain that the friction disc was 9 5/8th or 241mm
    so the question is,,,,, is the flywheel for the v6 camaro drilled the same so a v8, with a 10''' or 10.5'' clutch ? even though the v6 is 9 5/8ths 241mm
    or, will i luck out using a 241mm 9 5/8ths camaro pressure plate - it missing the half bell.
    damn
    pic of v6 camaro clutch, the pressure plate appears to have a quite wide mounting foot - or if you like more than it should.
    so, instead of drilling the flywheel.........................
  2. 51504bat
    51504bat
    Stamped steel 1/2 bell will take a 10 inch clutch but not an 11 inch (need a cast iron one from a truck for 11 inch). So I'm guessing that your clutch is although not 11 inches is still too big. That said you either need a smaller diameter clutch or a cast iron 1/2 bell or at least that's how I see it.
  3. nobby
    nobby
    damn i have a cast half bell
    i though they were the same
    the clutch that touched is 10 1/4''
    260mm
    the 241mm clutch doesnt fit the drillings
    they do a 250mm clutch for 23 splines
    for the 45 pounds i will gamble
    i dont understand the cast half bell being any different?
    as the hogs head i have would be in the same place?
    do you mean the cast one piece bell house for the 11'' clutches?
    like the full bell for an 8ba, BUT for the big truck transmission
  4. nobby
    nobby
    its annoying
    as i first got the 11'' clutch as that i thought you had to igger about with the hogs head
    then got another 8ba with the borg and beck 6 equal drillings
    the other 8ba has a 9 inch flywheel on it.
    then found a 10 1/4 23 splined clutch so though that would work, but its a smidgers too wide.
    Borg & Beck Clutch Kit for Ford Transit 2.0 DI 2000-2006 250mm | eBay
    i think the 250mm ford ranger diesel is the puppy
    if it all comes in 5mm per side it will go in, and its 23 splined
    then they say they are 248mm
    ahh 248 is a ford ranger
    so, 250mm an 1/8th and a clicj under 10 inches 9 7/8's minus two hairs
    its all about the drillings and the physical shape to clear the mounting circle for the hogs headthe rivets in the 10 1/4 touch
    whats eben more frustrating is the trans has the earlier cross shaft for lhd model a, i have a 37 version, but its **** backwards for rhd, plus i sold the rhd 37 version in the old 3 speed, grrrrrrr, would have like to have kept the factory rivet through the actuating fork doofer.. ffs.
  5. 51504bat
    51504bat
    When I had my '40 Ford big truck with an 8ba it had an 11 inch clutch. The stamped steel 1/2 bell I had would allow the use of the 11 inch clutch. I bought a cast iron 1/2 bell from a truck and solved all my problems.
