Leaf Spring / Axle Questions
Discussion in 'The Hokey Ass Message Board' started by Voh, Feb 28, 2008.
  1. Voh
    Voh
    LEAF SPINRGS: Can anyone give me a good source for getting new leaf springs or ideas on what I should do to correct the "Too Low" Situation I have created. I installled reversed eye mono leafs on the front for my '64 F100 and now I am into the bumpstops too easily. I have looked at purchasing new F100 leafs, but $299 ea seems little high (yes I got rid of the originals too soon). Where could i get a more common leaf to that truck?
    AXLE: Second question, with raising the truck back up a bit, I would still like it to stay low. I had been watching the 3" dropped axles from speedway on occasion, but last night noticed that they were discontinued. Any thoughts on lowering it back down? Should I just bite the bullet and start saving for an IFS install?
  2. scottybaccus
    scottybaccus
    Look in the yellow pages for your local spring and axle service. They will probably be big truck oriented. They can measure your set up and rearch what you have or replace them with new ones to spec.
    You may be able to have the stock axle dropped to suit. Look around at roadsters.com.
  3. 50dodge4x4
    50dodge4x4
    My first thought was "can't you just flip the leaf spring upside down?" That should un-reverse the reversed eye springs, and should gain you back a couple inches. Gene
  4. Voh
    Voh
    I am pretty sure that there is some arc in it. it would actually put the axle closer to the frame.
  5. Voh
    Voh
    FYI - This is the front straight axle if i wasnt clear.
  6. duke182
    duke182
    try looking in HEMMINGS MOTOR NEWS for EATON SPRINGS. they should be able to fix you up.
    other wise hit the junk yards, or consider c- notching and boxing the frame for clearance and strenght.
  7. junkyardroad
    junkyardroad
    from Colorado
    Alcan Spring in Grand Junction, CO made a really nice set for my '54 f2. They will pretty much do anything you want. Maybe ask if they can add arch to your existing set first. Very easy to deal with. Eaton made a set for me once, very easy to work with also.
  8. sho1off
    sho1off
    from Buffalo MN
    "to low"????? they are never to low almost always to High
    cut out or remove the bump stops that should give you and inch or two
  9. A spring shop could modify original springs to a point. Don't attempt to have the monoleaf springs rearched or modified. Tapered leaf and monoleaf springs make a weird sound in the arching press during failure/flight action. It's best to have a good wall between you and that sound. Trust me.
  10. Voh
    Voh
    It is not too low from an appearance standpoint, actually i would like a couple more in the front. I just went about it the wrongy and need to correct it so that i can be driven more then 30 mph.
  11. Voh
    Voh
    My current troubles are on the front axle - I do plan to c-notch the rear.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Why not notch the frame above the front axle much like some of us do with the deuces?
    We do it for spring clearence but I don't know you couldn't do the same for axle clearence,,HRP
  13. Shellback
    Shellback
    from SoCal
    Just curious. How do the mono leafs ride? Is it a spongey boucy ride in the rear?
  14. Voh
    Voh
    I have the monos on the front. If i were to do it again, i would not. They ride fine (After i bought them i heard the few stories about them failing - it all you have when it goes, all hell breaks loose)
  15. Voh
    Voh
    the front leaf springs run directly under the frame rail. I dont think the notch would help. If they were located as they are in the rear (outbound of the rails) then yes a notch would start to solve the problem.
