Technical leaky flathead
Discussion in 'The Hokey Ass Message Board' started by flathead 37, Dec 22, 2014.
  1. flathead 37
    flathead 37
    so I got a set of high compression heads for my flatty a while ago, and threw them on and now its leaking water. so I picked up some new gaskets, and I was wondering if there is any sort of gasket sealer I should put on there?
  2. King ford
    King ford
    from 08302
    I always use k+w coppercoat....several coats...also if it has head bolts instead of studs put high temp tv on the threads
  3. Jalopy Joker
    Jalopy Joker
    so, did you have the heads checked before you put them on ?
  4. flathead 37
    flathead 37
    the heads are brand new repros
  5. prpmmp
    prpmmp
    I remember reading on here that if you use just water for a while it will rust up the threads and stop leaking! It worked for me(I have studs) Pete
  6. flat 39
    flat 39
    Where is it leaking? Did you put sealer (permetex #2) on the head bolts/studs?
  7. BLUDICE
    BLUDICE
    need more info - early or late FH, where are the leaks, did you check the new heads out first - even new ones can be warped!!
  8. rusty rocket
    rusty rocket
    Mine leaked around the studs at first. I resealed and tourqed everything and have never had a problem since.
  9. A Duece Bruce
    A Duece Bruce
    X2 on the coppercoat. and the new black gaskets. Make sure they line up with all the holes in the water jacket of the heads and the block. I have studs and used clear rv silicone on the threads and washers and nuts. A thin coat is pretty invisible and has kept the nuts and washers from rusting. no leaks. happy motoring
