LED lights problem
Discussion in 'Off Topic Hot Rods & Customs' started by mixerman, Aug 2, 2025.
  1. mixerman
    mixerman
    I install a complete electrical system in my 33.
    1) Fuse panel with complete wiring
    2) LED rear tail /stop lights w/3rd brake light
    3) LED front blinkers run / turn signal
    4) LED flashers - e-flasher and turn signal flasher
    The lights on the rear work perfect with LED flasher
    The front LED blinkers work also with light switch off except, when I pull the light switch to the first position for park/running lights, the dash blinker indicater lights come on and when I activate either blinker the blinker works but the indicator light just dims and never goes completely off.
    So I bought some incandescent blinker ***enblies and hook them up and everything works perfect. I just figure what could be going on with the led blinker ***emblies.
    The only other think I haven't done is install LED load diode on each light, I'd do that if I was for sure it would fix my plrblem.
    Thanks in advance
    Doublepumper likes this.
  2. 19Eddy30
    19Eddy30
    from VA
    These two pic might help you out ,working & to Study ..
    I have use this wiring a few time's
    With ""all Leds "", & 3 wire / terminal
    Led flasher , 3rd terminal is a ground
    On flasher.
    2 plug Flasher
    If just Led's ""On Rear "" then wire as
    Pic shows, Condensed bulbs on front
    & Led rear , wire as pic shows
    Bottom pic is Gm switch
    With Running just "On " in Running light
    Position pre 69
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    I had to add resistors, even with the electronic (LED) flasher unit. The rear LED lights would work fine, but once the fronts were installed, the flasher wouldn't work with all four. I installed a different electronic flasher and had the same issue, so added the resistors and lights have worked fine since.
    Don't know if that's your problem, but thought I'd share my LED light story. Good luck!
  4. BJR
    BJR
    Where did you get the resistors and what value are they?
  5. mixerman
    mixerman
    Did you add the resistors just to the front only or rears also?
  6. d2_willys
    d2_willys
    from Kansas
    It all depends on how the dash indicators are wired. Your 33 is what brand name? I say this as I have a 59 Olds with a strange way of grounding the indicators. What they did was to use the opposite front turn signal to ground the indicator showing the intended turn direction. What ended up happening was with a 3 prong flasher (for incandescent bulbs), the center prong is used to provide flashing 12v to the indicator. But most 3 prong flashers have the center prong active when the L prong (for the signals themselves) is inactive. With this, both indicators iluminate at the same time, because of difference between the center and the L prongs. Now in your case, it sounds similar. I would check the indicators and how they are wired.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the off topic forum
    hrm2k likes this.
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    They are six ohm, fifty watt resistors. I found them on Ebay.
    Added to the front, as it was easier to access the wiring and mount the resistors. Two resistors, one for right signal light circuit and one for the left light circuit.
    BJR likes this.
  9. mixerman
    mixerman
    The wiring harness is from "Hotrodwires" the flashers are two prongs. I replaced the e-flashers with a led replacement and they work perfect. I replaced the turn signal flasher with a two prong with a third ground wire and got them to flash, but I'm getting a crossfeed thru the led dash blinker indicator lights. I just got thru reading where if you replace your incandescent blinker indicators with leds you need to add a diode to the indicators to prevent a crossfeed.
    I have a set of incandescent blinker ***emblies that I wired up and everything works perfect, so I ***ume wiring is correct.
  10. mixerman
    mixerman
    Thanks, I wasn't sure where to put it....thanks again
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    In the future if it wasn’t around in 1965 post it in off topic
  12. mustangsix
    mustangsix
    I would also check to make sure you have good grounds on those lamp housings. LEDs do odd things that incandescent lamps don't because they will react to very low current.
