Let's see your "paintin place"....
Discussion in 'The Hokey Ass Message Board' started by the other me, Dec 5, 2011.
  1. john mullen
    john mullen
    painted this outside with ppg midnight black laquer
      466.6 KB
  2. Sphynx
    Sphynx
    from Central Fl
    I like you white walls very traditional.
  3. evintho
    evintho
    It's not mine but this has got to be the ultimate portable paint booth!
    Joemama likes this.
  4. The37Kid
    The37Kid
    Everyone with a warehouse for a garage should have a fold away booth like that! Thanks for posting the photos.:D
  5. Skcollob
    Skcollob
    from UK, Kambs
    Mine's a small garage, very little room around the car and dusty. But given the "full Dexter" and a wetted floor and a paper suit I can get a good wet coat or two free of flying ****. Soon as the floor dries, bits start landing in the paint. I do some bits outside, actually get less h***le with dust and kamikaze flies etc.
    Love that colour Chevy54... can I ask what it is? Looking for similar to 2-tone my wagon.
  6. MP&C
    MP&C
    Devilbiss semi-downdraft booth..
  7. Deuces
    Deuces
    You don't want to see my spray booth....
    All it is, is a cardboard box... :rolleyes:
  8. aerocolor
    aerocolor
    from dayton
    I use the workplace booth. Very handy.
      486.5 KB
  9. palosfv3
    palosfv3
    Our hide out.
  10. Cylinder9
    Cylinder9
    I do most of mine in a commercial spray booth.
  11. Chevy54
    Chevy54
    from Orange, CA
    Great idea!
    Thanx bro, its a mid 30s Ford color called Cordoba Tan!
  12. CharlieLed
    CharlieLed
    I have had many versions of "paintbooths" and it was always a problem when venting air outside the "booth"...or garage as my neighbors knew it. I made this recycling air filter some time ago and have been very happy with its performance. Lower box has two stages of filtration; first is a paint arrestor material backed by a MERV 11 filter. Upper box has 3 inches of activated carbon and a set of regular paint booth inlet filters. I paint in a closed 2-1/2 car garage and this air unit will recycle all the air in the garage 3 times per minute with no overspray anywhere in the garage...not even dust. Best of all the neighbors never know when I am painting...no overspray and no smell.
  13. Skcollob
    Skcollob
    from UK, Kambs
    Eric, thanks :cool:
    cheers
    Bill
  14. Rod Ari
    Rod Ari
    from Finland
    My booth from early last spring. It wasn´t too cold, there was no flies or dust but there sure was use for rubber boots.
    Rod Ari
  15. D-man313
    D-man313
    Paintbooth!! We dont need no stinkin paintbooth!!:eek::D
    Final product
  16. D-fens
    D-fens
    from Huntsville
    Since I used to do sheetmetal and HVAC I should have already thought about something like this, but didn't.
    Thanks Charlie.
  17. Hdonlybob
    Hdonlybob
    Here is mine....certainly not fancy, or professional, but works for me......:)
    Cheers....
  18. R Frederick
    R Frederick
    from illinois
    My garage after a good sprayin' on my kid's o/t car. Little dusty, but it cut/buffed fine.
  19. williebill
    williebill
    More details,please?
  20. derbydad276
    derbydad276
    this one of the best ideas I have seen in while ! the only omprovement I would make on it would be to use light weight steel studs and FRP board
    to save weight
  21. JustJoey
    JustJoey
    Funny you say that, I did some painting in my garage last week with plastic sheeting setup. My wife said it looked like a kill room with the red overspray everywhere.
  22. CharlieLed
    CharlieLed
    Yeah it's kinda funny you should mention the HVAC...I hadn't planned on building it this way but I have a buddy who is in the trade and he took my measurements and turned them in on a work order with another big job they were doing. About 10 days later he shows up with the 18 ga ducting in the back of his truck...it sure made my work easier. I added a 1 x 2 box steel frame to the underside of the lower cabinet to strengthen the unit and to hold the casters.
    I used a 1 HP blower (available at Grainger, etc) and wired it up for high and low speed. In the circuit box on the air recycler I placed the on/off/speed switch and another outlet so that I could plug in lights or other devices as needed. I welded up some angle to hold the paint arrestor material, it comes in 300 ft rolls and is fairly cheap to buy...it only needs 5 ft to cover the intake. It is fairly common for air filters to be supplied in a 20 x 20 inch size so the lower unit is 3 x 20 and the upper is 2 x 20. I built a tray that holds the activated carbon (bought the carbon on ebay, overstock on a PA water plant)...this is basically the same stuff that is in the dual-filtration masks you buy for painting. The upper cabinet has a couple of regular paint booth intake filters on the outlet door that are there just in case some carbon particles break free and want to come out in the air return flow.
    I built this unit a few years ago and had it posted here right after I finished it. I got the usual concerns about "blowing yourself up", etc for using a non-sealed blower. Given the low volatility of the paint I use and the ultra-low concentration of vapors there is virtually no chance of combustion. Just thought that I would mention this point for those who may be thinking about those concerns.
    I have found another use for this unit quite by accident...one day I was working in the garage and it was a really hot day. I turned on the blower just to move some air around in the garage and I noticed that all the dust off the panel that I was sanding got ****ed up in the filter. Now I run it even when I am not painting but making dust, keeps the garage a lot cleaner.
    I sure wish that I had enough room in my garage for that folding wall setup, that is really cool.
  23. R Frederick
    R Frederick
    from illinois
    They don't show pictures of the three days it took to move all the garbage away from the wall so that it could be pulled out.:D
  24. CharlieLed
    CharlieLed
    I hear that...I just spent the last two days clearing out my garage so that I can paint my 56 F100 and it's in pieces. I sure would like to have that much room to work...
  25. bulldogcustomchrome
    bulldogcustomchrome
    women can be so touchy- Where are there priorities?Nice paint job, purple clothes. I don't see the problem.
  26. bulldogcustomchrome
    bulldogcustomchrome
    Love those respirators.
  27. bulldogcustomchrome
    bulldogcustomchrome
    That's actually a nice design. There is something similar on the market that has fire suppression and a plastic curtain and ceiling that are collapsible. If you google mobile paint booth you can find them. But when I looked into them they were around $15 grand.
