Let's play: What the hell is this tool
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Nov 23, 2007.
  1. Chris Casny
    Chris Casny
    What is this thing, to me it looks like some sort of reamer, it has 3 blades that at some point seem to have been really sharp. I acts like a ratchet, the three blade only rotate counter clock wise. (big extractor???)
    16" long and 9.5" tall.
    Made by Mueller, Patented June 21, 1898.
    This is part of a huge collection, from when I bought a building that was a machine shop.
    Anybody know? Looks like a mid-evil torture device.
  2. dave lewis
    dave lewis
    from Nampa ID
    large deburring tool..
    way cool..restore or display as is ??
    dave ;-)
  3. haroldd1963
    haroldd1963
    from Peru, IL
    It's a hemorrhoid remover!
  4. Chris Casny
    Chris Casny
    I was going to use it.
  5. kustomrodder53
    kustomrodder53
    Thats my guess.
    For pipe I think...
  6. strike a poser
    strike a poser
    from Salinas,CA
    You use it to remove the rough edges out of the inside of cut pipe.
  7. Kent
    Kent
    from KCMO
    looks like woody woodpecker
  8. fiat128
    fiat128
    from El Paso TX
    It's a bungholer!
  9. 47 jailbar
    47 jailbar
    from Mn
    Yup. We use a similar tool to this day when we cut round gas pipe:D
  10. daveyboy56
    daveyboy56
    It's a pipe remer for a plumber to use on Gal or steel pipe
  11. Louie S.
    Louie S.
    Definately a pipe reamer.
  12. 6deucecaddy
    6deucecaddy
    Its a Reamer or deburrer for conduit.
  13. Did anyone think it is a reamer? Looks like a reamer for wooden barrels, for a taper for a cork.
    CBB
    I was thinking the same thing Unkl Ian....
  14. 35mastr
    35mastr
    from Norcal
    Looks like an old gas pipe reamer.
  15. Unkl Ian
    Unkl Ian
    It's for cutting the tapered "Bung Hole" in wood barrels.
    The hole would be drilled through with a brace and bit,
    then this tool cuts the taper.
    I doubt they had conduit in 1898,
    and the angle is wrong for deburring pipe.
  16. Mr.Musico
    Mr.Musico
    from SoCal
    I think its a pipe reamer
  17. BeatUpFleetline
    BeatUpFleetline
    my guess is a flaring tool
  18. butch27
    butch27
    Gritzel Pivot installer.
  19. knotheads
    knotheads
    i agree with fiat 128 its a bunghole tool to gain access to wine barrels for sampling
  20. ray
    ray
    from colorado
    great, now i gotta get a bunghole reamer for my den.:eek:
  21. junior58
    junior58
    Man, I wouldn't want my bunghole reamed with that!!!! In fact I don't want my bunghole reamed at all.
  22. ray
    ray
    from colorado
    fine, whatever suits you, but be warned, bunghole leakage may occur if you don't properly ream out your bunghole before use.
  23. d2_willys
    d2_willys
    from Kansas
    butt reamer, or you can use it on "gas" pipe. No pun intended.
  24. BAD ROD
    BAD ROD
    I think it is an eye remover.
  25. budd
    budd
    pipe reamer
  26. publicenemy1925
    publicenemy1925
    from OKC, OK
    IT's for installing rubber assholes in wooden hobby horses. Geeeeeeeeez.
  27. Maybe you could do a patent search based on the date it was patented? It sure looks like a reamer of some sort. Probably the angle the blades are beveled at would give you a clue to whether it was meant to ream metal or wood.
    If you listen to it closely, maybe it will announce:
    "I am Cornholio... bunghole bunghole BUNGHOLE"
  28. Boynamedsue
    Boynamedsue
    My mom bought one a couple of years ago and its sitting in the pantry. Thats exactly what its for, if its not booze related my mom doesnt buy it.
  29. ls7gto
    ls7gto
    Now thats funny !
  30. do the patent search and by all means let us know.
