Projects Leaky Stromberg odd problem odd solution
Discussion in 'The Hokey Ass Message Board' started by strait8, Feb 27, 2018.
  1. strait8
    strait8
    from Skokie, IL
    I have had a leak on my Stromberg that I have been trying to get stopped for some time now. It leaked at the site plug. Or so I thought. I tried tightening it. I tried using all sorts of different sealants and even . I was about to go the route of a thread locker or a different carb but then looked closer. Midline of the sight plug is a casting seam. As I looked more closely I watched the leak with a flashlight and after wiping the area with a rag and seeing the slow flash of the gasoline as it creeped and expanded it dawned on me that maybe there was a hairline crack at that casting line. So I tried a product used for fuel tank repair. An epoxy. I mixed a small bit of it up about the size of a copper BB. Then smeared it against the carb pressing it into the seam where I thought the crack might be and voila it stopped almost immediately! Thought I would share. IMAG2182[1].jpg IMAG2184[1].jpg
    Blue One and Petejoe like this.
  2. 41rodderz
    41rodderz
    from Oregon
    Always like the tech posts on here . Thanks
  3. Fortunateson
    Fortunateson
    Well that must be the stuff to use, I can't even see the repair.
    Kiwi 4d likes this.
  4. Kiwi 4d
    Kiwi 4d
    Can you circle the repair so my dim old eyes can see it?
  5. strait8
    strait8
    from Skokie, IL
    Truly sorry didn't really think it was that "technical".....I still don't really get the criteria and should probably re-acquaint myself with them.
    Even if I circled the repair you would not see it. Hell I cannot even say that I could see the crack. It was a hunch. The repair is on the right side of the vertical seam below the sight plug screw. The amount that I smeared in cannot even be seen but the results were awesome. I just wanted to show the casting line in case someone might be experiencing and chasing the same mystery leak that I have been.
