Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. motoklas
    motoklas
    from Bern, CH
    Fred,
    Could that be small gearbox (for 2-3 speeds) or for reverse, or for both purposes?
    I suppose that box at the middle of jack-shaft isn't differential, but just 90° transfer-box - and pulley/belt combination serve as limited differential with slipping of belts at corners and sharp curves... So, jack-shaft could be in one piece - what happened at one side - happened at another too?
    Front pulleys really looks as some for CVT, but rear pulleys look fixed? At the beginning of ** century, there were some systems for motorcycles, but both pulleys were separated in the middle and could be pushed out or pulled inside as at modern CVT... Only, cl***ic systems had smaller ratio of speeds...
    Maybe there is somewhere textual explanation?
    Ciao,
    Zoran
  2. banjeaux bob
    banjeaux bob
    from alaska
    Mercury cyclecar built between 1913-14. 13083347_913665535419772_112336835423560607_n.jpg
    Rolfzoller likes this.
  3. fredvv44
    fredvv44
    Zoran, in this photo it looks like a gear shift lever on top of the bevel box. Also looks like a lever going to the centerpoint of the rear spring maybe to tighten or loosen the belt??!!
    Rolfzoller and motoklas like this.
  4. motoklas
    motoklas
    from Bern, CH
    Fred,
    Lever with white knob on bevel box could be command for Forward-Neutral-Revers, similar system used for outboard motors and later used for DAF automobiles with CVT?
    Two levers on the right side: maybe one for transmission and another for hand-brake? But, they are the same - quite confusing... Question could be if lever(s) moved trans-axle or rear axle as Bedellia had?
    On most of models (racing and touring) there is third lever on right side, smaller and something behind two bigger...
    Pity that there is no photos about reconstruction of some David! Anyway, it looks as quite well-built and serious cycle-car, almost real automobile!
    Zoran
  5. motoklas
    motoklas
    from Bern, CH
    ... some more details could be seen on attached video:
    Begining:
    Some details:
    On a few places, it was mentioned that DAVID has variable transmission...
    Zoran
  6. banjeaux bob
    banjeaux bob
    from alaska
    13055309_915061735280152_1970508730652563767_n.jpg Sweden 1927,Amilcar 4 cylinder. J-P C. ...
    Kume likes this.
  7. fredvv44
    fredvv44
    Thanks for all that Zoran. Really interesting car. I think you might be right about the shift lever.
    chriseakin likes this.
  8. banjeaux bob
    banjeaux bob
    from alaska
    13082641_564953453671782_5003481002844067399_n.jpg 13092068_564956530338141_1439526634894219356_n.jpg 13012812_564958483671279_4770062447066992102_n.jpg some little cars from H.K. ...
  9. ebtm3
    ebtm3
    Nice shack also--wouldn't mind living there-
    Herb
  10. banjeaux bob
    banjeaux bob
    from alaska
    Herb,I always enjoy the ironic juxtaposition of showing an economy car in front of a luxury home.
  11. banjeaux bob
    banjeaux bob
    from alaska
    13100889_1593391344306181_5477441887078328712_n.jpg 13015439_1593391287639520_146005580282226678_n.jpg 13102796_1593391304306185_6235847795334287672_n.jpg Curtiss powered Frazer-Nash. Images from F.S. ...
  12. banjeaux bob
    banjeaux bob
    from alaska
    Here's some older video of the Curtis Frazer-Nash
    chriseakin, Ned Ludd and Rolfzoller like this.
  13. Herb, it's funny- that house is almost identical to where one of my grade school buddies (JR Bottoms) grew up in South Narberth (right along South Narberth Ave)- did a double-take when Bob posted the pic :)
  14. fredvv44
    fredvv44
  15. ebtm3
    ebtm3
    Yeah--suddenly I have a wet spot in my crotch!
    Have to say that that's my all time dream car--
    Herb
  16. banjeaux bob
    banjeaux bob
    from alaska
    11891212_10207825625109341_578518586106009832_n.jpg Amilcars from F.G. ...
  17. banjeaux bob
    banjeaux bob
    from alaska
    Amilcar C6 prince Bertil of Sweden J-P C. ... 13087446_915692315217094_5759100895352136554_n.jpg
  18. The37Kid
    The37Kid
    The butler and cook had to get to work somehow. Bob
    banjeaux bob likes this.
  19. banjeaux bob
    banjeaux bob
    from alaska
    13102602_10154076688088361_4797800671644907898_n.jpg The 2016 VSCC Spring Rally.
    Kume and ebtm3 like this.
  20. banjeaux bob
    banjeaux bob
    from alaska
    13015416_1017572034945776_5079586419560417806_n.jpg Georges Grinard driving an Amilcar C6 in the 1938 Bol d' Or .
    rmcroadster likes this.
  21. banjeaux bob
    banjeaux bob
    from alaska
  22. banjeaux bob
    banjeaux bob
    from alaska
    13102726_1131286266892141_4171504037666407124_n.jpg 1927 AmilcarCGS
    Kume and Rolfzoller like this.
  23. banjeaux bob
    banjeaux bob
    from alaska
    13043612_1017584128277900_50623013054459860_n.jpg A familiar sight... the 1925 Maratuech "Auto-Avion".
  24. banjeaux bob
    banjeaux bob
    from alaska
  25. banjeaux bob
    banjeaux bob
    from alaska
  26. banjeaux bob
    banjeaux bob
    from alaska
  27. banjeaux bob
    banjeaux bob
    from alaska
    13094248_1018196178216695_4523447518745297029_n.jpg 13096117_1018195664883413_7155233199769217743_n.jpg 13118900_1018195668216746_1541903472989317688_n.jpg 1927 GIMA formerly of the Serge Polozi collection. Marc images. ...
    Kume, Rolfzoller and t-rod like this.
  28. noboD
    noboD
    That wet spot comes with old age.
  29. ebtm3
    ebtm3
    Who you callin old?? I'm only 560 in dog years!
    Herb
  30. banjeaux bob
    banjeaux bob
    from alaska
    That depends...
