Leaf Reversal
Discussion in 'The Hokey Ass Message Board' started by Darwin, Oct 2, 2003.
  1. Darwin
    Darwin
    Heard about an old rodder's trick for achieving a reversed eye front spring. The pack is disassmbled, the main leaf is flipped, and the whole thing is drawn back together resulting in a somewhat de-arched pack with reversed eyes. Anybody have a guess at just how much this would lessen the arch of a typical Model A spring?
  2. Dago Red
    Dago Red
    from Delaware
    I think the typical drop is between 1 and 2 inches. You might want to track down Mart, who put together a simple tool that makes the job a lot easier.
  3. Elrusto
    Elrusto
    I tried that and the lower leaf did some funny***** after I put it back together. It didnt lay flat against the other springs.
  4. Dago Red
    Dago Red
    from Delaware
    Elrusto,
    That's where Mart's tool comes in handy. Instead of just flipping the mail leaf over and clamping the whole thing back together, the Mart-O-Matic uses a bench vise to reverse the arch. That way it matches the rest of the spring pack. You can also reverse the arch with a BFH, but it's noisy and a lot of work.
    FWIW, I've also heard that springs reversed in this manner may eventually try to return to their original arch.
  5. manyolcars
    manyolcars
    The spring shop that makes reversed eye springs here, makes them 1 inch shorter. The guy is about 70 yrs old and was a hotrodder long ago.
  6. NealinCA
    NealinCA
    I copied the "Mart-O-Matic" and have reversed the eyes on a couple of model A springs. It seems to work fine.
    Here is a sketch of the dies you use in you BIG vise.
    Neal
  7. NealinCA
    NealinCA
    And as viewed from the side...
  8. Elrusto
    Elrusto
    Ahhhhhh I seeeeee!!!! Mucho Groceries me amigo. Ill have to give that a shot!
  9. k-member
    k-member
    I totally understand the concept but,is it just me or should'nt the main leaf in the first pic be turned 180 to reverse the eyes. Like the spring eyes should be on top as the vise compresses to reverse the arch. It looks like it is going to arch it in the stock shape.
  10. DrJ
    DrJ
    [ QUOTE ]
    [/ QUOTE ]
    Yes
    i don't think I'd put any force bending directly over or even near the center hole since it's gotta be a weak point, it might "kink" and crack there.
  11. Kevin Lee
    Kevin Lee
    Super Moderator
    The tool in question....This is just a nancy-boy display version of Mart's original tool I had fun making and coined the term "martomatic".
    Mine works well, but Mart's original was far more paractical with tabs to bend around and hold it to the vice. I had planned to drill a couple holes and bolt it directly to the jaws, but gave it away before that happened.
    Hey Mart, didn't you fashion some goofy thing out of coat hangars to find TDC on your flathead? I was going to do the next piece in the marto series but read about a stupid simple way B Navarro uses to find TDC. Send me a picture anyway if you would though. Sometimes I need a break in the garage and want to do something goofy.
