Late Flathead Trans to Early Motor
Discussion in 'The Hokey Ass Message Board' started by The Wrong-Un, Jan 19, 2005.
  1. The Wrong-Un
    The Wrong-Un
    I've had a good look round but haven't managed to find an answer, so I'm hoping someone here may know. Is there (or was there ever) an adapter to put a later style Ford flathead V8 trans (49-53) onto an earlier flathead V8 motor?
    Thanks in advance, Neil.
  2. Farmer
    Farmer
  3. Bruce Lancaster
    Bruce Lancaster
    Lots of possibilities, probably all harder and more expensive than swapping for an early trans(ge****t is essentially same as '49 type).
    Easiest, but a rare part: Some late 1951 Mercs used late trans, '49-40 Merc type bellhousing (early Ford pattern), and a factory adaptor to go between the two, complete with clutch cross shaft. Someone posted a pic of this recently, but I can't find it. Perfect solution...but really scarce.
    There are modern adaptors that I think will do the job from Offy (requires 2 adaptors!) and "We're only '32" direct to Ford--both ways will cost more than swapping trans. If you have access to machine work, truck four speed bell or cut-off front from early trans can be adapted--again obviously harder and more costly than going to early trans.
    My thought: Either use early trans, or, if you go the adaptor route, go to a trans that's better than '50 Ford. If you are going to use an expensive adaptor and open drive, use the money and work to get a trans that is stronger and has more than three gears!
