1952-59 Ford Leaf spring lowering Tech
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Jul 18, 2020.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. 56FORD390
    56FORD390
    Thank you for this article. One question though, there seems to be a shim under the block, I ***ume to correct the pinion angle? Is that correct and are those shims available?
    JeffB2 likes this.
  3. TomDobbs
    TomDobbs
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. guthriesmith
    guthriesmith
    Those adjustable pin blocks are pretty cool. I was just considering making a set with offset pin locations to do the same thing (and also in a Chevy...but don’t tell anyone here.) :D
  6. TomDobbs
    TomDobbs
    I use 'em on my Merc. When I got the car it had standard run of the mill 3" blocks that were too narrow and wouldn't stay put, letting the axle squirm. I could not tighten the u-bolt nuts enough to keep 'em in place. I switched to 2" adjustable blocks and have had no issues since.
    guthriesmith likes this.
  7. Black Wagoon
    Black Wagoon
    Too bad the author didn't mention the shim blocks, but I guess that wouldn't opened another whole subject to delve into.
    I do wish he would be shown a better Side Pic of the finished result. Not really able to see results from a 3/4 side view.
    I wish these blocks would've been around 30yrs ago. I had a 2" dropped front axle on my 56 F100.
    The lower the F100 sits, the more accentuated the off-centered wheel is vs wheel opening.
    I think a 2" push Forward would've made a big difference in looks.
    Sent from my KFDOWI using The H.A.M.B. mobile app
