Lets see your Column drop
Discussion in 'The Hokey Ass Message Board' started by lrs30, Sep 25, 2012.
  1. lrs30
    lrs30
    from Kentucky
    I am at that stage, and am looking for ideas to fab up a column drop for my 31 A. So if you would be so kind, show me what you got!
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Search in the tech archives. There was a thread on building one that really looked period correct.
  3. Fenders
    Fenders
    I cut out the tank of my 30 (same as early 31), retained the tank column support at top, used a late 31 column support (reversed) at the bottom.....
  4. beater32
    beater32
  5. Hot-Rod-Howard
    Hot-Rod-Howard
    In my old 36 coupe, I used an aluminum piston rod I picked up at a swap meet for $5.
  6. Tony Ray
    Tony Ray
    The one in my 59 truck is a flathead connecting rod, actually fits o nthe column pretty good. I was debating keeping it or find something else closer to stock.. but at this point it works. could take a picture if you want..
  7. Roadsir
    Roadsir
  8. Canuck
    Canuck
    Custom made column drop mounted under a 34 Chevy Master dash in my 30 A coupe. Lower end is clamped in a sleeve welded to the firewall. Had to put a removable shift lever on the lower end of column so it could be installed and removed, column shift automatic.
    Canuck
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    The factory Model A column drops use a rubber pad around the column tube in the bracket. The 28-31 units are soldered to the bottom of the gas tank. The late 31 units bolt to the dash rail under the top of the dash.
  10. HellsHotRods
    HellsHotRods
    Mine.... I own several of these, it's a sickness........
  11. fleetside66
    fleetside66
    If you want it to be rock solid, you might consider making the drop independent of the dash. Although the pics aren't great, I made a drop that was adjustable north, south, east & west. So, I could get the positioning of the steering wheel exactly where I wanted it & the dash was really independent of the whole works. That whole 1" square tube bracing thing enabled me to hang my pedals, as well. Just another idea.
  12. Old Dude
    Old Dude
    Here is mine on '31 Model A !
      435.5 KB
  13. Framewelder
    Framewelder
    Here's the one in my roadster
