Let's see your custom air cleaners
Discussion in 'The Hokey Ass Message Board' started by olds vroom, May 19, 2014.
  1. 56 Dodge Pickup
    56 Dodge Pickup
    Man that’s smooth nice work! Hobo Jim
    Deuces likes this.
  2. Flashback to the 1960s-'
    before I could get a drivers license.
    With odd job money I bought a well used big single cyl Harley hard tail track bike.
    It had so much low end torque you'd swear you could drive it straight up out of a well.
    The air filter was missing. There were two screw holes for the old missing one.
    I took a metal Planters Peanuts can, cut a hole in the metal bottom for the carb opening, holes for the 2 screws into the carb housing, then drilled dozens of breathing holes all around the can walls.
    After I screwed the Planters Peanuts can to the carb, I grabbed a fluffy knitted potholder and put it in the can, then snapped on the plastic lid.
    Voila! I had a free breathing filter to keep the pebbles and leaves and flying sticks out of the engine.
    To clean it, I peeled off the plastic lid, pulled out and rinsed the potholder, shoved it back in and snapped the plastic lid back on.
    That Planters Peanuts air filter became the first thing people saw, and the first thing they talked about.
    A conversation piece, and it WORKED!
    WHY BE ORDINARY ?
    Deuces likes this.
  3. olds vroom
    olds vroom
    Zjerry that’s the best one I’ve seen yet .love the innovation.
    Deuces likes this.
  4. olds vroom
    olds vroom
    Any new ones?
    Deuces likes this.
  5. i.rant
    i.rant
    Here’s a few I made, converted to 4bbl use 641C0B39-13A8-4180-B61B-724B5063E45E.jpeg A4405DE7-957E-4470-A3C7-8308AE960D2D.jpeg
  6. mrhp
    mrhp
    from MICHIGAN
    On my 62 impala
  7. blue 49
    blue 49
    from Iowa
    Deuces and CudaChick1968 like this.
  8. olds vroom
    olds vroom
    I like it !
    Deuces likes this.
  9. earlymopar
    earlymopar
    Dual Element Air Cleaner 1.jpg A couple I've made. The cast aluminum piece was a Mercury outboard gas tank & recoil starter.
    - EM
    Mercury Outboard Air Cleaner.jpg View attachment 4065116
    PoTaToTrUcK, Moondog13, BigO and 6 others like this.
  10. dan griffin
    dan griffin
    Cook pots with handles cut off.
    clem, Deuces and Early Ironman like this.
  11. Deuces
    Deuces
    Perfect!!! I always loved cowl induction.....
    mrhp likes this.
  12. mrhp
    mrhp
    from MICHIGAN
    Patterned off the z-11 style air cleaner. I built the air cleaner housing, and had a fella build the lid. The lid I had made was flat, and this domed lid looks more correct.
    Deuces likes this.
  13. Bandit Billy
    Bandit Billy
    I bought this moon unit (zapa?) and hit it with the bridgeport and removed some fins, sanded, polished, cut the attachment studs off a 396 fender emblem and JB'd it to the new flat spot. For my OT Camaro.
  14. ct1932ford
    ct1932ford
    Not custom, just old:rolleyes:
  15. Cree
    Cree
    from Montana
    not a crazy custom but an old y block oilbath gutted, converted to paper element and holes drilled in it
    Deuces likes this.
  17. GordonC
    GordonC
    I posted this up before here but some hard case felt it was too rat roddy? Go figure? Anyway, it is made from a 1957 (I think) Mercury hubcap a buddy had hanging on his garage wall. I had a 4 bbl on my flattie at the time and thought it looked pretty good when I was done. Running a Merc 4 inch crank in the motor so it seemed appropriate to me.
  18. patzfab
    patzfab
    from Canada
    9DA328C8-1742-42C6-A3C9-B57CB94EDF4B.jpeg This one from my buddy Cam Grant. He has the pattern and had one cast for me. I fitted a 6” dia. x 3” filter element, a 1/8” aluminum base. Looks “HAMB” friendly.
  19. GordonC
    GordonC
    patzfab can you fit a Ford emblem in that oval on the front of the air cleaner!:D
    Deuces likes this.
  20. olds vroom
    olds vroom
    Here’s one I found[​IMG]
  21. 56 Dodge Pickup
    56 Dodge Pickup
    Wow I’ve ever seen one like that before!
    Deuces and 41 GMC K-18 like this.
  22. Donut Dave
    Donut Dave
    Plain and simple!
    GordonC and Deuces like this.
  23. olds vroom
    olds vroom
    Btt
    Deuces likes this.
  24. Jokester
    Jokester
    Where did you find the chunk of finned aluminum?
    .bjb
    Deuces likes this.
  25. Almostdone
    Almostdone
    I suppose you could face it forward or backwards depending on your age.
    Moondog13, atch, High test 63 and 3 others like this.
  26. rustydusty
    rustydusty
  27. bowie
    bowie
    NOT a cake pan : 7550B1A9-929E-4A4E-AA60-00CC1537F854.jpeg
  28. JOHN H EDGE
    JOHN H EDGE
    842ED912-FA2E-4923-ADC5-DA73F69097F5.jpeg My 52 Plymouth Suburban with the Flathead 6 hopped up with dual carbs. Used a 67 corvette 427 tri power air cleaner and made a fresh air intake thru the factory Front blower for the inside vent system but ran it to the air cleaner 3E40C81F-D68A-4825-A1C5-75E7096243C9.jpeg 67C156AA-BF03-4A77-AD02-57D965F9FF83.jpeg 8C1A3BFE-ADD1-475B-AB7C-B51EE89357BB.jpeg
    GordonC, Deuces, Dangerousdan and 2 others like this.
  29. jimmy six
    jimmy six
    Thought we did this a couple of months ago....not custom but near unobtainable. 1956 NASCAR Purolator dual quad. image.jpeg
  30. nochop
    nochop
    from norcal
    Not sure I’ll use it 94B2EA85-4DB2-40AB-A70B-A868479B7F97.jpeg 878FF7B5-FC80-4CD5-A651-AD8C4B33BEA8.jpeg
    Deuces and GordonC like this.
