Hot Rods Let's see your headers. Custom built only
Discussion in 'The Hokey Ass Message Board' started by Frames, Jul 19, 2024.
  1. Frames
    Frames
    I build headers using U bends, not kits. p1010176_0020_020_0044 - Copy.jpg p1010182_0007_007_0055.jpg
  2. ALLDONE
    ALLDONE
  3. Flatrod17
    Flatrod17
    My home made for my 4 banger. Still being made in these pictures, I then had it ceramic coated. header1.jpg
    jet996, flyin-t, 402BOSSMAN and 15 others like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    I built the headers for my outlaw clone from u bends. Tig welded and metal finished before chrome plating. I also did the pre plating polishing
  5.
  6. My next little project is building a set for this thing and keeping them inside the stock fender panels.
    Yes it's an I-Beam axle and stock 40 steering column. Prymarys are 2.125 and must squeeze between the wishbone and frame rails and go around the steering box. Why make it easy? Stay tuned.
    slayer, jet996, neilswheels and 14 others like this.
  7. mad mikey
    mad mikey
    I made these last winter, good at the drag strip but to loud on the street. With my blown mill, they set off all the car alarms in town.:eek::) WIN_20240517_17_37_17_Pro.jpg WIN_20240517_17_39_59_Pro.jpg
  8. Had to build the swedges too! Hell's Gate Hot Rods flanges.
    upload_2024-7-19_19-0-22.png upload_2024-7-19_19-0-45.png upload_2024-7-19_19-1-23.png upload_2024-7-19_19-1-55.png upload_2024-7-19_19-3-18.png upload_2024-7-19_19-3-56.png upload_2024-7-19_19-5-21.png upload_2024-7-19_19-6-3.png upload_2024-7-19_19-6-34.png upload_2024-7-19_19-7-27.png upload_2024-7-19_19-8-52.png upload_2024-7-19_19-9-17.png
  9. Just Gary
    Just Gary
    My MIG-welded headers have 5/16" thick flanges from "Headers by Ed" with 3.5"x10" collectors and 16 ga, 1 5/8" primary tubes using 2.5" radius mandrel U-bends from Summit.
    20190704_123009_HDR(1)(1).jpg 20200207_161450_2.jpg 20200129_193055_HDR_2.jpg 20200212_190112_2 (1).jpg 20240404_181011.jpg
    GordonC, slayer, jet996 and 18 others like this.
  10. willys36
    willys36
    Mysterion reproduction
    engine header assembly.JPG engine header mockup.JPG P1010316.JPG P1010319.JPG IMG_1718.JPG
    Willys
    For small 331 heads. Put new heads with bigger ports so made the ones below
    New big tube headers for the Willys
    '36 Pontiac with 230 straight 6. Excuse the ******X front end!!
  11. Frames
    Frames
    Building a 32 roadster with a 365 Cadillac engine. Sprint car type headers. Smoothing the welds for chrome plating. My own flame cut flanges. 2024-07-17 21.48.26-1.jpg 2024-07-17 21.48.26-2.jpg 2024-07-17 21.48.26-3.jpg
    jet996, pbr40, dana barlow and 6 others like this.
  12. Frames
    Frames
    302 G M C. 2 center pipes 2" because they have to serve 2 cylinders each. Engines-parts (44) 040.jpg Outer pipes 1.75" because they only serve 1 cylinder each.
  13. willys36
    willys36
    Consider Jet Hot instead of chrome. This stuff is amazing. Have headers that are unblemished and still bright after 20 years. IMG_1590.JPG
    jet996, whtbaron, dana barlow and 9 others like this.
  14. Frames
    Frames
    Lots of headers I built have been ceramic coated.
    mad mikey, willys36 and Pist-n-Broke like this.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    adv23t098.JPG Here are two I've done.
    One on my avatar champ car; one for my altered roadster drag car.
    I used stainless steel on both of these.
    jet996, Gotgas, Ned Ludd and 12 others like this.
  16. Frames
    Frames
    Full race 47 Ford. 2" center pipe split length wise to form taper. 2012-11-03 17.53.52.jpg 2012-11-03 17.53.54-1.jpg
    jet996, whtbaron, dana barlow and 7 others like this.
  17. Paul
    Paul
    Editor
  18. Paul
    Paul
    Editor
  19. Paul
    Paul
    Editor
  20. -Brent-
    -Brent-
  21. patsurf
    patsurf
  22. Marty Strode
    Marty Strode
  23. Marty Strode
    Marty Strode
  24. -Brent-
    -Brent-
    @Tex***peed fabbed it!
  25. big duece
    big duece
    from kansas
    20240720_132653.jpg You didn't mention scale, does 1/8 scale count?
  26. Paul
    Paul
    Editor
    and new headers to fit.
    I don't know who built the new headers
    or if they cut mine up to do it.
  27. Paul
    Paul
    Editor
  28. Paul
    Paul
    Editor
  29. 69fury likes this.
  30. Budget36
    Budget36
    That’s pretty intense!
