Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. fredvv44
    fredvv44
    You don't wear loose leg pants driving that car.
  2. fredvv44
    fredvv44
  3. timberwolf01
    timberwolf01
  4. fredvv44
    fredvv44
    I can't tell for sure if that is a JAP engine but I know they had those finned alum. coolers over the valves on their side valve engines.
  5. timberwolf01
    timberwolf01
    I believe you are correct, sir.
    "In the 1920s, he had made his own first four-wheel cyclecar, powered by an air-cooled JAP V twin. Asked by fellow compe***ors to make them a similar machine, he productionised it through use of a JAP or water-cooled Blackburne V-twin, of either 998 or 1097 cc." (Wikipedia)
  6. Ziggster
    Ziggster
    porkshop likes this.
  7. banjeaux bob
    banjeaux bob
    from alaska
    Sorry, I don't know who owns it. The seat also looks quite similar.
  8. timberwolf01
    timberwolf01
    I believe it belongs to New Zealander Louis McNair. I found this on another site:
    "Having now been in the U.K. for 3 years my ideas and inspirations have changed slightly from the wooden ch***is cyclecar I had originally intended. I’ve been very lucky to get quite involved in the vintage racing scene over here and have made some very good friends because of it. A GN cycle car was always the dream although with none available in NZ to look at and the closest example being in Aus it was quite hard to fathom coming up with one. Since being over here I’ve managed to collect enough GN parts to put together this which is my take on the Hillclimb special concept of the 20s-30s. Going to all the swap meets in the calendar i managed to get hold of all the other groovy bits and pieces that I needed for the build.
    The defining feature of a GN is its chain drive transmission and solid back axle. 4 different ratios with dog selection. An incredibly simple but extremely effective system with large scope for easily changing ratios. Normally on a GN these chains are on the back axle but on this car I’ve moved them forwards so they are under your legs, this means you can have a low down far back seating position that you can’t get with the chains on the axle. Of course It needed a name to get the poms scratching their heads...."
  9. Ziggster
    Ziggster
    Thanks for posting this!
    rod1 and timberwolf01 like this.
  10. fredvv44
    fredvv44
    Amazing build.
    Ziggster likes this.
  11. timberwolf01
    timberwolf01
    Hinstin CC1 1920
  12. timberwolf01
    timberwolf01
    Bugatti Type 13
    G Baese, Ned Ludd, porkshop and 2 others like this.
  13. timberwolf01
    timberwolf01
    Sima Violet
    porkshop and roadsterlines like this.
  14. banjeaux bob
    banjeaux bob
    from alaska
    410856948_852257210235737_4752385552756390787_n.jpg 'schmitts racing. who knew?
    Ziggster, Kume, roadsterlines and 2 others like this.
  15. fredvv44
    fredvv44
    Slow motion racing??!!
  16. roadsterlines
    roadsterlines
    'A. Machin driving an Austin 7, AMSC Standing 1/4 Mile' [1946] - George Thomas photo, State Library of Victoria pi017885.jpg
    Stueeee, Ned Ludd and porkshop like this.
  17. Kume
    Kume
    Louis' father Robert built an equally fascinating Riley 9 fitted with Gypsy major aero engine - covered in another thread on the HAMB. We are hoping Louis brings Katipo back to NZ but there are few events down here worthy of such a machine.
    rod1, porkshop, fredvv44 and 3 others like this.
  18. rmcroadster
    rmcroadster
    That Austin 7 on the standing 1/4 mile would have taken an eternity, was it timed using a calendar?
    Matthew
  19. fredvv44
    fredvv44
    LOL. Would probably beat my Morgan.
  20. Speed~On
    Speed~On
    I attended Vintage Torque Fest in 2019 (Dubuque, IA). A guy brought his cyclekart and it was a hit. This was the first time I've seen one and I was fascinated. What a great looking machine. He said he races this however, they are not as common in the Midwest as they are on the east and west coasts.
    Z06-LITE, j hansen and porkshop like this.
  21. El Caballo
    El Caballo
    from Houston TX
  22. j hansen
    j hansen
  23. timberwolf01
    timberwolf01
    LET'S TALK CYCLEKARTS . . .
  24. Kume
    Kume
    That is a separate thread
    Ned Ludd likes this.
  25. fredvv44
    fredvv44
    rod1 likes this.
  26. timberwolf01
    timberwolf01
    A veritable 'hens tooth' . . . . the 1919/20 Dobi
    Okie Pete and porkshop like this.
  27. j hansen
    j hansen
  28. timberwolf01
    timberwolf01
    1907 Peking-Paris Contal (this cyclecar ran out of fuel somewhere in the Gobi desert . . . and is still there, waiting to be found!) MotottriArticle2_7.jpg
    porkshop, Okie Pete and j hansen like this.
  29. fredvv44
    fredvv44
    Get your metal detector ready.
    porkshop and timberwolf01 like this.
  30. j hansen
    j hansen
