Hot Rods Laycock de Normanville Model J—-O/D functions
Discussion in 'The Hokey Ass Message Board' started by Flatheadjohn47, Aug 28, 2024.
  1. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Anyone familiar with this O/D setup/ how it functions/ it is behind a Model A truck with synchronized 39 style Ford trans/does it have 1st low and 1st high and so on for all three speeds of the 39 box for 6 seperate speeds??? There is a solenoid looking apparatus on the back of the setup—-by the way the truck has a 12 volt system!! Only pics I have so far are pretty poor quality. Thanks John from Texas but in Lewes,De. To avoid the terrible hot summers. Thanks fellow HAMB members. Flatheads Forever!! Does the clutch need to be pushed in while changing the O/D to different positions?? IMG_0677.png IMG_0649.jpeg
    Ned Ludd likes this.
  2. AccurateMike
    AccurateMike
    I put one in a '65 Triumph Herald. I used the transmission from the donor too. The shifter had switches in it that only energize the OD circuit in 3rd & 4th. No 1st or 2nd OD. No clutch to use OD. Just hit the switch and the hydraulics do the shifting. Up or Down. You don't really need to let up either. Your trans probably lacks the low gear lock out/s and OD will work in all gears. I don't know if I would do any full throttle 1stOD shifting. They probably locked out low gear OD for a reason on OEM applications. This is my 2nd car with one. You will love the electric/hydraulic shifts. Mike
  3. BJR
    BJR
    They came as an option on AMC Gremlins.
  4. squirrel
    the Gear Vendors overdrive is built from the same design.
    The way it works, there's an oil pump inside, and the pump needs to build pressure before it will shift into OD. So the driveshaft needs to be turning at a significant speed, perhaps 30 mph, before you energize the solenoid.
    And if you energize the solenoid when it's in reverse, you'll break it, so make sure that can't happen.
    Energize the solenoid, while the car is moving at speed, it doesn't care what gear the transmission is in...it will shift into OD. De energize the solenoid, it will shift out of OD.
    Ned Ludd and BJR like this.
  5. Ned Ludd
    Ned Ludd
    The basic design can handle a much higher operating pressure than LdN originally intended. That is probably the most important aspect in which the GV unit is different. The torque capacity depends on the operating pressure. All it requires, apparently, is a modification to the internal hydraulic pump's pressure regulating valving. That same valving would regulate an external hydraulic pressure source, should you wish to go there.
    Hypothetically it should be possible to operate the unit directly via a linkage instead of the solenoid. That would change the slightly whenever-you're-ready engagement quality to a right-now! engagement quality, like on a manual gearbox. But that would complicate rigging a reverse-lockout feature.
  6. Hellfish
    Hellfish
    They are common in European cars (Jaguar, Volvo, etc). I have one in my Jaguar. Electric solenoid kicks it in and you can do it in every gear, I think
  7. AccurateMike
    AccurateMike
    Look at Mopar 42 RH/RE & 46 RH/RE's, they had big units, some with 6 pinion planetary. I think this is the source of the GV.
  8. Oneball
    Oneball
    You don’t have to use the clutch but a little lift of the throttle is best as you flick the switch, with a bit of practice it becomes seamless. The 1/2 cutout is often byp***ed on compe***ion cars and with a switch on the gear lever itself it’s easy to have 8 gears. But in normal use I’ve only ever really used them in top.
    Ned Ludd and 41 GMC K-18 like this.
  9. squirrel
    I don't think so....the source of the GV is that funny sounding British/French name he mentioned.
  10. Oneball
    Oneball
    Lay**** is the British company that made them originally to a design by Edgar de Normanville who was actually British too. He also invented those circular wizzy things that act as windscreen wipers on some boats.
    squirrel and Ned Ludd like this.
  11. AccurateMike
    AccurateMike
    The one in my buddy's Grand Cherokee sure looked like the ones in my MGB & Triumph. Always made me wonder. I think they are Lay**** with big pumps and such.
  12. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Thanks for everyone’s input/now I have a “starting” point to try and learn from—-appreciate the various inputs!!! IMG_0333.jpeg IMG_0678.jpeg IMG_0483.jpeg
    SS327 likes this.
  13. deucemac
    deucemac
    I have one in my avatar roadster. It was a factory option on 75-77 Pacers, Gremlins, and Hornets. They came attached to a Ford full synchro 3 speed. I took mine and removed all the side shift linkage and added a Jeep T150 top shifter. The original side shift setup had a switch on the 2-3 shift rail that prevented engagement unless the trans was in 3rd gear. All that went away when converted to the Jeep top shifter. I just installed a lighted rocker switch on my dash to turn the solenoid on and off. Works great and the light in the switch reminds me to turn off the o/d solenoid when going into reverse or starting off in 1st. It's been that way since 2009 when I first put the car on the road and has worked flawlessly ever since.
    rod1 and AccurateMike like this.
