leg problem = automatic transmission
Discussion in 'The Hokey Ass Message Board' started by worn shoes, Feb 8, 2008.
  1. worn shoes
    worn shoes
    Does anyone know of any type of automatic transmission that will work behind a Model A motor?
  2. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I dunno man, but if your avatar is your car, that shoebox rocks!!!
  3. They make C4 kits. Supplied by who? I don't know.
  4. Bruce Lancaster
    Bruce Lancaster
    I think two kits exist, Chevy and Torqueflite, plus I suspect you could find a way to use Flatomatic with an A-V8 adaptor kit. I think the Chevy kit is full developed, other ways are just adaptor and youfiggeroutthedetails.
    I wonder how NSU did the automatic clutch on the Ro-80...I drove one of those once, I think it was a conventional 4 speed, but no clutch pedal. Touching the shiftknob worked a switch, and presto, disengage. I found myself mysteriously slowing down once, and saw the tach on like 8,000...my knee was resting against the knob! The engineer was NOT pleased.
  5. jetmek
    jetmek
    i seem to recall an article done on a c-4 conversion and the results were unimpressive supposedly due to the extra power rqrd to run an auto transmission. it took like 10 or more hp to run it which is alot when you only got 35 or 40 to start with.
  6. tjm73
    tjm73
  7. continentaljohn
    continentaljohn
    If your going thru that route why not go with a flathead along with a early flatty auto and keep the model a rear? Make it all bolt in? well kinda for the most part..
  8. tjm73
    tjm73
    I don't ever remember seeing or reading about a factory Flathead with an automatic transmission.
  9. continentaljohn
    continentaljohn
  10. '53 Ford F-100s (last year for the flathead in the US light trucks) had an optional automatic...the Ford-O-Matic. Couldn't say about the Ford auto line, not being a flathead guru, but I thought the '53s offered it as well.
    Of course the Ford-O, in its early versions, sucks. :D
  11. Bruce Lancaster
    Bruce Lancaster
    1951-53 Ford and Merc...heavy thing.
  12. tjm73
    tjm73
    If you do Flatty V8 you can do almost any transmission. C4, AOD ('49-'53), TH350, TH400, 200R4, 700R4, etc....
  13. worn shoes
    worn shoes
    Thank you guys for your prompt replies I greatly appreciate the help.
    ( That is my 51 ford )
  14. scottybaccus
    scottybaccus
    What if you could keep the stick?
    Have you thought about hydraulic or pnuematic operation of the clutch using a button operated selonoid? A small compressor with an adequate holding tank can provide a lot of cycles on the right air cylinder?
    A vaccume brake booster might allow power assisted clutch just as easily.
    Just some ideas.
  15. worn shoes
    worn shoes
    Sounds great but I don't know if I'm that knowledgeable to pull that off.
  16. Darwin
    Darwin
    I've heard that the vacuum booster thing has been done several different ways. Inquire over on the forum at Ahooga.com. Rigging up a vacuum booster or some other hydraulic setup would be a whole lot less work and expense than converting to an automatic transmission.
  17. continentaljohn
    continentaljohn
    You might want to talk to Lonewolfclub (James) A real nice guy and is building a car Model a coupe with Hand controls.
  18. Ray Frey
    Ray Frey
    from Arizona
    Try talking to the Guys at Flat O Matic
    They might be able to addapt a C4
    Good luck
    Ray
  19. Mooosman
    Mooosman
    If you convert it to hydraulic clutch operation, some imports have small power brake boosters that could probably be adapted to your clutch master cylinder. Power operated clutch might take a while to get a feel for it, but it would be 10x easier on your leg compared to mechanical linkage.
    Nick
