Technical lets see some 28 9 roadster dashes
Discussion in 'Traditional Hot Rods' started by 48fordnut, Jul 31, 2018.
  1. 48fordnut
    48fordnut
    I am trying to come up with a dash for my A v/8 roadster . I have 2 5/8 gauges with a 3 3 /8
    speedometer.Let me have some ideas.
    Thanks,
    jim
  2. hfh
    hfh
    from Western MA
    IMG_1356.JPG IMG_1355.JPG This is mine with old 2 5/8" gauges. I made the dash panel and the birds eye maple piece over the top. I've been enjoying them for 20 years.
    Jet96, Bandit Billy, alchemy and 4 others like this.
  3. 48fordnut
    48fordnut
    I like the larger gauges, with a small speedometer. Yours is esp nice.
    thanks,
    jim
  4. This is a work in progress. The dash is a 1937 Ford unit. Being I'm Flathead powered I wanted gauges that looked and worked correct. It will use all stock 37 Gauges and spedo. I also like the fact I'll now have a glove box. Minor job with good results for this project. I was actually able to mount the 40 steering column and use the locking key switch. It kind of all just fell into place. I know the 28\29 is a bit narrower but there's plenty of material to trim off should you want to try this set up.
    The Wizzard
  5. 48fordnut
    48fordnut
    Tried a 50 ford dash on a 31 roadster. It didn't work out. Yours looks good. A friend has a 31 coupe with a 35 dash.
  6. 2935ford
    2935ford
    Here's mine.
    studebaker46, Jet96 and 48fordnut like this.
  7. Stan Back
    Stan Back
    Here's mine. It may have a few things you're not going to need . . . dash.jpg
  8. sloppy jalopies
    sloppy jalopies
    trimmed these dashes ... DSCN2642 (2).JPG DSCN2810.JPG DSCN2840.JPG DSCN2859.JPG DSCN2880.JPG … for '30-'31 but could work on the '28-'29s...
    48fordnut likes this.
  9. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Anymore out there ?
  10. Dean Lowe
    Dean Lowe
    I like the way Henry designed it.
    akoutlaw and 48fordnut like this.
