Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. Kume
    Kume
    Now there is an interesting vehicle lined up in front of a bug - what more can you tell us about the Lombard Banjeaux bob?
  2. banjeaux bob
    banjeaux bob
    from alaska
    That is all the info I got with the image.I can tell you that a Bugatti was not always the fastest car in the field.
  3. banjeaux bob
    banjeaux bob
    from alaska
    Kume,here is the inner workings of a Lombard engine.Bronze head,dual overhead camshafts,substantial crankshaft support, all in a 1927 package.It also employs a muti-plate clutch ***embly.
  4. banjeaux bob
    banjeaux bob
    from alaska
    More Lombard engine details.Marc images...
  5. nexxussian
    nexxussian
    Wow, ball bearings everywhere. :D
    I take it the rods are either ball or some other rolling element (anti friction) bearing. :confused:
  6. smarjoram
    smarjoram
    from uk
    What a crazy car - I love it!
  7. Gamlebilrokker
    Gamlebilrokker
    from Denmark
    There is something in the water in Great Britain. I have been lurking at those cyclecars for a while now, abd just at the point where you think that it can't get more werid than what you see, there is something even more crazy comming up.
  8. Airhead Roadster
    Airhead Roadster
    Question: I see a lot of vintage cars with what appear to be brake or shift levers side mounted exterior of the vehicle. Are these brake or shift levers or both? If some are brake levers, would they be the only means of applying the brakes? Or were they a parking brake of sorts?
    The reason I ask is because the area I intend to mount my foot pedals is pretty tight and my feet are pretty big. I was thinking of using a side mounted brake lever instead of a foot pedal for the brakes if it was common practice in the day. That way I'd have more room for the gas pedal.
  9. Ned Ludd
    Ned Ludd
    By the Vintage era the absence of a footbrake was very rare. Most outside levers were indeed handbrakes, considered an auxiliary brake ever since outside the USA, be it for emergency stops, parking on inclines, or whatever. (On trials specials it became common quite early to fit two handbrakes, one acting individually on each rear wheel, to allow one manually to counteract differential action in slippery situations.)
    Outside gear levers were also common in the Vintage years. Formal coachwork would place the lever between the driver and the door. Some cars even had the gear lever between the driver's knees :eek: And the arrangement of pedals was by no means standard: it was not uncommon to have the throttle pedal in the centre and the brake on the right.
    So, I fear I can offer no better than sympathy regarding the design constraints of a narrow footwell: with any luck I shall be facing the same problem before long :D
  10. DjNeil
    DjNeil
  11. T-Head
    T-Head
    from Paradise.
    Principles of Cycle Car Construction – Part IV
    Part IV of our ongoing series about the world of cycle cars, with more excerpts from that definitive article on the subject from the January 15, 1914 issue of The Automobile magazine cane be found on The Old Motor.
  12. banjeaux bob
    banjeaux bob
    from alaska
  13. UKAde
    UKAde
    from Oxford UK
    I think the jappic cyclecar originally had
    Hand throttle on steering wheel
    Brake and gears on outside
    Just clutch pedal in the footwell
    As the jappic was built for record breaking on banked tracks breaks were only needed afterwards
    But as I intend to do some compe***ive events when it's done
    I will have
    Clutch and footbrake on footwell
    Gears and e brake on outside
    There are a couple of vintage hill climb cars here in the Uk which only have one brake lever on the outside and no pedal
  14. banjeaux bob
    banjeaux bob
    from alaska
  15. UKAde
    UKAde
    from Oxford UK
    jappic progress front spring mounts/damper mounts just about there
  16. banjeaux bob
    banjeaux bob
    from alaska
    Ade,did you make the shocks or are they Andre's?
  17. UKAde
    UKAde
    from Oxford UK
  18. Airhead Roadster
    Airhead Roadster
    Those caught my eye as well. I would love to have some made in stainless for the Airhead Roadster and considered using the orginal Hartfords I have for pattern making.
    Were those laser cut Ade?
  19. gnichols
    gnichols
    from Tampa, FL
    A little O/T. Gary
    Dang it! I told her not to wash it in hot water!
  20. UKAde
    UKAde
    from Oxford UK
    they are laser cut ,, the company up the road charges me about £80/hour for cutting if I supply the material
  21. banjeaux bob
    banjeaux bob
    from alaska
    Bugatti Type 10
  22. banjeaux bob
    banjeaux bob
    from alaska
    1931 Rally from La Festa Autunno in Japan.
  23. banjeaux bob
    banjeaux bob
    from alaska
    1913 Peugeot
  24. banjeaux bob
    banjeaux bob
    from alaska
    From the Gunn Cyclecar Co.
  25. banjeaux bob
    banjeaux bob
    from alaska
    More from the Gunn Cyclecar Co. 250C.C. 2 cycle flat twin by the Enfield Cycle Co..
  26. Kume
    Kume
    Gorgeosity made flesh!
    Is that an austin badge?
  27. banjeaux bob
    banjeaux bob
    from alaska
    Kume,it IS an Austin Seven based special.
    BanjeauX Bob
  28. Kume
    Kume
    I understand the Austin 7 had a great little motor. There is no shortage of very cheap 1920s Austin 7 parts in New Zealand and I have often been tempted to build a special. I guess the austin 7 isn't a cycle car to the purist but I have seen some wonderful specials with very pleasing bodies and remarkable power to weight ratios for their time.- alas for the same reason I sold all my lambrettas and vespas - when you get to a certain age and weight you just look like a dam fool on or in them.
    Kume
  29. 64 DODGE 440
    64 DODGE 440
    from so cal
    Easy solution to those problems Kume. I have found that as the years add up, (turned 67 this April) that growing older does appear to be mandatory, but growing UP is optional. Peter Pan is a good role model and hence I really don't care what others think of my actions and enjoy doing whatever activities I care to do, remaining one of the "lost boys" forever. Once we get our HA/GR project finished I have plans to build a single cylinder 500cc Morgan trike "replica". May look like a damn fool, but I'll be a damn fool having fun and that's what it's all about. :D
  30. banjeaux bob
    banjeaux bob
    from alaska
    This image via Paul at http://www.thevintagent.com . 1924 Morgan Racer with 8-valve Anzani engine.the engine was designed by the gentleman standing ,Hubert Hugens.Driver Harry Martin.
