Technical Let's talk 283s again...
Discussion in 'The Hokey Ass Message Board' started by Dave G in Gansevoort, Oct 12, 2023.
  1. Dave G in Gansevoort
    from Upstate NY
    Yeah I know that one. Bought the 265/283 book of HR magazine articles a while back. There's another HUGE 283 modification article that does a stroker crank AND huge overbore, where they cut the bores completely away and weld in new cylinders!
    ratrodder's 400 started life as a Gaerte built WOO engine. Rodec 350+ block, but it had too many heat cycles and the head studs wouldn't stay put! The heads have ports and valves that could feed a potent 454. Solid roller, chosen for the last rebuild for use in a hillclimb special. We were shooting to detune it a bit, and get more 4000 to 6500 rpm range and give up the 8000 max of before.
    As a final note it's now using a factory block that ratrodder has had machined for all of the good parts. I did keep the front drive set-up however. Gear drive for the cam, dry sump system, crank driven water pump, and a place to run the Hilborn pump.
    Never know what I may do with that...
    The Chevy Pope likes this.
  2. Yeah when I got that issue of harm(1959 iirc) I had no idea anyone was punching them out that far at all. And the mention that 350 strokers were already commonplace threw me off too lol
  3. ratrodrodder
    ratrodrodder
    from Boston
    You're right that it is just sitting around... Still needs some additional ***embly, too. I have no idea where my rod bolt stretch gauge is packed, either. You say the word and I can get a long-term loan set up for you, great terms too! :D You'll have to get that front suspension back together first, though.
    I'm guessing that if you can keep your foot out of it for the first 30 feet or so, the T5 will last for a little while...but you probably know that better than I do. :)
    Dave G in Gansevoort likes this.
  4. Dave G in Gansevoort
    from Upstate NY
    That's why I also have a T10 in the garage. It might last a little bit longer...
  5. tomcat11
    tomcat11
    Here's one for fun..
  6. Dave G in Gansevoort
    from Upstate NY
    That's one nice sounding small block! Going in a Tri-5 by chance?
    GlassThamesDoug likes this.
  7. alanp561
    alanp561
    Sounds like the engines had heat exchangers. They're probably worth more than the engines. The ones I had on my twin 283 powered Chris Craft were all br*** and heavy. The boat came from Long Island, NY. When I rebuilt the engines, the inside of the water p***ages was squeaky clean.
  8. tomcat11
    tomcat11
    Well there is a Tri-5 in the background but I don't really know. I just read through your thread and remembered seeing that video. I really don't like looks of the 6V stacked on the tunnel ram and the drive hanging way out there like that, but it sure rev's quick with the 3.00" stroke and 12% overdrive. Gotta love those short stroke SBC's.;)
  9. 283john
    283john
  10. GlassThamesDoug
    GlassThamesDoug
    Deuces, 283john, deuceman32 and 2 others like this.
  11. Dave G in Gansevoort
    from Upstate NY
    Deuces, 283john and 427 sleeper like this.
  12. Dave G in Gansevoort
    from Upstate NY
    Update: I now have 4 small flange 2G Rochesters, a spare top, a conversion kit for the carburetors and an Edelbrock 3 deuce intake manifold. Oh, and an ultrasonic cleaner to get the carburetors cleaned up. That's an over the winter project. I don't remember if I wrote about 1975-76 262 V-8 heads previously, so I'll mention it here.
    According to Hot Rod magazine from when they were current, those teeny tiny little engines had heads based on the then current 350 heads but with changes to make them work on a small bore, small displacement engine.
    The ports and overall castings were kept the same, however the combustion chamber and intake valves were reduced in size. The ports were still around 170 cc, the valves were 1.84 inch diameter, exhausts stayed at 1.5 inch diameter. Best of all, the castings were still the "heavy" castings. The combustion chamber was alleged to be 58 cc, but I'd guess that they were a bit larger.
    Compared to the stock 283 heads however, these would be a good upgrade. I don't know if the early 305 had these heads. I'd like to get a set of these, if possible, to at least see if that information is accurate. Being a 2-year only option, and even if the 305s had the same heads, this might be a fool's errand. So if anyone has a 262 or early 305, mostly unmolested, and willing to dispose of it/them, let me know.
    Thanks
    deuceman32 likes this.
  13. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The early 305s did not. It wasn't until the early '80s that the 305 heads with 1.84 inch intake valves and small chambers came along.
    Deuces and Dave G in Gansevoort like this.
  14. Deuces
    Deuces
    The 416 305 castings were out in '76-'77..... I have a couple of sets... 1.84" intakes with 1.50" exhaust valves.... And 57-58cc chambers.....
  15. Dave G in Gansevoort
    from Upstate NY
    Care to share a pair? Good rhyming, don't you think...
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    From 1976-78, Chevrolet listed one intake valve for all 262s and 305s. It was 1 . 20241010_131423.jpg 72 inches. The only difference in the other part numbers listed here are .0015, .003, and .005 oversize stems.
  17. Deuces
    Deuces
    I'm gonna hang onto those till I get some things sorted out.... Sorry....:(
  18. Deuces
    Deuces
  19. Dave G in Gansevoort
    from Upstate NY
    Thanks to ididntdoit1960 I now have a set of 1962 power pack heads for the 283. I've got a bit of effort to expend on them before they go to the engine shop, and some decisions to make regarding some modifications, but moving forward.
    So here's some of the areas that need work: seat, guides, stud bosses, gasket surfaces refaced, of course start with degreasing and magnaflux. Port matching, and all of the usual steps. Those chambers look nice and small, so compression with flat top pistons should be able to get into the 9-9.5:1 range. Compatible with the ethanol free gasoline available around here. Induction will be 3-deuces and I'm thinking roller cam. Been investigating street solid rollers, as I don't mind the occasional setting the valves. There's some solid rollers available with bronze bushings instead of needle bearings. These should be more amenable to street use. I'm not too fond of needle bearings in an application that can have some intermittent oiling issues.
    The only down side, can't use those staggered bolt pattern valve covers with the Chevrolet script on them. Guess I'll have to use the set of Corvette valve covers instead!
  20. DDDenny
  21. blue 49
    blue 49
    from Iowa
    Staggered bolt CalCustoms adapted to my 327.
    Gary
    Deuces, GlassThamesDoug and Sharpone like this.
  22. GlassThamesDoug
    GlassThamesDoug
    Yes you can, there are nice adapters out there for staggered to straight.
    Dave G in Gansevoort and rod1 like this.
  23. Dave G in Gansevoort
    from Upstate NY
    I imagine that the adapter looks like a valve cover gasket made in aluminum with a countersunk hole for the straight across bolt on the staggered side, and a threaded hole for the staggered hole. I suppose if I decide to get another set of the aluminum Corvette heads I could use a similar adapter from center bolts to staggered bolt pattern valve covers.
    You guys know that it's a sickness, right? Our need to keep collecting parts for the next project...
  24. GlassThamesDoug
    GlassThamesDoug
  25. Dave G in Gansevoort
    from Upstate NY
    Those look like they go from staggered to straight across. The countersunk holes are the staggered pattern. But they look like what I imagined. Thanks for posting. Where was the listing? Any links?
  26. GlassThamesDoug
    GlassThamesDoug
    Several companies make them for both applications. JEGS above.
  27. HOTRODPRIMER
    HOTRODPRIMER
    This 283 was in the 1932 fordor I traded with Ron for my 1932 Tudor street rod, I honestly don't know anything about the engine but I do know that it ran like Jack the Bear! HRP
    Deuces, slim38, 427 sleeper and 2 others like this.
  28. Dave G in Gansevoort
    from Upstate NY
    Thanks... Christmas presents coming soon!
    427 sleeper likes this.
  29. Dave G in Gansevoort
    from Upstate NY
    Ooo-wee, I'll have more in the adapters than I currently have in the heads and valve covers I'm going to use!
  30. GlassThamesDoug
    GlassThamesDoug
    Yeah.... why use staggered valve covers, since everyone makes both. Swapmeets have baskets of both. I bought adapters for faux 56 Jr Stock engine.. no other reason.
