LED Headlamps
Discussion in 'Off Topic Hot Rods & Customs' started by hot4hotrods, Aug 18, 2025.
  1. hot4hotrods
    hot4hotrods
    from U.K
    I've bought some of these style
    https://ebay.us/m/oVTHfz
    LED's to replace my old sealed beams on my 58 Buick, but have found they dont fit the lamp bucket due to the back of the LED's being too big and square, has anybody had any luck modifying the old Buick buckets? Is there a kit to buy that allows them to be fitted?
  2. 19Eddy30
    19Eddy30
    from VA
    Try Holley Look Original, they make some seal beam that are Led , they are few hundred thoe.
    Cut hole in Original bucket?
    Modification below is for non-seal beam.
    Some others are going to Junk yards /pick apart getting Led head light , ***emblies / bucket's
    Cutting out the back side of where bub is on the donor head light ( hole saw)
    Then adapting to a Original bucket with glue /panel adhesive,
    afew month ago there was a thread
    Here On how the HAMBer modified
  3. Turns
    Turns
  4. Damon777
    Damon777
    Can't help you with that style, but I have Hella H4 conversion lamps in my 50. They fit without modification to the buckets, and H4 LEDs are available to be swapped in.
    We did a similar Octane halogen conversion on my son's 70 Catalina. They also worked without modification to the bucket.
    gimpyshotrods and Mr48chev like this.
  5. squirrel
    I tried some cheap LED lights, they didn't work very well...poor fit (they had the clocking wrong), and the light pattern was awful. I got some of the Holley lights, they're pretty expensive, but they work well and fit without any issues.
    this in my 62 Corvette. GM generally used the same buckets for all the 58-newer 4 light systems.
  6. Greg Getz
    Greg Getz
    I put the Holley lamps in my 57 and they work great. They are spendy, but don't look out of place.
  7. rockable
    rockable
    squirrel likes this.
  8. squirrel
    neat. I ordered a pair of rectangular ones from Summit for Cheep (which probably is against Cheep policy?) and will see how they work.
    41 GMC K-18 and rockable like this.
  9. 65pacecar
    65pacecar
    from KY, AZ
    Running Holleys in the Sport Fury and Road Runner, great fit and no issues, excellent lighting.
  10. rockable
    rockable
    Let me know how they work out. I may order a pair for my Sedan Delivery.
  11. squirrel
    I got the summit brand LED headlights for Cheep today. They are the rectangular style. There is a divider in the middle, the top and bottom halves are separate. The reflector is also a separate plastic piece, it does not use the gl*** shell as the reflector. There is a cable to connect the plug, not just terminals.
    Here are a few pictures. One installed so far. I'm waiting for it to get dark and go for a drive.
    41 GMC K-18, rockable and pprather like this.
  12. squirrel
    Low and high beam. The beam is very centered, not spread out like it should be...
    this is with the LED light only on the p*** side still.
    but its not really dark yet, still waiting to see how it works.
  13. gimpyshotrods
    gimpyshotrods
    I run those.
  14. 19Eddy30
    19Eddy30
    from VA
    If you do not like , are they refundable?
    After driving many old cars I found weird to get use to the Narrow Horizontal beam , Not enough vertical horizon, like over driving light beam.
    Around 80mph .they are bright thoe.
    Holley does not have this Issue for me.
  15. squirrel
    It got dark, so I drove around more...did some adjusting, installed the other headlight, drove more, more adjusting, and in the end I'm happy with them. I wouldn't like to be the guy in front of me, though. I probably need to aim them back down just a bit.
    Low beams in my driveway.
    High beams, while moving, so the image is weird. It lights up the road a long way ahead.
    Again, these are the Summit brand 5x7 rectangular LED headlights,
    https://www.summitracing.com/parts/SUM-RP22678
    not the Holleys.
  16. 19Eddy30
    19Eddy30
    from VA
    @squirrel
    What you think compared
    To Holley in Vett
    To the Summit Brand ?
    I see many after market Led
    On low beam are bright , Focus beam in
    Eyes as Vehicle moves toward from 300 feet away or more coming towards you ,
    Hard to see , do not know if installer do not know there Blinding on comers
    Or just bad Focus beam in relationship to flutes, Im out dayley after dark.
    2-4 lane oncoming traffic.
  17. rockable
    rockable
    Polycarbonate lens or gl***?
  18. squirrel
    The Summit lights claim to be a gl*** lens, and they look like it.
    Both the Holley and Summit lights work well. Neither one looks quite like the original lights--the Holley has the wrong shape lens, it's too flat, while the Summit has weird looking insides, although they're not real noticeable compared to many other LED headlights.
  19. proartguy
    proartguy
    from Sparks, NV
    Not quire the same configuration, but I put focused LEDs in my ‘34 and they are a big improvement as well as a lot less current draw on the 6 volt system.
  20. hot4hotrods
    hot4hotrods
    from U.K
    Wow these look amazing
  21. hot4hotrods
    hot4hotrods
    from U.K
    I bought one of these, but in chrome, they sell them seperately, really cheap, so I bought one and will see how it fits. Even modifying the buckets wouldnt work, and the originals are sealed beams , so I cannot even change the bulbs to the H4 LED's. I'll see how it fits with this holder and report back.
