Technical Later model rims for 47 Buick Super.. What will fit???
Discussion in 'The Hokey Ass Message Board' started by schreddr, Feb 7, 2015.
  1. schreddr
    schreddr
    from ND
    Does anyone know of a (Later) set of rims that will fit a 1947 Buick Super???
    Thanks.
  2. enjenjo
    enjenjo
    from swanton oh
    Buick to 1960
    schreddr likes this.
  3. I would think most any 5 on 5 in a 15" would clear everything.
  4. schreddr
    schreddr
    from ND
    Kewl.. Thank you.
  5. schreddr
    schreddr
    from ND
    Thank you.
  6. Squablow
    Squablow
    '47 is going to have locator pins on the hubs which will have to be ground off to put any later wheels onto it. Chevy Caprice and 2wd half ton Chevy pickup trucks all had the same 5 on 5" bolt pattern and would work to make the car a roller, although any later model wheels like that will be wider than the Buick's originals and may cause rubbing or clearance issues if you actually want to drive with them.
  7. 302GMC
    302GMC
    from Idaho
    The center hole in a Buick wheel is larger than any other 5 on 5'' '40s-'60s wheel. Try before you buy ....
  8. gotta watch that huge center hole on a buick/caddy wheel
  9. Hnstray
    Hnstray
    from Quincy, IL
    The locating pin unscrews from drum/hub....does not have to be ground or cut off.
    I have converted Buick hubs to wheel studs from wheel bolts. Dorman products has
    lots of wheel studs from which to choose. Best when pressed into place, not hammered.
    Ray
  10. my47buicksuper
    my47buicksuper
    from sunny fl.
    I have a set of Buick rims if your needing them , not sure if you need wheels or you just want newer rims
