Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. timberwolf01
    timberwolf01
    Ok, I know what it's not. It's not a cyclecar OR an Austin Seven! But, can any of you remarkably knowledgeable people tell me what this fabulous ORIGINAL looking old girl (top) is? (Only original once, oily rags rule Ok!?) Thanks in advance, Le Zebre Curtiss special photo (bottom) for cyclecar content!
    Okie Pete and Bandit Billy like this.
  2. ROADSTER1927
    ROADSTER1927
    Areo engined Race car.
  3. Bandit Billy
    Bandit Billy
    What's that snake head thing?
    Okie Pete and Outback like this.
  4. noboD
    noboD
    The horn, common back then.
    Okie Pete and timberwolf01 like this.
  5. mohr hp
    mohr hp
    from Georgia
    I think the left one is an American La France based Speedster, pieced together in the recent past. Not sure on the maroon one, but it's powerplant is an OX-5 aero engine.
    Ned Ludd and timberwolf01 like this.
  6. timberwolf01
    timberwolf01
    The maroon one is the Le Zebre Curtiss special with, as you correctly pointed out, the OX-5 engine. Thanks for your thoughts on the other one!
    Ned Ludd likes this.
  7. banjeaux bob
    banjeaux bob
    from alaska
    The real answer is did the idea endure?
  8. j hansen
    j hansen
  9. fredvv44
    fredvv44
    Are those 2 cycle engines? I see a bunch of holes low in the cylinder wall on both of them.
  10. timberwolf01
    timberwolf01
    Hi fredvv44, this from wiki
    "They were all air-cooled side-valve engines; each exhaust valve was controlled from below by a cam in the crankcase.[2] Each was mounted in a cell to the side of the cylinder, with the automatic, atmospheric pressure-driven spring-loaded inlet valve immediately above it, partly to minimise volume and partly to help cool the hot exhaust valve."
    You can see the exhaust valvegear in the attached photo.
    Okie Pete, Ned Ludd and banjeaux bob like this.
  11. timberwolf01
    timberwolf01
    Neumann-Neander-Fahrmaschine
    Okie Pete, Ziggster, porkshop and 2 others like this.
  12. fredvv44
    fredvv44
    A very interesting engine. In some ways similar to the Gnome rotary. It had it's intake through a hollow crankshaft and a p***ageway to ports in the cylinder wall similar to a 2 stroke. My all time favorite engine.
    timberwolf01 likes this.
  13. timberwolf01
    timberwolf01
    Austro-Grade. Interesting steering setup, and chain drive to right hand rear wheel only, solid back axle.
  14. timberwolf01
    timberwolf01
    Racy version!
  15. timberwolf01
    timberwolf01
    Pretty little car:
    Koco 4/12 PS HK1 - 1922
    1.020 cc
    Flat 2
    12 hp
    Vmax : 65 km/h
  16. Ned Ludd
    Ned Ludd
    Interesting that it should have coil springs at the rear?
    porkshop and timberwolf01 like this.
  17. timberwolf01
    timberwolf01
    Yes, I thought the same Ned. So far been unable to unearth a photo of the bare ch***is to get a better look at the setup.
    Okie Pete, porkshop and Ned Ludd like this.
  18. Ned Ludd
    Ned Ludd
    That style of Dutch sounds quaintly archaic to my Afrikaans ears!
    "Springing: very soft and pleasant. The front springs semi-elliptic, rear spiral." — in spite of the apparent total lack of damping.
    Okie Pete, porkshop and timberwolf01 like this.
  19. j hansen
    j hansen
  20. timberwolf01
    timberwolf01
    Okie Pete, Ned Ludd and porkshop like this.
  21. timberwolf01
    timberwolf01
    I thought it might be familiar Ned!
  22. timberwolf01
    timberwolf01
    1902 Sunbeam Mabley. A cyclecouch?
  23. fredvv44
    fredvv44
    That's amazing.
  24. timberwolf01
    timberwolf01
    Obviously before the 'Elfe and safety' regulations . . .
      88.5 KB
  25. fredvv44
    fredvv44
    The mud guards are insane!!!
  26. j hansen
    j hansen
  27. j hansen
    j hansen
    Found a replica...
    Skärmavbild 2023-10-30 kl. 15.21.22.png Skärmavbild 2023-10-30 kl. 15.28.08.png
    Kume, banjeaux bob, Okie Pete and 4 others like this.
  28. j hansen
    j hansen
    And the Big Boy...
    Skärmavbild 2023-10-30 kl. 15.26.36.png Skärmavbild 2023-10-30 kl. 15.26.21.png
    Kume, Okie Pete, Ziggster and 2 others like this.
  29. timberwolf01
    timberwolf01
    What a contraption!!!
  30. timberwolf01
    timberwolf01
    Here's some more 'amazingness' for you fredvv44 . . .
    "The unconventional vehicle had four wheels, one at the front, one at the back, and two in the middle. It was shaped like an 's' sofa with a seat on each side facing in different directions, and powered by a 2.75hp. De Dion single cylinder, water-cooled engine.
    The engine, mounted above the front wheel, drove the middle wheels by a leather belt and chains. It had tiller steering on the front and rear wheels, pneumatic tyres and a drum brake on each driving wheel."
    porkshop, Okie Pete and Ziggster like this.
