Lets see your Halibrand rearends
Discussion in 'The Hokey Ass Message Board' started by Dave50, Sep 4, 2010.
  1. Dave50
    Dave50
    Lets see your Halibrands guys. There isn`t anything better peeking out the back than a Halibrand IMO Also how many are running locked rear ends or open rears? I got a 310 i am thinkig about using on my project got pics in my albums letr me know what you think and i need to know what type of tubes and bells i could use thanks IK anothe FNG and his ?`s lol
  2. Berky
    Berky
    I love up skirt shots :D
  3. sdluck
    sdluck
    More please
  4. Pewsplace
    Pewsplace
    Here is mine and a few more. A hot rod without a QC is a wannabe.
  5. duste01
    duste01
    wrong time of the day to be looking at rear ends.......mine a columbia anyway
  6. 32 Barn Car
    32 Barn Car
    from Oregon
    Mine............
  7. Dean Lowe
    Dean Lowe
    Sorry, but mine's a Speedway Engineering unit.
  8. Dean Lowe
    Dean Lowe
    This one was a Halibrand.
  9. uncle buck
    uncle buck
    What modifications were required to the crossmember , gas tank , or suspension to make it work in the 36 ? Thanks Dave
  10. Berky
    Berky
    Dave,
    A modified Model A crossmember was installed with a Model A spring. The tank and everything else is stock. The only part that needed to me modified was the floor of the trunk to make room for the crossmember.
  11. bonesy
    bonesy
    Wow - what a great looking setup.
  12. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    This is my early Halibrand in my 29 lakes modified. The casting is one of the early mag jobs and I have converted the axles to full floating using parts from Coleman Bros. Racing. I used Ford 7.5" side gears and remachined the carrier to except them. The axles are 4340 28 spline units from Coleman Brothers Racing also. The hubs are aluminum and use a pair of Timken tapered roller bearings so they are pretty stout. I bought it from Vern Tardel and did a complete rebuild, new bearings and seals etc before I put it on the road. I have about 10,000 miles on it and zero problems. Special thanks to the guys at Hot Rod Works also.
    Rex
  13. uncle buck
    uncle buck
    Rusty, Thanks for the info. I was thinking that was going to need to be done, but not positive. Dave
  14. sr
    sr
    from Monterey
    Here is mine before I put it under my roadster.......
  15. Russ B
    Russ B
    v8 with '37 bells, 9" bearing and brakes. ...not on the road yet. Ch***is is for a full fendered '29 Ford cabriolet.
  16. cabriolethiboy
    cabriolethiboy
  17. Here's mine peeking out.
  18. bathcollector
    bathcollector
    This one has sat in the rafters in my shed for a few years. [​IMG]
  19. Dave50
    Dave50
    WOW! Guys alot of really nice rears keep them coming heres what i am starting with need to find the rest.
  20. Rich Wright
    Rich Wright
    Looking forward to having the time to put it together....
  21. 2002p51
    2002p51
    I have rear-end envy! :(
    How much better would this car look with a quick change?
    I'm gladly accepting donations! ;)
  22. thunderbirdesq
    thunderbirdesq
    My ol' Culver City...
  23. my 34
  24. MikeRose
    MikeRose
    from Yuma, AZ
    Are there any companies/shops that sell complete units ready to go? I need an open drive one for a project and don't know enough to build one myself.
  25. Deuce Roadster
    Deuce Roadster
  26. MikeRose
    MikeRose
    from Yuma, AZ
    Awesome, thanks.
  27. Pete1
    Pete1
    from Wa.
    It's not a Halibrand but the parts interchange.
    3 inch axle.
  28. 50 Ford 1963
    50 Ford 1963
    Quickchange
    Quickchange Rear Ends for Early Fords
    Just for the nostalgia hot rodder, an affordable Quickchange rear conversion that fits early Ford axle housings. Uses your original parts and retains the differential action. Gives you that old time Hot Rod look. No special parts to purchase. Uses stock 1940-48 Ford rear hubs and brakes. Great for Model A's, Deuce Hiboy's and many other applications. Not intended for racing or high horsepower vehicles.
    Seems to be some conflicting information about this... :rolleyes::D:rolleyes:
  29. Pete1
    Pete1
    from Wa.
    I would venture that 90% of the hot rodders have never seen a street roadster with an open
    tube rear end going down the street....I know that many run locked axles in conventional rear ends...One of the biggest advantages of an open tube is, taping up the axle with bright colored tape in a spiral configuration like a barber pole....It hypnotizes the people following you when they watch the axle and try to figure out what is going on.....
  30. seatex
    seatex
    That just ain't right............................. "nice ***"!:eek:
