Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. ebtm3
    ebtm3
    If you do decide to start a new thread, please pose the location here. I, for one, am interested in that kind of thing.
    Herb
  2. Hardhatz
    Hardhatz
    Just to clarify something I muddled before: I am thinking of cog belt rather than chain. Like the final drive on a Harley. Cleaner, quieter, and easily will handle the torque given that you are running "rear" sprockets on the driving side, thus reducing torque by about 75% compared to a typical M/C primary.
    All you'd need at the back is a sturdy stub shaft on the right side of the diff to carry your sprocket hub/yoke. Looking at what you've done so far, I'd say it's about a 30-minute job for you! Consider a rear axle hub from a small FWD car.
    Bodame brings up an excellent point about the reverse issue. Although you could just go electric, perhaps an opportunity exists for a reversing transfer in front .
    I think it's really cool that you are putting your issues out there for ideas!
    And, I say "Bravo" to what you've done so far..
  3. UKAde
    UKAde
    from Oxford UK
    A lot of Austin 7 single seated cars run an offset differential, early banjo type look like small versions of a model a ford rear axle
    One side is cut and welded together and the other is extended half shafts can be made to suit ,
    There is always the option of running a solid rear axle like GN or frazer Nash cars , the jappic recreation I am currently building uses a 25 mm solid rear axle
    But you would need to turn the drive through 90 degrees to then run a chain final drive
  4. banjeaux bob
    banjeaux bob
    from alaska
    3 wheeler
  5. banjeaux bob
    banjeaux bob
    from alaska
  6. banjeaux bob
    banjeaux bob
    from alaska
    Dual overhead cam Salmson w/ Weymann body on offer through Leboncoin in France.
  7. onelung
    onelung
    from Adelaide
    It's just possible this is a modified Victoria Combination ("La Parisienne")
    In 4 wheeled form they were somewhat unstable, evidently. One can maybe ***ume the caster was modified in the process to make things safer.
  8. banjeaux bob
    banjeaux bob
    from alaska
    GN Spider II. GL pic
  9. ninosdad
    ninosdad
  10. banjeaux bob
    banjeaux bob
    from alaska
  11. noboD
    noboD
    Bob, that thing is crazy!! I love it. Look at the expression on the dog's face.
  12. onelung
    onelung
    from Adelaide
    What a great website - and you just have to love the Bécognée ...:)
  13. banjeaux bob
    banjeaux bob
    from alaska
    Lung! You're happy about something!
  14. banjeaux bob
    banjeaux bob
    from alaska
  15. banjeaux bob
    banjeaux bob
    from alaska
  16. banjeaux bob
    banjeaux bob
    from alaska
  17. UKAde
    UKAde
    from Oxford UK
  18. banjeaux bob
    banjeaux bob
    from alaska
    Quite a bit of research Ade! Did they make you wear white gloves to handle the paper? I like Buckingham's moustache.
    Bob
  19. UKAde
    UKAde
    from Oxford UK
    Some of the old magazines are very fragile White gloves not required but there are little pillows to rest some books on so they don't get damaged ,
  20. banjeaux bob
    banjeaux bob
    from alaska
    I have gone to look at paper and brought my own gloves..... only to find that I was treating the material more kindly than the stewards!
  21. banjeaux bob
    banjeaux bob
    from alaska
    1920 HINSTIN Vintage Revival pic. vintage-revival.fr
  22. banjeaux bob
    banjeaux bob
    from alaska
    1946 Montichari,Lombardia .....Italy
  23. banjeaux bob
    banjeaux bob
    from alaska
    1928 Ratier. Vintage Revival pic. www.vintage-Revivsal.fr
    Picture shows the car running on the banked oval at Montlhery.
  24. UKAde
    UKAde
    from Oxford UK
  25. 64 DODGE 440
    64 DODGE 440
    from so cal
    Does that qualify as a "Ratier Rod"? :p Looks great on the banking.
  26. banjeaux bob
    banjeaux bob
    from alaska
    More Ratier for the old Dodge guy.I have posted most of these before.
  27. banjeaux bob
    banjeaux bob
    from alaska
    I think this is more of a ratier rod...
  28. 64 DODGE 440
    64 DODGE 440
    from so cal
    Only as old as I feel.......must be damn near 97 today. :D
    Looks like rats just want to have fun.
  29. banjeaux bob
    banjeaux bob
    from alaska
    Czech car show...
  30. banjeaux bob
    banjeaux bob
    from alaska
    Duncan trialing in his fur covered GN.Paul Saunders pic.
