LED flasher
Discussion in 'The Hokey Ass Message Board' started by Fourdy, Dec 13, 2010.
  1. Fourdy
    Fourdy
    Has anyone converted to LED taillights and replaced the flasher to make them work? If so, can you give me the info on the flasher you used such as number or model? I have a 2 prong unit. Napa guys say that they are not electricians so they have no idea which one I need. It is my understanding that just because it says "electronic" doesn't mean they will work with LEDs.
    Apparently I need a two prong electronic unit with a ground pigtail or use a 3 prong unit and make up a pigtail to be able to ground the 3rd spade?????
    Any help will be greatly appreciated.
    Frustrated - - -
    Fourdy
    Merry Christmas and Happy New Year
  2. Gator
    Gator
    I don't have anything with LED's but just had to help a street rodder buddy with the same problem.
    Since LED's require such little current to operate a normal type flasher usually won't work properly.
    You need what is called a 'no load' flasher, it's electronic and doesn't depend on current draw to operate.
    I know Summit sells one for $10, part # FF552NLF
  3. jmh
    jmh
    I got my flasher from Ron Francis.. Works great.. John
  4. refried confusion
    refried confusion
    ___________
  5. NINE INCH
    NINE INCH
    I've changed most of mine. Napa...Sheez. Try the Poulsbo store. Ask for Bill or Dick. They have had all mine in stock. 9"
  6. lostforawhile
    lostforawhile
    Blazer EF-32, it's a two prong, power in, load out. most auto parts stores have them, the basic circuit works as battery power in to one terminal the other would go through the turn signal switch and when connected to either the left or right circuit that completes the circuit through the bulb. it doesn't require a ground, current flowing through the flasher completes the circuit.
  7. lostforawhile
    lostforawhile
    I used this flasher mentioned above to flash a single warning LED in my center console, and it works just fine. I think it was around 8 bucks off of the shelf
  8. We have them in stock sell them for 15.00 w/free shipping
  9. Fourdy
    Fourdy
    Thanks to all of you.
    I have a 12v system with the small chrome bodied lights hidden behind my grill for front turn and park lights. They probably don't use much amperage each. I replace the taillights with the LED lights designed for the 40 ford.
    I just ordered three 2 prong with pigtail units for my 40, my 24T and a spare. I find if I have a spare, I rarely need to use them. lol
    I will let you know how they work when I get it set up.
    Merry Christmas
    Fourdy
  10. garcoal
    garcoal
    a standard flasher is nothing but a circuit breaker, when enough load they break the circuit. and they can be over or under loaded. and they wont work right. a led flasher is not load dependent. thats why they hav 3 wires power in power out and a ground when you present power they just turn on and off. thats why you need a ground. they will work with 1 light or 50 lights. i sell them at the kenworth dealer i work at all of the time. dont over do analzing this problem its already been solved . just use the right flasher for your car
  11. lostforawhile
    lostforawhile
    these electronic flashers like the one i mentioned also don't need a ground, the blazer one i mentioned is operating one LED warning lamp and it works jut fine
  12. Sprout
    Sprout
  13. fordor41
    fordor41
    I have LED taillights and use a hazzard warning flasher. They will flash any and all good bulbs and don't rely on amp draw as a turn signal flasher.
  14. funk 49
    funk 49
    deal with this at work alot. if not enough draw-no flash. Listen to Kelly and do the simple fix.
  15. patrod
    patrod
    from idaho
    Install a ballast resistor in line, and just use a ordinary flasher.
  16. cryobug
    cryobug
    When using a electronic flasher you have to make sure that the terminal marked X is the hot side. A regular flasher is not polarity sensitive but electronic ones are.
