Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. chrisp
    chrisp
    More info's on that thing?
    I wonder how the gear box holds because they are weak compared to the later one. And it's still no sports car given how you have to finesse every gear in position, other wise you end up with a 10mm socket and flat screwdriver to unlock the trans or you end up with a blown trans.
    It's weird to see the aluminum parts (engine block, steering rack...) painted in black.
  2. banjeaux bob
    banjeaux bob
    from alaska
  3. banjeaux bob
    banjeaux bob
    from alaska
  4. banjeaux bob
    banjeaux bob
    from alaska
  5. banjeaux bob
    banjeaux bob
    from alaska
    15578871_1326517457371653_8544151429273703495_n.jpg BNC 527 Monza from Igor.
    Jacketch, Kume and Rolfzoller like this.
  6. banjeaux bob
    banjeaux bob
    from alaska
    15541931_10154889536434306_2337856044115544607_n.jpg 15439698_259762681107878_8638470815888683880_n.jpg 15541502_10154889847099306_8469662448579296742_n.jpg 14600973_10154889851694306_2538209630009724254_n.jpg Same car,same event(Vintage Revival Montlhery 2014),and 3 different photographers...Marc ,Max,and Marc T..Marc T. was focusing on the Amilcar and provided the detail image.
    Jacketch, t-rod and Kume like this.
  7. banjeaux bob
    banjeaux bob
    from alaska
  8. banjeaux bob
    banjeaux bob
    from alaska
    15542014_1141114926007818_7120558312108546204_n (1).jpg Morgan powered by a Moto Guzzi engine... appears to be at Angouleme.
    ebtm3 and morac41 like this.
  9. banjeaux bob
    banjeaux bob
    from alaska
    8bf2bfbe424d58da1c8e6ab13337eeac.jpg Darmont for sale with no price given.
    Rolfzoller likes this.
  10. banjeaux bob
    banjeaux bob
    from alaska
    1555394_533188360142510_8078476509891413476_n.jpg 15541908_1013568918771116_6444100572059468268_n.jpg A couple of Amilcar CGS's .....
    Jacketch, t-rod, Kume and 1 other person like this.
  11. banjeaux bob
    banjeaux bob
    from alaska
    15541666_10211394896818719_1195809523944422737_n.jpg 1922v Senechal W/ 750cc engine
  12. banjeaux bob
    banjeaux bob
    from alaska
    15542058_10211394614651665_6868407302209434725_n.jpg PARKER at Montlhery by J-J C. ...
    Jacketch, Ned Ludd, Kume and 2 others like this.
  13. jonto
    jonto
    from UK
    What's the car, French registration? 15577927_1474848385858866_2910767761620128474_o.jpg
    banjeaux bob and Rolfzoller like this.
  14. motoklas
    motoklas
    from Bern, CH
    Jonto,
    French Clément-Bayard, maybe?
    Ciao,
    Zoran
  15. jonto
    jonto
    from UK
    Yes thanks Zoran, that is it, I'd wondered if it might be a Charron but had not looked them up as yet. The question was posted on another forum, I'll let them know.
  16. chrisp
    chrisp
    That car was registered in the Arras region, north of France, in about 1923, the sidecar is from the Pas de Calais region, north /west of France and registered in june 1920. This was a used car of about 10 years when registered.
    banjeaux bob likes this.
  17. Rolfzoller
    Rolfzoller
    Wish all of you a Merry Christmas and a Happy New Year.
    Rolf
    rooman likes this.
  18. Leon Sandcastle
    Leon Sandcastle
    Jacketch and Egor like this.
  19. ROADSTER1927
    ROADSTER1927
    Looks well equipped to me! Gary
  20. Leon Sandcastle
    Leon Sandcastle
    It was a French anti-tank weapon
    Sent from my HTC One A9 using The H.A.M.B. mobile app
  21. kabinenroller
    kabinenroller
    I do not know much about the Panhard. A friend of mine bought the car in pieces, the dis***embled car had been in a fire. He bought it and found the supercharger in the parts that came with the car. The engine had a intake manifold with a two throat carb on it, the supercharger uses a single throat carb. The car is now almost completely ***embles except for interior and folding top. I will post more pictures soon.
  22. fredvv44
    fredvv44
    I think this will be on topic so here goes.
    The 3 wheeler you see here has a MotoGuzzi 1000cc engine with Dellorto PHF-30 carbs. I have a pressure regulator set at about 3#.
    When hard cornering the outside carb seems to run dry and the outside cylinder quits. Coming out of the turn it stumble back to life. So, this would also happen to cyclecars with bike engines and bike carbs.
    My ***umption is that fuel sloshes up the side of the carb starving the main jet and possibly forcing the float up closing the needle valve. Fuel comes out of the vent tube also. Body roll would also add to the mix since the carb will be tilted. It looks like it happens more with left turns which is odd since the right carb vent is on the left side of that carb.
    Have any of you with cyclecars or 3 wheelers had this happen? Any suggestions to cure it?
  23. banjeaux bob
    banjeaux bob
    from alaska
    Electronic fuel injection hidden within the present fuels system.....
  24. banjeaux bob
    banjeaux bob
    from alaska
    15672899_1205109736192004_5055558725347962012_n.jpg marc pic. ...
    Jacketch and Ned Ludd like this.
  25. banjeaux bob
    banjeaux bob
    from alaska
    15622762_1208229719255670_6374523109922427171_n.jpg GCL oic of an Amilcar at the VSCC 2011 Prescott meet.
    Kume and Jacketch like this.
  26. motoklas
    motoklas
    from Bern, CH
    Hello Fred,
    Maybe to replace motorcycle type carburators with a pair of some old but good auto carburators for small European or Asian cars? They should be resistant to side-forces (centrufugal) during cornering?
    Ciao,
    Zoran
  27. fredvv44
    fredvv44
    I thought about SU carbs but someone said that they had the same problem with racing Minis.
  28. motoklas
    motoklas
    from Bern, CH
    ... maybe some sport-type from small FIAT if could be found in USA? We had so-called National-Cl*** racing for Zastava 750 (later Zastava 850), that were slightly modified FIAT 600d, giving up to 35 HP for smaller engines and up to 40-45 for bigger! As I remeber, allowed was use of Weber carburators, Solex or Zenith, with restriction of size... Double-barell Abarth carburtaors (single or a pair) were allowed for "open cl***" of 850 cc.
    I had two SU carburators on my Triumph Dolomite, driving it without problems, but more in family style than any sport way.
    Z.
    P.S. (added): that is my experience old 4 decades! Probably nothing of that could be now found in USA! Maybe, still in Europe...
  29. fredvv44
    fredvv44
    A test drive showed it happening on right and left turns. Only happens on a tight hairpin corner at 30 MPH in 2nd gear. Larger sweeping curves at the limit of adhesion seems to be OK. Not something I have to do in normal street driving so I'll have to live with it.
  30. 64 DODGE 440
    64 DODGE 440
    from so cal
    You might find that SUs will have a slightly larger float bowl and cause less of a problem. Just a random thought from my random brain.
    While I'm here, Merry Christmas and the best in 2017 to all the crazies that hang out here.
