Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. timberwolf01
    timberwolf01
    1896. Ransom E. Olds in the Olds “Pirate” racing car.
    Okie Pete and porkshop like this.
  2. fredvv44
    fredvv44
    I liked the patent drawing showing a gas engine in the Curry. I'm not much for pulling that strap.
  3. timberwolf01
    timberwolf01
    1920 Pegase
  4. timberwolf01
    timberwolf01
    1913 Spacke 'Prototype':
    71 cubic inch, 13hp atmospheric intake single, 2-speed gearbox, electrified acetylene headlights
    Okie Pete, porkshop and roadsterlines like this.
  5. Ned Ludd
    Ned Ludd
  6. timberwolf01
    timberwolf01
    Interesting front suspension setup on this one
  7. timberwolf01
    timberwolf01
    To stop this contraption apparently you have to PULL on the steering wheel!
    Okie Pete, porkshop and Ned Ludd like this.
  8. j hansen
    j hansen
    And it leans!
  9. Ned Ludd
    Ned Ludd
    Bedelia?
    Centre-pivot steering meant effective reduction in track in tight turns.
    I wonder if it was a p***ive tilting setup, i.e. initiated by countersteering as on a bicycle. Tilting vehicles fascinate me.
    Okie Pete, porkshop and timberwolf01 like this.
  10. j hansen
    j hansen
    Jacquemont...
    Skärmavbild 2023-11-06 kl. 07.33.53.png Bedelia...
    Skärmavbild 2023-11-06 kl. 07.35.46.png Skärmavbild 2023-11-06 kl. 07.34.19.png
  11. j hansen
    j hansen
    Mr Neumann- Neander did some interesting stuff.
    Okie Pete, porkshop, Ned Ludd and 2 others like this.
  12. timberwolf01
    timberwolf01
    No, it's what j hansen said :)
  13. fredvv44
    fredvv44
    Many cycle cars used the Soapbox Derby type steering.
    porkshop likes this.
  14. The37Kid
    The37Kid
    Often wonder if this boat steering with a Model T steering wheel would work in a cyclecar build. Should sell it. Bob
  15. timberwolf01
    timberwolf01
    Must be road legal, it has a horn!
    Okie Pete, porkshop and j hansen like this.
  16. fredvv44
    fredvv44
    Notice the frame tubing on that car. It's all motorcycle fittings; tee and 90 deg. fittings. I once saw a catalog from back then where you could buy all kinds of fittings. Morgan 3 wheelers were made like that with the fittings brazed to the tubes. You could easily heat them up and remove them for repairs.
    Okie Pete and timberwolf01 like this.
  17. timberwolf01
    timberwolf01
    Bow-V cyclecar:
    "It had a Precision 1096cc, V-twin engine, mounted on a ch***is-less body made of three-ply wood. Power was transmitted from the engine through a chain to a clutch and a four-speed gearbox, and then on to the back axle via another chain. The controls for brake, clutch and accelerator were all operated in a way not dissimilar to many cars at the time, and the dials forming the dashboard were lit from the car’s sidelights, thanks to a small window on each side of the scuttle. The price of the Bow-V was £180, or £200 with a dynamo lighting set."
  18. timberwolf01
    timberwolf01
    1928 Zaschka 'collapsible' car
  19. timberwolf01
    timberwolf01
  20. timberwolf01
    timberwolf01
    Spot the reversing mechanism . . . 167abfe0-65c1-4e5b-8ec2-ed9de927f9cb.jpeg.jpg
  21. timberwolf01
    timberwolf01
    A rare Bear
    Okie Pete, Ziggster, porkshop and 3 others like this.
  22. fredvv44
    fredvv44
    Flintstone reverse??!!
    timberwolf01 likes this.
  23. timberwolf01
    timberwolf01
    Exactly!! :)
  24. timberwolf01
    timberwolf01
    Is it just me, or does she look properly embarr***ed??!!
  25. timberwolf01
    timberwolf01
    A cyclesub?
  26. j hansen
    j hansen
  27. timberwolf01
    timberwolf01
    That is the coolest video! Thanks j hansen!
    j hansen likes this.
  28. timberwolf01
    timberwolf01
    It has a name!
  29. fredvv44
    fredvv44
    You remember the famous photo of Jacques Lartigue; here is his wife Zissou. Zissou, jacques-henri lartigue (0).jpg Zissou, jacques-henri lartigue (1).jpeg
    Okie Pete, Ziggster and timberwolf01 like this.
  30. j hansen
    j hansen
