Let's see some sheet metal shaping
Discussion in 'The Hokey Ass Message Board' started by jhnarial, Sep 16, 2008.
  1. MP&C
    MP&C
    Don't know that I'd go that far OJ, I do try to improve from one job to the next and apply any lessons learned (mine or someone else's) to make the next one go smoother. Sometimes that works, sometimes it's s****. :D
    Good seeing you again yesterday, glad you could come down and spend some time in the shop!
    lothiandon1940 and loudbang like this.
  2. How does it work?
    Steve
  3. MP&C
    MP&C
    Place the panel flat on the table, use the "half pipe" as a punch to crisp up the ends. No fuss no muss.
  4. Cool - such a simple tool yet it makes a huge difference in the quality of the beads.
    Steve
  5. MP&C
    MP&C
    Had some questions about how we did the "J" detail for the bumper seal..
    I missed getting some of the pictures of the dies, so had to go back afterwards...
    These are all the dies used, I had three different lower dies to progressively fold the sides in. The location is set by using a backstop on the first p***, using the die show on the right..
    This is the final die shown with a sample run...
    lothiandon1940, 54reno, fauj and 7 others like this.
  6. iwanaflattie
    iwanaflattie
    Hey how are you guys cutting sheet metal thats is so straight?
    Just bought a Milwaukee double shears but cant cut true straight.
  7. JOYFLEA
    JOYFLEA
    Seth I have one of those 3 in1 machines. Works fine for what it is .
    On cutting straight lines , rough in your cut to about 1/4 to 1/2 inches of your line then tin snips on line . Also a shear is nice . Good to hear from you , did you get moved . Blue
  8. iwanaflattie
    iwanaflattie
    Hey Blue.
    Thanks.
    I am still in transition...
    Im working in Vegas and I go see my son every weekend..
    Most of my tools are in Ca including my coe...
    I'm about to bring it to Vegas to get some work done on it..
    Im still looking for a place I can afford that has space for all my stuff and a place to work on it.
    Say..wat kind of tin snips are you using?
  9. JOYFLEA
    JOYFLEA
    Wiss snips , l&r plus a pair of bulldogs now and then for really thick stuff . Also use some Malco zip snips . But mostly Wiss for last 50 years . Blue
    biggeorge likes this.
  10. Offset snips, where one blade is off to the side or offset and allows the metal to slide past the pivot. You can cut right thru the middle of a sheet.
    loudbang and biggeorge like this.
  11. cretin
    cretin
    If you are using a shear, you should have no problem cutting a straight line without hand shears.
    Do you mean that you can't cut a line square to an already straight edge? Or is your shear not cutting?
    If your shear isn't cutting, make sure your blades are adjusted, and sharp.
    If you can't cut an edge square, make sure your guides are square.
    If you can't use, or square your guides, you can do this. This method is also good for shearing a large piece by yourself.
    Mark your cut line, then use your hand shears to make a small cut on your line so that it also bends down a little tab on the side that you want to cut off.
    Now you can put your material in your shear, and you use the little tabs you just cut to hook on the lower blade of the shear, so that you have your material lined up right, then shear it.
    junkbrick, LBCD, brEad and 7 others like this.
  12. JOYFLEA
    JOYFLEA
    I think what Seth is talking about is electric hand shears .
    I do the same on my stomp shear ****** . Use to do all my lay out for duct work with a ***** punch and snips . Blue
  13. It's 3 units in one & it can't do any of the operations well enough to justify the floor space.
    These don't want to follow a curve, and are hard to run a straight line. Great for hacking.
    These will cut any way you want to go, as long as the sheet is flat and the curves aren't too tight.
    A rig like this nibbler cuts tight radius and shaped panels. Like a ribbed truck bed, floor pans or tight radius on formed panels. Drill a hole and cut with it anyplace in the middle too. Runs off a drill you already have.
    JOYFLEA, MP&C and loudbang like this.
  14. cretin
    cretin
    Oh you're right, I missed the part where he said he got the Milwaukee double shears, and thought he was talking about the shear in the photo. My mistake.
    In that case yup, cut close then hand shears.
  15. cretin
    cretin
    I also completely agree with this statement. I had one of those, and it just sat in the corner because it really did nothing well except take up space, so I sold it. Never missed it since.
    31Vicky with a hemi and loudbang like this.
  16. slimcat7m3
    slimcat7m3
    Switched ******s so I am in the process of making a new ****** hump.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    my hillbilly radius bender... 18 guage kicked my *** bending 24" by hand.
    brEad, bct, JOYFLEA and 5 others like this.
  17. TFoch
    TFoch
    ^^^ That looks great. Can you show a pic of the dies you used. Can't see the bottom die in your pictures.
  18. Dino 64
    Dino 64
    from Virginia
    Great job, how did you fab the rear end of the cover ? Thanks
    loudbang and lothiandon1940 like this.
  19. MP&C
    MP&C
    I have the battery version of the Milwaukee, rated at 14 ga capacity. Works well, but as noted is limited in radius cuts. I've found if you trim close to the line in repeated straight cuts, leaving less material than the blade width, it will then go back and trim practically any radius you like.
    loudbang, JOYFLEA and lothiandon1940 like this.
  20. wingedexpress
    wingedexpress
  21. MP&C
    MP&C
    What did you use to form the diamond tread pattern?
  22. I wonder about the larger 52" models that are supposed to be rated for 16 ga - anyone have any input on those?
    Steve
  23. MP&C
    MP&C
    One of those sells new for approx 2300. For another 500 on top of that I was able to buy a 12 ga rated Pexto shear with 3PH rotary converter... Not that it's the same machine, but for that money you should be able to get so much more capability in a used machine
    I'm a cheap ******* but would rather spend what I have on good, quality machinery. Unless you have space limitations that make a 3 in 1 machine appealing, I would steer toward good used multiple machines.. If you must get the 3 in 1, you can always look for used on CL or otherwise, that way you're not so much into the machine and can come out better if you decide to upgrade to multiple machines down the road..
    loudbang and cretin like this.
  24. Wow, that is quite the brute! The floor space is definitely the issue for me otherwise I'd hit bidspotter.com and buy 3 machines. I'd prefer made in USA anyway and I think all of the 3-in-1s are overseas junk...
    loudbang and MP&C like this.
  25. MP&C
    MP&C
    If you're on FB or IG, check for sodakbigjoe, he recently got one of those 3 in 1 machines from a Baileigh contest. I'd ask how it does with it's rating of 16 ga, and if he had to BUY one, would he still pick that one. I have one of their magnetic brakes, got in a contest for about half off, and just recently got one of their MH19 power hammers used, at just over half price. Again, I'm a cheap *******, and don't know that I'd have either of these machines if I had to pay full price. But the mag brake can do some neat stuff, it is a bit over rated as it doesn't do 16 ga with as crisp a bend as I think it should. That's why you'll see me thinning a bend line with a tipping die for crisper bends. The power hammer, it's a beast, and USA made. All of their yellow stuff is made in WI at RMD.
  26. K13
    K13
    Good luck finding much locally. I always keep my eyes open for stuff and very little ever seems to be available in the prairies. I always cringe when I see guys buying Bridgeports for $1000 in the US and you can't buy a cheap used bench top Chinese mill for less that $1200 around here. There was a guy on instagram trying to sell a working Bridgeport with a phase converter for $1000 and it took him days to sell it (I think he was in Detroit) that would be $4000 here all day long. We also get killed on shipping from the U.S. When I bought my bead roller I was going to buy it from Baileigh as Shane was super helpful but shipping was going to be close to $600 for a $1000 machine just made no sense.
    whtbaron and loudbang like this.
  27. I hear ya - we get our ***es kicked on shipping stuff here. I bet there's more selection in Eastern Canada than here as well...
  28. i had a 10ga 48" sheer, with manual back guage- 3 phase. I got it working perfectly then tried to sell it. I don't really need it because most stuff I cut isn't straight. I couldn't give the thing away.
    Too big for the garage guy and too small for the pro fab shop.
  29. slimcat7m3
    slimcat7m3
    These are from the Eastwood kit, I absolutely love it.
    loudbang and TFoch like this.
  30. slimcat7m3
    slimcat7m3
    If you look at the first pics, I made it too long so I could cut the rear portion off and angle it down. I tack the parts together and sadly clamped a ball peen hammer in a vise and used that as a dolly to roll the edges together into a radius.
    loudbang and JOYFLEA like this.
