Hot Rods Let's see your headers. Custom built only
Discussion in 'The Hokey Ass Message Board' started by Frames, Jul 19, 2024.
  1. Russ B
    Russ B
    ‘way, way too loud
  2. X-cpe
    X-cpe
    Waiting on a leak check and white paint.
    slayer, pbr40, dana barlow and 4 others like this.
  3. TCTND
    TCTND
    Lakes style for 394 Olds. Not in use so for sale if anyone is interested.
    mad mikey and X-cpe like this.
  4. Marty Strode
    Marty Strode
    Those bulbs are 2 piece, form fit together, and not welded. I think they are for expansion, and allow flex to keep the pipes from cracking due to heat and vibration. It's a "Stunt" Plane.
  5. badshifter
    badshifter
    I build all my own headers, exhaust systems etc. Rarely take pictures. A few of them are HAMB friendly ish. I rebuilt / restored the Bathtub headers and built the Zoomies on the Redd Wrecker.
    IMG_6248.jpeg 59831449107__5704EC52-AA60-4B16-B438-547A819F134E.jpeg IMG_6274.jpeg IMG_3138.jpeg IMG_5941.jpeg IMG_1308.jpeg IMG_6248.jpeg 59831449107__5704EC52-AA60-4B16-B438-547A819F134E.jpeg IMG_6274.jpeg IMG_3138.jpeg IMG_5941.jpeg IMG_1308.jpeg IMG_6259.jpeg
    Tim, jet996, Fitty Toomuch and 13 others like this.
  6. willys36
    willys36
    Tim, osage orange, jet996 and 9 others like this.
  7. greybeard360
    greybeard360
  8. Marty Strode
    Marty Strode
    Tim, jet996, whtbaron and 18 others like this.
  9. Oh my, is that a Wayne head I see?
  10. Marty Strode
    Marty Strode
    jet996, bymanr, whtbaron and 7 others like this.
  11. Marty Strode
    Marty Strode
    slayer, jet996, Blown Red Ram and 8 others like this.
  12. dana barlow
    dana barlow
    from Miami Fla.
    Built a lot of custom headers,and like how custom looks vs same old aftermarket repetes. So I stared looking for old pic's,but looking like I have lost one of my many albums at some point!.
    Only found a few, the set of pic's I wanted too find are gone maybe.
    Back in the 1960's,I had a Studebaker Lark Daytona that I dragged race some, { Super charged,4 speed with TT } I ran NHRA F-Stock* with,the cl*** was legal with custom hearders added> So I built my own<none after market at the time anyway,,! I made my own with 4 tubes pre side* vs Studebaker heads have sim-center EX ports so would be 3 tubes by most.. But I built my headers with a tongue* as part of the center headers two pipes< that did stick in to head an divided the sim EX { fitted very close the inter port shape. Being a welded part of the headers*,and not the Study head,made it legal. Worked well,matched the NHRA Record.
    Over the years,an lots of miles on my old high school hotrod,a number of hearder set have gone bad/by uses. Each time,I'd try a little def. design=more for a bit of new look then anything. This last set I made,for the Ford "Y" V8 engine in my old rod,I cut up a set of Chevy SBC V8 chromed headers,I got for free,from my buddy Rosh{ I had help him built a 23T w 350 SBC years back. He cracked a chrome EX tube were it was welded to header plate,and just went an got a brand new set. He gave me the broken SBC chrome set.
    To his shock,I held them next to Ford "Y" block head,an screwed the end bolts in=with out doing anything; yes Ford has same end EX spacing. The center how ever,Ford use's a bolt between center pipes{ with little space between center EX ports}, So I just cut off the chrome SBC headers from the Chey EX flange, pushed the center pipes apart a little ,an welded them to Ford "Y" block flange,making sure the angel was right for Ford "Y",an painted sliver the welds n flange . Low $ chrome Ford Y hearders.:D:cool: Bobtail 28 roadster DB's.jpg Welding an cutting up tubes,can also be for intakes, I've seen some nice log intakes over the years. Did a few my self ,the 4x2 you see on my old high school rod, I made by cutting up a drive shaft*welded to gether=that made just size log I was looking for.
    slayer, jet996, Gotgas and 5 others like this.
  13. Bcap55
    Bcap55
    from PA, USA
    I needed a set of Lake headers for the Olds motor on my coupe project. I used a kit for a SBC that had a tapered section that was the right length that I needed.
    The header flanges I used from Hell's Gate to fit the Olds motor have square ports, so I made a die to form the ends of the tubes to fit.
    Here it is all welded up.
    I added bottom dropouts to run to mufflers under the car. I made my own flanges for the dropouts.
    slayer, jet996, X-cpe and 4 others like this.
  14. Marty, You do know how to get my attention, is this a current build going on?
  15. Marty Strode
    Marty Strode
    Mike I sent you an email with the details.
  16. Marty Strode
    Marty Strode
    slayer, jet996, whtbaron and 7 others like this.
  17. 1935ply
    1935ply
    from peyton,co
    IMG_0043.JPG 6133996[/ATTACH] headers into '36 driveshafts, no mufflers. IMG_0130.JPG IMG_0043.JPG
    Tim, osage orange, jet996 and 5 others like this.
  18. Russ B
    Russ B
    ‘and below, the same car with a different engine a few years earlier
    For this, I did header runners into a 4” collector. The Buick was not too wide for the frame, but required a little clearancing to get equal lengths.
    Back in the sixties, ready made headers were available for relatively few applications. Building your own was not uncommon as it is nowadays. Block hugger designs have become the norm as they often clear steering for many different applications.
    jet996, dana barlow and X-cpe like this.
  19. 69fury
    69fury
    from Topeka
    Just Gary likes this.
  20. Flatrod17
    Flatrod17
    I started to make headers for my Ardun, but could not figure out how I wanted to get to where I wanted to be on them. This is as far as I got, it's on the back burner for now. 7-21-24-1.jpg
    whtbaron, dana barlow, X-cpe and 2 others like this.
  21. Marty Strode
    Marty Strode
    215 Buick in a 32 sedan, couldn't make them a real Tri-Y, but the customer is happy. IMG_7994.JPG IMG_7992.JPG
    slayer, jet996, neilswheels and 8 others like this.
  22. ironandsteele
    ironandsteele
    You have built a lot of really nice-looking headers, Marty! I recently purchased a car that came with a set that I think you did. A lengthened Model A Roadster with a Hemi mocked up in it, ring a bell?
    ironandsteele.com​
  23. jimmy six
    jimmy six
  24. The37Kid
    The37Kid
    1975 seams like a long time ago sometimes and just yesterday on others. DSCF8210.JPG
  25. Harv
    Harv
    from Sydney
  26. Marty Strode
    Marty Strode
    Yeah, that belonged to Pete Balch. I still have the collectors with his name on them. He was getting on, when I fabbed all of the center crossmembers too. I have photos of all the work. Donn Lowe did the sheet metal modifications.
    Blown Red Ram and Just Gary like this.
  27. I came across this photo and had to stop for a moment and thought, "what am I looking at here"? Then I remembered. I had to make space for the clutch linkage and room to adjust it, be able to get the Clutch out without removing the headers and stay above the bottom of the frame rails with everything. I did manage to get that done but Geezz! Give me a Hot Rod without fenders any day.
    jet996, Bcap55, dana barlow and 3 others like this.
  28. Just Gary
    Just Gary
    They're ET Cl***ic V's.
    I ordered them with minimal backspace to look extra deep, like a '60's dragster, then narrowed the rearend to fit. Most people do it backwards; installing a rearend first, then searching for wheels and tires to fit.:rolleyes:
    To stay on topic, here are two more header under-construction pics:
    slayer, akoutlaw, 6sally6 and 3 others like this.
  29. alchemy
    alchemy
    My recreation of Heddmans for use in a '32 Ford with a 409. Custom machined plates, mandrel bent tube, lots of hand fitting.
    Tim, jet996, akoutlaw and 6 others like this.
  30. Marty Strode
    Marty Strode
    One of my current projects. IMG_0593.JPG IMG_3987(1).jpg IMG_4837.JPG IMG_4925.JPG
    brandon, Tim, slayer and 11 others like this.
