Let's play "what is this"
Discussion in 'The Hokey Ass Message Board' started by Aman, Oct 8, 2010.
  1. Aman
    Aman
    from Texas
    I found this thing on the drivers side of the 235 in my 55 Chevy. Does anybody know what the hell it is? It has a 110 plug on one end of the wire and then screws into the block through the red, round thing. I unscrewed the little bolt that goes in through the red thing and it's about 2" long, strangest thing I've ever seen. The red thing doesn't come off. It's located just below the intake/exhaust manifold on the drivers side. Instead of just cutting it off I wanted to ask around to see what it was. Any clues about what it is?:confused: thanks for the help guys.
  2. SWIGJ
    SWIGJ
    from JASPER GA
    Block heater
  3. Engine block heater..typically used in cold weather areas to prevent freezing.
  4. Bruce Lancaster
    Bruce Lancaster
    It is a block water jacket heater. Your car has lived far north of Texas at some point in its life!
  5. CANS01
    CANS01
    from MidWest
    Yep block heater
  6. KIRK!
    KIRK!
    Block heater....oh, too late for the right answer.
    Electric car conversion kit?
  7. pinstripebob
    pinstripebob
    from Carmel, IN
    Where's that car from? I wonder if that's a block heater.
  8. alchemy
    alchemy
    This is funny. A Texas guy would have no idea what these things are for.
  9. CME1
    CME1
    It's a block heater to keep your water from freezing in the winter.
    ME
  10. Rod and Wheeler
    Rod and Wheeler
    from NOR CAL
    A block water heater for those cold winter nights. Ah memories when I lived in Minisota.
  11. little skeet
    little skeet
    from huston
    It is an electronic 110 voltage, element heat transfer conductor with H2O capabilities.
  12. 57tailgater
    57tailgater
    from Georgia
    Block heater. Used rarely in areas below the mason/dixon line!!!!!!! :cool:
  13. the-rodster
    the-rodster
  14. Mr. Jean
    Mr. Jean
    Yup, you've heard the answer. They are to keep from blowing freeze plugs in the block or worse yet freezing it up and cracking something in the really cold/freezing climate areas.
  15. drs47ford
    drs47ford
    from Western NY
    Also makes it easier to start the car when the temps get below freezing.
  16. Stevie Nash
    Stevie Nash
    Looks like a northern car worked it way south. Usually the other way around...
  17. Ebbsspeed
    Ebbsspeed
    And now it's a rust-free Texas car?
  18. RoryShock
    RoryShock
    from Western TN
    Since the real answer was already taken ...
    An early model hybrid.
    I wonder how many people you could fool by telling that to ...
  19. :D
    best reply so far!
  20. stromberg
    stromberg
    So you can make hot tea without running the engine.
  21. thendrix
    thendrix
    I don't know guys, I kinda thought it was a block heater ;)
  22. Motorsports One
    Motorsports One
    Did you notice the file names of the 4 pictures you attached to your message? "55 heater 001.jpg", etc.
    My Flathead has them too, being a Saskatchewan truck, but without the cords. The plugs just stick right out of the cylinder heads on both sides.
  23. You fuckers are all full of shit !! It's the first ELECTRIC CAR and it's RARE AS HELL !!! Now go cash in on it !!! >>>>.
  24. Glad you set them straight before I had to:D.
    There sure are a lot of them in this neck of the tundra.
  25. I,m surprised at the many answers saying it was to stop the coolant from freezing. I doubt that is the case. The purpose of course is to warm the coolant which allows for easier starting in cold climates. Don't believe me? Try leaving straight water in the block up here but plug it in in January. It will freeze regardless......
  26. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    That is, as many have stated, a block heater. Up here in the Great White North, we mix the water in our cooling systems 50/50 with anti-freeze, as do the northern states.The heater is not intended to keep water from freezing but to heat a properly mixed coolant to facilitate easier starting in freezing temperatures.
  27. brad2v
    brad2v
    Exactly correct, but I wish I lived somewhere that I'd never heard of such a thing either....
  28. wetatt4u
    wetatt4u
    Early model theft proofing !
  29. 63gasser
    63gasser
    no its to keep the block warm so you have something to cuddle against and keep warm when the old lady says no!
  30. dudley32
    dudley32
    It turns Water Into Electric Current ..plug it into your house for free electricity...
    d32
