Hot Rods Let's talk Cadillac 331's, 365 and 390's
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 7, 2016.
  1. Mike Paul
    Mike Paul
    do you think a guy can get away with stock valve covers and rocker shafts with a .480” lift? I’m looking at the same cam setup with 390 heads. 1.6:1 ratio
    Roothawg likes this.
  2. Roothawg
    Roothawg
    It's not the amount of lift that causes it to hit the valve covers, it's when you convert to adjustable rockers.
    Mike Paul likes this.
  3. WTF really
    WTF really
    Will a 1957 water pump fit a 1956 365 engine? I need the water outlet on the p***enger side instead of the drivers side.
  4. 42merc
    42merc
  5. WTF really
    WTF really
    Awesome thanks I appreciate it.
  6. warbird1
    warbird1
  7. WTF really
    WTF really
    Torkwrench, MOTOV8N, cretin and 3 others like this.
  8. cretin
    cretin
    The UPS man brought some good stuff today.
    Torkwrench, WTF really, rod1 and 5 others like this.
  9. Roothawg
    Roothawg
    Santa came early!
    cretin likes this.
  10. WTF really
    WTF really
    I want to see if anyone in here would be interested in this 1955 remand water pump before I list it for sale. 200.00 plus shipping. 20221128_110727.jpg 20221128_110741.jpg 20221128_110748.jpg 20221128_110801.jpg
  11. x77matt
    x77matt
    only other thing to check- 1957 had the timing tab and the balancer mark on the opposite side to avoid the pump inlet. I’m not sure if you can see your timing marker with a 57 pump on a 56 setup easy. Might be good to double check that to be sure
  12. WTF really
    WTF really
    Awesome thanks. I will definitely check that out.
  13. WTF really
    WTF really
    This is the adapter on my engine now. It came out of a 40 coupe. Is there a way to adapt this the a Muncie or will I need one of the high priced kits? 20221201_115005.jpg 20221201_115012.jpg 20221201_115027.jpg 20221201_115034.jpg
  14. wheeltramp brian
    wheeltramp brian
    That one is to adapt it to the stock Ford transmission. You will need to get a different one to convert to the Muncie I believe
    WTF really likes this.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    OR...you could buy one of the flathead to G.M. four speed adapters that's currently available and bolt it to your existing adapter.
    lumpy 63 and warbird1 like this.
  16. WTF really
    WTF really
    I'll research that. Thank you
  17. WTF really
    WTF really
    One like this? Would I use the clutch and pressure plate already in it? Screenshot_20221201-193443_Chrome.jpg
  18. wrenchbender
    wrenchbender
    The disc will probly be different but you can still use the pressure plate. And yes that is the adapter you need
  19. WTF really
    WTF really
    Awesome thank you for your help
  20. devilscustom
    devilscustom
    from Sweden
    Anyone having a cad file for
    Cadillac 331 (Early) Exhaust Flange?
  21. sheparj2
    sheparj2
    Hi all. Finally found an Un cracked head and got my truck running with this 390 Cadillac. Issue I’m having is I keep blowing my lower radiator hose off. I have a 16psi cap. I plugged the heater inlet and outlet on my water pump because I don’t currently have a heater on my truck. Is 16psi cap too much? Im just running straight water because im tired of dumping antifreeze down the driveway…. Any ideas?
  22. Roothawg
    Roothawg
    There's something else going on there......the cap shouldn't make it do that, regardless of the pressure. It has to be getting hot in order to build that much pressure. How hot is it running? Pull the dipstick and make sure there's no water in it.
  23. sheparj2
    sheparj2
    . I’m only running it a few minutes. Gauge says lower than 195.
  24. Roothawg
    Roothawg
    Can you see coolant flowing if the cap is off?
  25. sheparj2
    sheparj2
    Yes. After a few minutes water was moving.
  26. sheparj2
    sheparj2
    Actually. It is moving but not like you would think. Thermostat is brand new but maybe it’s a dud. Maybe I’ll take it out and remove that variable
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    does the water pump have a byp***? I don't remember. I have the heater hose fittings plugged on mine too, but If I know myself, I probably drilled a couple of 3/16 holes on the outer part of the thermostat for a byp***....
  28. sheparj2
    sheparj2
    A byp***? What would I be looking for? I was wondering if my plugging did something unexpected. That was my concern
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    I don't know if those pumps have an internal byp*** or not (a route for the pump to push water when the t stat is closed) Maybe someone else here will know. I always drill 3/16 byp*** holes in my thermostats, It makes filling initially easier with less or no air burping... and gives a route for the pump to move water when the stat is closed. I don't know if that is the problem or not though...
  30. Roothawg
    Roothawg
    Before the cracked head, did the radiator seem to be ok?
