Let see all the custom made frames...
Discussion in 'The Hokey Ass Message Board' started by SinastirSpeedShop, Oct 4, 2007.
  1. Jethro
    Jethro
    some old in progress shots....
  2. Drive Em
    Drive Em
    Here is the semi-space frame for my '27 Track T. It is made out of 1 1/2" x 3" x .120" wall rectangular tubing as well as .120" wall 1 3/4", 1 1/2" and 1 1/4" round tubing.
    Here is the finished car:
  3. roseboystoys
    roseboystoys
    Model A Tudor Sedan Frame "Lucky Strike"
    Built by Hot Rod Ch***is and Cycle
  4. Anderson
    Anderson
    Not nearly as nice as some posted above....but I made do. Side rails are 6"x2" tube, pinched at the cowl, kicked up at the front, and tapered to 4" tall at the front crossmember (model A reproduction). 4"x2" for the kickup in the back and an original A crossmember. Center frame section is from a '41-'48 Ford. All done on my garage floor with a tape measure.
  5. retroridesbyrich
    retroridesbyrich
    from Central NC
    A drilled '32 I did a few years ago..
  6. retroridesbyrich
    retroridesbyrich
    from Central NC
    2 x 3 .125 wall and 1.5 round underslung ch***is...
  7. retroridesbyrich
    retroridesbyrich
    from Central NC
    A myriad of various size tubes from 7/8 dom to 2x3 and everything in between on a 26 Ford modified roadster..The Ace of Spades.
  8. 2x3 with 2x4 cross members under a 26 T r/p
  9. jaxx
    jaxx
    2 x 3 tubbing - 1/4 in plate - Conduite for body skelaton
  10. pompadour
    pompadour
    not running any gussets on that copper one on the front and rear z's?or am i missing something
  11. CheaterCarl
    CheaterCarl
    do you mean the copper, cream & green frame?
    If so, no gussets on the the Z's my man. Didn't feel the need, no problems yet, cars been done for 2 years.
    If you didn't mean this frame, please disregard.
    Happy new year to all.
    Love Cheater Carl
  12. lowsquire
    lowsquire
    from Austin, TX
    This ones an A model replica, kind of. Under My RPU, first one i built.
  13. Evel
    Evel
    ACEHOLES frame Built Buy Bob Bleed with the "Bleed Sweep" and adjustable rear perch
    Outback likes this.
  14. i love seeing all of the builds, and craftmanship on here, it motivates me and makes me want to do a better job and be more innovative. thanks guys
  15. CheaterCarl
    CheaterCarl
    a few from my coupe I finished this summer/fall. Sorry they are kinda artsy, Cheater Jack took them & he is a budding homo***ual w/flair! Love CHeaterCarl
  16. Drive Em
    Drive Em
    There must be something wrong with these pictures because the steering box is on the wrong side of the frame, and the distributor is on the wrong side of the engine.
  17. lowsquire
    lowsquire
    from Austin, TX
    "There must be something wrong with these pictures because the steering box is on the wrong side of the frame, and the distributor is on the wrong side of the engine."
    Damn smart*** texans...;)
    Outback likes this.
  18. choppintops
    choppintops
    He probably already has a belly ****on, and didn't want another one. :D
  19. woodbox
    woodbox
    Here is some more detailed pictures of my front end set up in the 1927 lakes modified. These show the torsion bar suspension and how the connection on the right is fixed to act as a Panhard rod and the left side is a link to enable the arms to swing through different arcs and not bind.
  20. retroridesbyrich
    retroridesbyrich
    from Central NC
  21. charleyw
    charleyw
    That's killer!
  22. screwshiney
    screwshiney
    here is the start of mine on my international
  23. woodbox
    woodbox
    Here's a few more with the body a bit more advanced. All of the steel panels including the grill shell were formed from flat panel steel.
    I made the steering wheel and column from bits and pieces of alluminuim from the s**** bin. The seats are formed from flat with compound corners welded in after. The fuel tank has hammer formed ends and a filler cap from a GSXR1100 motor cycle, the belts are just for show over the mounting bolts. The tail lights are Model A with custom brackets from the tank mounts.
  24. retroridesbyrich
    retroridesbyrich
    from Central NC
    That looks bad *** for sure.
  25. retroridesbyrich
    retroridesbyrich
    from Central NC
    Woodbox, looks great. Thanks for posting.
  26. woodbox
    woodbox
    Rich, Thanks for your comments. I do appreciate them, especially from another one man band on the other side of the world. I am currently caught up with house renovation projects and have been doing OPJ's (other peoples jobs) so have not been able to do anything on the T for far too long. I am expecting a load of new parts soon to help things get kick started again.
  27. ma70tt
    ma70tt
    here's a couple of mine. they are both for 4100 series chevy ad trucks
    this one is in the process still, should be on the road in the spring. its 2X4 mostly...
    this is one i did last spring
    this one is 2X4 main rails with a 1 5/8 cromoly truss
  28. scottybaccus
    scottybaccus
    Still a work in progress...
  29. retroridesbyrich
    retroridesbyrich
    from Central NC
    So many great fab jobs..It's a shame to cover them with a body!
  30. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    do you have a clearer pic looks good but hard to see
