Let see all the custom made frames...
Discussion in 'The Hokey Ass Message Board' started by SinastirSpeedShop, Oct 4, 2007.
  1. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    .......Littleman
  2. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Oh Dave.... stop the charade.... we know you order them from SoCal..... ha ha ha
    Outback likes this.
  3. scootermcrad
    scootermcrad
    Although pretty off-topic around here I have to give serious credit to this ch***is build! INCREDIBLE work!! Since I'm a 35 coupe guy also, I would like to see the rest of the car. Maybe you can PM me a picture or something.
    Ch***is work is sort of an art form, in my opinion. It has to be structurally sound as well as functional and when you have a small car it can get even more challenging to fit 10 pounds of poop in a 1-pound bag and still be able to work on the car.
    Some amazing ch***is work, PERIOD, in this thread!
  4. ELpolacko
    ELpolacko
  5. ELpolacko
    ELpolacko
  6. ELpolacko
    ELpolacko
    Mix bag of stuff.
  7. gotwood
    gotwood
    from NYC
    ELPOLACKO??
    From reading some of your posts you are obviously educated in your work and I want to ask if cutting reliefs and slicing 2x4 tubing and welding in into shapes weakens the structure?
    I am in no way attacking your work i just know it is common practice and wonder if you take a say 2 foot section and put say 5 or so reliefs to make a bend and then weld and grind it up what the effects are.
    Love that 2.5? bent tubing.
  8. ELpolacko
    ELpolacko
    All depends on how you do it.
    All of our stuff is cut on a band saw to keep abrasive material out of the joint. We also debur as much as possible to eliminate anything that could contaminate the joint and we leave about a 1/16" gap between the pieces and then TIG weld them for the high strength areas. Generally a MIG weld would be more than sufficient and if we need a smoother finish (outside rail visible) we will sand the weld level.
    Been building frames this way for over 20 years without incident. No real need for gusset plates unless you have an unusually high stress area or improperly welded joints. If you will notice on the truck frames that I try and place the tube structure in the center to overlap some of the joints just for piece of mind.
    Yeah, 2.5" X 0.188 DOM! It was supposed to be mandrel bent but the shop that did that for me broke the mandrel on the first bend. Still made for a killer look.
  9. retroridesbyrich
    retroridesbyrich
    from Central NC
  10. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  11. scootermcrad
    scootermcrad
    WOW! Just keeps getting better and better! Impreessive stuff ELpolacko!!!
  12. Well I started this thread 5 years ago, Lets see what is new now days
  13. ARTSWRK
    ARTSWRK
  14. verno30
    verno30
    Here is a sampling of ones I have built. I used 2x3 .125 wall. These are lightweight cars and I have not had any issues. I also build my own suspension components, crossmembers, and motor mounts
    And some '32 Ford based frames.
  15. Vigsters
    Vigsters
    from Folsom, Ca
    Howdy, lets all enjoy new years and the frame of what drives us;;; FAMILY Before I GET BANNED THANK YOU ALL.....
      16.8 KB
      20.1 KB
      15.9 KB
  16. VintageConcepts
    VintageConcepts
    Taking notes. Nice Frame!
  18. Lets keep this thread going...
  19. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Here's the one I built for my 32 pickup
  20. Roger Walling
    Roger Walling
    Extended 84 Fiero with 1" x 2" 1/8" tube and 16 ga. side panels
  21. mgtstumpy
    mgtstumpy
    A friends 42 Chevy PU, kicked up rails with '46 Olds X-Member and trailing arm suspension.
  22. daddio211
    daddio211
  23. buzz4041
    buzz4041
    from Texas
    Here is a few of my 40 ford pickup ch***is I am building.
  24. J.W. Rod Garage rails. everything else was fabbed by me in my home shop. It's under my 29 roadster.
  25. wldtrout
    wldtrout
    from montana
    Here is one I built for a chopped 37 Ford pickup.
  26. wldtrout
    wldtrout
    from montana
    Here is another one I built for the 36 ford panel
  27. barett
    barett
    from Taylor TX
    Oh fun I want to play...
