Projects Let’s Redesign A Brake Pedal Arm or Not?
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Apr 12, 2023.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not exactly what I call ideal. Let’s correct the lower over centered push rod lever then increase upper pedal arm ratio from 5:1 to 6.5:1 and make this follow the toe board a little better. 6C7F4256-3ECF-4F05-8753-4E3EA0148B0D.jpeg D78DE849-D62C-4A8B-9C76-F2A81B0777F4.jpeg
  2. alchemy
    alchemy
    Is the pivot rod the pedal turns on even parallel to the master mounting plate? Looking from above? Doesn’t seem so in the pic, but may be an optical dillusion.
    dana barlow likes this.
  3. Pete Eastwood
    Pete Eastwood
    from california
    Move the pedal pivot forward.
    That way the pedal will be pointing back at you & not up to the sky.
    That will correct the over center problem too.
    When I do pedals & floors in '32's I elevate the toe board.
    I just put a 1 1/2" or 2" spacer (what ever works best) on the toe board ramps & then build the floor.
    This does a couple of things for you.
    It improves that little toe board "pocket" area between the kick panel & the trans hump,
    where the pedals live.
    Makes locating & operating the throttle pedal a lot nicer.
    Makes the trans hump smaller too.
    Basically it gives you more toe board & less trans hump.
    And that 2 inches your giving up . . . you'll never notice the difference, but your pedals will be happier, and so will you.
    My 2 cents worth . . .
    Sharpone, ottoman, deucemac and 13 others like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It all lines up fine. It’s just the way the photo came out. Also that’s just a 1/4” plywood push rod as mock up.
    Not moving it, I’ve cut and relocated enough stuff as it is due to interference.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Got angle of frame to toe board settled. Here’s the lay out. 9C141D5F-C215-4E04-A56D-09130C921B8A.jpeg 05B736FD-0D0D-4E0C-8D55-CDF92315B150.jpeg
    tb33anda3rd, Paul and Chucky like this.
  6. Pete Eastwood
    Pete Eastwood
    from california
    Johnny Gee
    At least look at elevating the toe board .
    I think you'll see it gives a better result.
    seb fontana likes this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Why would I want to make truck cab even tighter?
    Paul likes this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Much better. FF54CF96-5C99-4632-8441-EF1641E07CE8.jpeg 34B4BE22-9060-48CF-B580-DB9753207004.jpeg BE90F95D-1060-4AD8-B761-4B90E2B73A9A.jpeg
    -Brent-, Paul, Chucky and 3 others like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    951D6E61-05EA-4703-B141-E81E0F9F2F5A.jpeg That’s it for now. Only a profile design and check. When cab final goes back down on the frame and steering column is set will I modify the arm. It may need a Z bend to get pedal from left to right in the proper position.
  10. beater32
    beater32
    What's that done to the pedal ratio?
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just makes it easier to apply the brakes. It’s still within spec (5:1 to 7:1) for manual brakes with a 1” bore master. But that’s not the reason for doing it. I did however take advantage of it since pedal pad would be too low down the toe board because pivot point/shaft was welded in the wrong location (by someone else) to begin with.
  12. 1971BB427
    1971BB427
    from Oregon
    Looks great now. Should be a much easier pedal ratio to push with. Are you going to adjust pedal angle more vertical to get the pad pointed more towards the driver's foot?
  13. BJR
    BJR
    Have you checked the stroke of the master cylinder, so that you get full travel just before the pedal hits the floor?
    Johnny Gee likes this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Vertical? I will most likely move it horizontally to the right as I’ve already mentioned 3 comments above your like.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Once I get a proper push rod I will be checking that.
    BJR likes this.
  16. jimmy six
    jimmy six
    Not saying you have done anything wrong .. the opposite is true. Many miss pedal ratio as friendly and the correct thing to do. That said a 7/8” will be even less foot pressure and not throw you thru the windshield even at 7-1.
  17. nobby
    nobby
    return spring
    brake light switch
    Tman likes this.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    On loan from the part’s store. Which will it be? E23012A7-D70C-4D9D-88D9-E2A34A1BE2BE.jpeg
    Paul likes this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Look’s like SLS40 wins over the SLS43. 5C0382B1-7F30-44C9-B65B-30BCADC2327D.jpeg
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Push rod still has not arrived but I did some number crunching. Master cylinder has 1 1/8” of travel until it bottom’s. That will make for more travel than what the arch on the lever can handle especially when I factor in floor thickness. So it’s back to 5:1 ratio but will still retain 13” radius that 6.5:1 cardboard pattern gave me. To compensate I’ll increase the radius of lower lever from 2” to 2.600”.
    2.600”x 5 = 13”
    1.1875”(lower lever travel) x 5 = 5.9375”(of upper lever travel). Arch has 7.25” of travel available.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ So, can a push rod handle .600” of droop over an approximate length of 8.875”? Or do I lower the master cylinder by .600”?
  22. DDDenny
    Johnny
    Does the MC piston have a shallow pushrod seat, if so, I don't think .600 is too bad.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    @DDDenny no, it’s a manual unit with a deep socket.
  24. BJR
    BJR
    With a deep socket the push rod may hit the edge of the piston at the end of the stroke. I would drop it to try to keep the pushrod as centered as possible. This will also cut down on wear of the master cylinder bore.
    seb fontana and Johnny Gee like this.
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    How high will the pedal pad actually be above the floor when its all the way up? Friend stopped by yesterday to show me his 56 Chevy truck. He had converted to a hydrostop brake setup and put an aftermarket pedal in it. It worked great, but the pedal ended up being too far from the floor and uncomfortable for normal driving. Its a simple fix, as all he has to do is remove the pedal and bend it so its lower. Most brake pedals don't use the floor as a reference as to when to stop....but stop maybe an inch or two above the floor. I'd look at having your pedal stop a little further from the floor, but also check how it "feels" when its all the way up and you are in the seat.
    I think Pete Eastwoods suggestion to move the pivot forward is worth considering, and it looks to me like moving it down slightly would correct the over center problem, and lower the pedal closer to the floor. Anyway, I may be wrong but I think you are solving one problem but maybe creating another one.
    Looks like you are doing a nice job fabbing things up, just looked like your pedal may be kinda high.......but might just be how it looks in the picture.
  26. woodiewagon46
    woodiewagon46
    from New York
    I used a brake switch similar to yours from a company called Preco. The part number was SW-3 and the lever was a spring that gave it some "forgiveness" so that you did not to be exact. Anyone know if they are still available? I searched for the name but nothing comes up so Preco might have been bought out by someone. Those switches came in handy, but the Standard switches you show will work out great.
  27. nobby
    nobby
    p.s. yo know you can get a 'long' 3/8ths clevis
    so IF you have more meat about the fulcrum it clears
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Moving the pivot shaft won’t get pedal pad up higher on the toe board which is goal #1. CC2C3CB9-C5C6-4A80-8A4C-CF810E421316.jpeg 377222A5-A4A6-4FBE-926D-A3E27DF130B4.jpeg A9C934C4-5DCC-411A-975C-510C73E9011F.jpeg
    Chavezk21 likes this.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    And there is all this tubular X structure in the way to deal with as well. Which would mean if pivot were moved forward a 12”-13” push rod would be required. No deal 16BB847A-EF9A-4592-BF0B-C8B888671EB9.jpeg
  30. RICH B
    RICH B
    Tman, olscrounger and Johnny Gee like this.
