left key on and now no start
Discussion in 'The Hokey Ass Message Board' started by noxided, Jan 21, 2011.
  1. noxided
    noxided
    i left the key on yesterday on my stude and now it wont start. i replced the coil, points and concesor and still no start. nothing else appears to be damaged/melted so what should i do?
  2. Master of None
    Master of None
    Get your muliti meter out and check the voltage to the switch and from the switch to the coil.
  3. big creep
    big creep
    did you check if the batt is dead?
  4. Rock Island Rocket
    Rock Island Rocket
    Is the engine turning over with the starter but just not firing?
  5. T Fritz
    T Fritz
    No spark? or no fuel?
    Check for power at the coil with the key on. Can always try a jumper wire to the coil.
    Use a test light hooked to the positive on the battery and the wire for the points to see if the points are opening and closeing properly. Unhook that wire from the coil when you do that test. Check the coil for output by pulling the coil wire off and using a screwdriver in the wire boot see if spark jumps to ground when the engine is turned over.
  6. Paul
    Paul
    Editor
    that cracked me up
    test lamp or volt meter at coil show full voltage when switch is on?
    is the connection at the resistor byb*** lug on the starter clean and solid?
    try turning the ignition on with the cap off and points closed,
    open the points with a screwdriver a few times till you see a spark
    sometimes just doing that will get the juice flowing
  7. sawbuck
    sawbuck
    from 06492 ct
    ballast resistor ???
  8. noxided
    noxided
    battery is good, it will turn over, getting fuel just no spark, in the moring ill start checking it all out a little better cuz its already dark here. thanks guys ill update tomorrow.
  9. rustyford40
    rustyford40
    from Mass Bay
    You might have burnt the points
  10. big creep
    big creep
    you never know? nothing surprises me anymore!
  11. RichG
    RichG
    x2.
  12. F&J
    F&J
    If the ballast was bad, it should still start but then die when the key is released.
  13. lonestarluck
    lonestarluck
    I've seen a coil get so hot it's bursts when the key is left in the on position without the motor running. Haha
  14. burnin53
    burnin53
    from cuba,n.y.
    Yes,probably fried the points.
  15. big creep
    big creep
    get a pertronix II setup, it has an auto shut off if you leave the key on, and you cant see it under the cap so it looks like a point setup. but if you like to keep it old school, just ignore what i say.
  16. Roadsir
    Roadsir
    He stated he replaced the points....Did you set the point after replacing?
  17. noxided
    noxided
    ive got new points and a new coil that has an internal ballast resistor. ford 302 1975 f150
  18. burnin53
    burnin53
    from cuba,n.y.
    Must have skipped the part where you said you replaced the points.
    I have seen points installed incorrectly with the battery + and /or condensor attatched on the wrong side of the insulator bushing on the stud.
    This would ground the primary ignition circuit before it gets to your points,causing no spark.
    Would only take a minute to double check this..
  19. noxided
    noxided
    ok, i tested the coil, switch and distributor and everyting is good. And now it starts. i Fiddled around with it today after replacing the point, condensor and coil and now it works, but it did not yesterday, so i dont know why it wanted to work today but all that matters is that it did. thanks for the help guys.
  20. J. A. Miller
    J. A. Miller
    from Central NY
    Ignition gremlins like to **** with people.
  21. willowbilly3
    willowbilly3
    from Sturgis
    I know that's what's usually wrong when my car won't start.
