Customs lets talk coils why do i keep going threw them?
Discussion in 'The Hokey Ass Message Board' started by Gambino_Kustoms, Nov 15, 2011.
  1. hotroddon
    hotroddon
    Yes, internally resisted to 1.5 ohm. Internal resistance coils can vary from .2 to 3 or more ohms depending on applications (there are probably others that are outside of those parameters, but not common)
    Just because it says it's internally resisted doesn't mean a whole lot - you need to know What the resistance is. Truthfully, the Ignitor will run with a 3 ohm internally resisted coil, it will just have a lower spark energy.
    To your original question about why you are burning up coils, well, more info is probably needed. Is there a chance that voltage is still being supplied to the coil after the car is shut off? What position is the coil mounted in/ Where is the coil mounted? Are you using cheapo Chinese coils?
    Etc.
  2. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    i dont leave the key on, except when i brake a ball joint at 65 and the car died :D
  3. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    the ciol is up side down and yes it was a cheepy i bought in flagstead az on the way to kansas im gona get the correct coil now that i understand this better but for my trip tomarrow to andy brizios xmas party im gona tryu and get a 6o's ford internaly resisted job !
    thanxs
  4. hotroddon
    hotroddon
    If you can mount the coil terminal side up, that will help as well. many coils don't have enough oil in them and they get hot when they are upside down and that can be a problem. Also they can weep oil out which only compounds the problem.
  5. GMC BUBBA
    GMC BUBBA
    WOW 34 posts and we are all over the place with the good , bad and ugly answers.
    If you are eating coils on any vehicle the problem is always the same ....too much HEAT !!!
    And the heat always comes from using a incorrect resistance in the primary circuit of the ignition. Causing a very high primary current!!
    Number one cause of incorrect resistance is incorrect part ( either chinese or just the wrong part) usually with a very low resistance ( less than 1.5 ohm).
    Typically you need for your application a 1.5 ohm ignition coil, oil filled is fine.
    AND shouldnt make any difference on how the coil is mounted as ONLY a defective coil will allow the oil to run out.
    Send me a pm and i will send you a american made ignition coil with 1.5 ohms and oil filled to try out on your vehicle.................love to help anytime we can
  6. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thanxs ill change it back right side up i did it that way for a reason i forgot now when i was on the side of the road some thing was short and it work up side down
  7. GMC BUBBA
    GMC BUBBA
    After some more thoughts here there is another issue that might cause this problem..
    "you said its hard to start and after a while wont start at all"
    Lets say theres a wiring problem ( ie : coil wire, connection in the plug wires, rotor or somewhere in the secondary plugs wide gaps etc) that requires a very high coil voltage all the time.
    This would make it hard to start and the coil being operated with high voltage all the time would weaken with use and heat, and then not be able to supply this high voltage anymore .
    A fresh coil would be good for a few starts etc and then fail as well.....
    Just some more thoughts ?????????:eek:
  8. hotroddon
    hotroddon
    While you are right it SHOULDN'T make a difference, I have seen MANY coils, from many different manufacturers (including Andover) leak oil when mounted upside down or vertically. It should never happen if the coil is made right, but the fact is it does happen occasionally and an easy precaution is to not mount them upside down and take the risk - even though you shouldn't have to.
    Hell VW's came mounted upside down and Ford mounted them vertically, but unfortunately quality isn't what it once was in the world of coils. ;)
    Also make sure you have good quality plug wires, not some old solid cores or something that has high resistance
  9. chrisntx
    chrisntx
    from Texas .
    I thought Pertronix was in Ponca Oklahoma????
  10. hotroddon
    hotroddon
    Uh, No - Always been in So Cal - since the original company, Per Lux was founded in 1962
  11. Ice man
    Ice man
    Yea, had the same problem with my 29. I'm running a 2.5 AMC 4 banger with a dizzy from FS Ignition. A coil came with it but did not last long and then went through 4 coils from NAPA. Tired of it, I called Bubbas in Indy. He sold me a coil and said that would be the last coil I would need. Well so far its been there for a good while and like he said, its been the last coil I need. Knows his stuff and he a straight shooter. Iceman
  12. Engine man
    Engine man
    from Wisconsin
    I have a 1980 lawnmower with a Kohler engine that had the coil mounted upside down. The coil failed in 2003. Picked up a coil at NAPA that was supposed to be an internal resistance one listed for the Kohler engine. Mounted it in the original bracket and it died in less than an hour with oil running all over. Tried mounting a replacement terminals up. It lasted about 4 hours. We tried several different coils with no luck. Finally I dug into some boxes of old parts and found a coil we pulled off a 66 Chevy 327 before we put it in a race car. I put it on to finish mowing the lawn and it's been on there ever since. Today's parts are ****. It doesn't matter where you buy them, they likely all come from the same place.
  13. need louvers ?
    need louvers ?
    had a situation I alueded to earlier where the Plymouth started eating coils... in the worst possible places! Generally, over fifty miles from anywhere. It is a complete, matched M.S.D. system with they're recomended coil and all. After the second go round, in a completely different dimension of pissed off, I called they're tech line and as calmly as possible explained what was going on. The first question was "how is the coil mounted?" On a bracket, on it's side, was my answer. The recomendation? Same coil, just get the ceramic filled. Explanation, when an oil filled coil is layed on it's side, it exposes a large potion of it's windings as the oil runs to the low side, giving the dry coils a chance to heat up and burn down. I did what I was told, and bought the ceramic filled coil... 100,000 miles ago!
  14. Go back to good American made points/cond (I buy 5 sets at a a time NOS on line), American made coil, the proper ballast resister....and you'll die of old age before having any problems. Sorry, but electronic ignition is like old days "snake oil" hype. An efficient points system will give you fair warning of any on coming issues. An electronic system, while OK when it works, gives you NO SUCH WARNING. It just leaves you stranded.
  15. MercDeuceMan
    MercDeuceMan
    from Indiana
    Groucho is right..
    Better go with GMC Bubba. He already made you an offer you can't refuse, not to mention he knows his **** too....
  16. hotroddon
    hotroddon
    I doubt it is "Ceramic" filled, most likely Epoxy.
    As for side mounting, it can be fine with a good oil filled coil, but the terminals should be mounted horizontally, not vertical. When it is vertical is when you can have a problem with the winding above the oil level. Cheap coils that leak, or that don't have enough oil will still be a problem.
  17. need louvers ?
    need louvers ?
    You are right Don, epoxy filled. Been awhile since I have bought a coil, i guess. interesting thought on the clocking of a coil layed on it's side, and makes perfect sense. I took a look at the Plymouth right now and gues how the terminals are clocked?! All I know is with the epoxy filled, what was frequent problem became a non issue... After quite the learning curve!
  18. big creep
    big creep
    hey don are the pertronix coils epoxy filled?
  19. Rich Rogers
    Rich Rogers
    big creep, they are either oil or epoxy filled . I had a similar issue with a pertronix coil. Not being able to get one here fast enough I called Pertronix and spoke to a tech. The 1.5 ohm coil CAN be replaced and work fine with an Accel super stock coil of 1.2 ohm ( but no lower). It's been on there now for 3 years with no trouble.
  20. hotroddon
    hotroddon
    We offer both Oil Filled and Epoxy filled coils
  21. bobss396
    bobss396
    I also prefer to get the coil off the engine and mount it to the firewall, less heat and vibration.
    Bob
  22. GMC BUBBA
    GMC BUBBA
    Ok lets handle one myth after tha other .
    First and foremost the oem maker of the coil will install the correct amount of oil per coil and then vacuum test the unit to test for leaks.
    Once properly filled the coil will operate as designed with no exposed windings , no bubbles and work in any position.
    If the seal does leak now we have a problem with windings etc.
    So in reality only a defective coil will have a problem with windings.
    I have a tool box full of defective coils from just about every manufacture of coils, the worse being in the last couple years with the off shore (chinese ) made units. One brand actually told me they were all made in china and approx 50% failed testing when recieved at the factory, however they were so cheap ( meaning high profits) that was acceptable.......
    WOW i couldnt live with that one.....:eek::)
  23. hotroddon
    hotroddon
    Correct, if they are manufactured properly every-time this is true, Unfortunately Quality Control with many of these coil manufacturers is not what it should be ~ we have cut apart coils from every manufacturer and found inconsistency's - some worse than others obviously.
    The other problem is the consumer. If you check with Summit or Jeg's or any other large retailer of performance products, you will find that inexpensive coils out sell the expensive ones by a zillion to ones (OK slight exaggeration). If you look at what most of the name brand coils sell for (between $22.00 and 40.00) you will see that is where the market is. When you figure out the economics of a manufacturer distributing a product through the normal channels, where each step needs to make a reasonable profit to stay in business you will quickly realize that the only remaining American Coil manufacturer cannot, or is unwilling to, compete and this requires foreign sourced products. The other American ignition companies took their production overseas as well, or pulled out of the business all together.
    The problem with coils in the market place is the consumer and his perception of value. If we offered a canister style coil that was above reproach in quality and US made it would have to retail for about double what the current market trend is. The consumer can't see, and therefore can't justify, the difference in a $25.00 coil and what would be an $80.00 price tag. It is an unfortunate consequence of the perception of the product and the value the consumer sees. As long as there are other countries that are willing to subsidize their manufacturing companies and economies that allow for people to earn the equivalent of as little as $4.00 a day, and we don't put a tariff on such products, then the consumer will continue to drive the market by buying such goods and continue to make WalMart the largest retailer in the world and car companies like Kia and Hyundai to thrive and overtake domestic brands.
    Sorry to have taken a slightly political slant, but this is the reality of ignition coil manufacturing and sales in the US.
  24. Never2low
    Never2low
    At the risk of sliding waaaaay off the "on topic" cracker and starting a **** storm of foreign policy and political rants. My former employer did the exact same thing. Buying US castings, machining them, and selling them, proved not to be cost effective. They found a "competative" casting supplier in China. After almost a year of completly unusable castings, they eventually got them close enough. By this time, it was established that the castings could also be machined abroad, as well. Again, it took months before the parts even resembled anything usefull. As of the day I left, they were still sorting eveything incoming, and throwing 40-50% right into the s**** hopper. But, they had quadrupled the profit, even with shipping and 50% fallout. Sign of the times, I guess.:rolleyes: Now back to your regularly scheduled programing!
  25. rd martin
    rd martin
    from indiana
    once again what grandpa said was correct, if ya buy ****, your gonna get **** on boy!
  26. big creep
    big creep
    this is very true, i would rather spend a few more bucks to get a quality product that last! **** i pay 150 bucks for my work boot, yes it cost more but, it keep an American employed! and thats what we all should be doing!
  27. I dunno. I have a lot of good coils here that if shook, you can hear the liquid. That's only possible if there's some air
  28. GMC BUBBA
    GMC BUBBA
    Just a matter of reference , our coils sell for $61, and customers dont complain (especially when they are on their 3rd brand x coil):D
    Quality is sometimes hard to find........
  29. GMC BUBBA
    GMC BUBBA
    Got to have that room for expansion of the oil etc. They should shake and slosh....:)
  30. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Did you ever hook up your pertronix backwards? I hooked one up backwards a long time agao and it wouldnt start so I figured out it was hooked up wrong. I then hooked up the wires the right way, it started and ran. BUT it kept leaving me on the side of the road after so many minutes of running. Figured I fried it and when and got another one and hooked it up correctly and it has been in my car for 14 years now and still works fine with the same coil. My coil even has a small hole on the bottom from something rubbing against it years agao.
