LED charging light help
Discussion in 'Off Topic Hot Rods & Customs' started by topher5150, Feb 2, 2026.
  1. topher5150
    topher5150
    Trying to keep this simple I'm using a Ford 3G alternator on my build and a LED idiot light. Someone suggested that I use a relay to act like a resistor. Just wondering if anyone help how that gets wired togehter.
  2. squirrel
    connect the coil of the relay to the two wires that would connect to the light bulb. Then connect the LED to the NO contact on the relay, and connect power to the COM contact.
    I would use a light bulb, because that's what it's designed to have. You could put the light bulb anywhere hidden, and you might even be able to connect the LED across the bulb so you have an indicator that the bulb is lit.
    LEDs are great for many things, but old cars is not one of them.
    SS327 and leon bee like this.
  3. topher5150
    topher5150
    85, and 86 from the green alternator wire
    87 NO, 30 COMM to the LED
  4. Damon777
    Damon777
    I am in a similar situation with my 10si. My issue is actually finding an incandescent indicator.
    If a guy wired an LED and a standard bulb in, I would think that the LED would need to be in series with the light bulb, as the LED would provide a path of zero resistance if wired parallel, correct? Granted, it should work parallel if you got the polarity on the diode right.
  5. leon bee
    leon bee
    Cycle parts places have a lot of different little indicator lights.
  6. Damon777
    Damon777
    The overwhelming majority of them are LED.
    I found some on Amazon if I really get to that point. I just put a switch in that circuit and manually shut down for now.
    leon bee likes this.
  7. mustangsix
    mustangsix
    I put a 1k ohm resistor across the LED leads. That seems to work for me.
    topher5150 likes this.
  8. topher5150
    topher5150
    Is there a more of a plug n play version of this?
  9. Damon777
    Damon777
    Just the resistor would work, so long as you don't need the indicator.
  10. squirrel
    it's about as basic as electronics gets.
    But pretty hard for most folks to deal with, I guess.
    I would pull out my little draw of resistors that I bought at Radio Shack several years ago, get one of the Brown-Black-Red resistors off of it's tape, and then wrap the ends around the wires that attach the LED to whatever it's attached to, solder them, cut off the excess, and be done.
    If you didn't have the foresight to buy those resistors while Radio Shack was still around, you'll probably have to use the internet to get one.
    SS327 and TrailerTrashToo like this.
